Question about Swift M7000D-MA11003 Binocular Microscope
Light does not go on
Repacing the bulb does not solve the problem. I suspect the part the bulb mounts onto makes poor contact - how can Ibe sure
  • 36 Answers
Yes, very often it is the lamp socket that has failed. Contact: Delta Optical Instruments, Inc. Email: robin@deltaoi.com
Posted on Dec 25, 2010
  • rnmconstruct Dec 25, 2010
    You can test the voltage before it enters the lamp socket with a voltage tester.
    It needs to be set on DC at something more than 6 volts.
My brake lights wont work everything else back there works just no brake lights what is causing it and how can i fix it
check if there is a brake light switch under the dash at the top of the brake pedal as it may be loose or a wire has fallen of the connection
Oct 29, 2014 | 1996 CHEVROLET SUBURBAN 1500 Grille...
Brake lights go on but when headlights are on and i press the brake they go off the brake lights go offf
Brad V's "bad ground" is most likely cause. I'd start investigating with the tail lights. (Not the headlights, but they may also be an issue.) Confirm all bulbs on both sides are good. That includes running lights, brake lights, turn signals and reverse. Some bulbs may have dual-function, the 3157 bulb in the J2K is one that serves stop-light (brake) and tail/running lights. Replace if suspect. Make sure the bulbs are mounted correctly. Rust can cause a poor ground so you might have to replace the socket or fixture if it is grounded to the fixture. By any chance do the turn signals also have issues? Or the emergency flash switch bulbs?
Mar 23, 2014 | 2000 Jeep Grand Cherokee
Left rear turn signal light will work and then stop I have to take the bulb out and put it back in tried swapping bulbs now the turn signal and brake light are not working
There could be a few different solutions;
1. the socket wires could be bent. Remove bulb and check for socket wires pushed into the socket housing. Use a small fine point pick to bend wires until they stick out into the bulb cavity.
2. The bulb wires could be out of alignment. Bend wires until they stick out from the bulb base.
Those 2 possibilities apply to the glass tang base bulb. If you have a metal base bulb ( it has the contacts on the bottom, with a metal base and pegs sticking out the side ). If this is your bulb style, you'll need to look at the contact points in the bottom of the bulb socket. If the contact point tops are flat or curved in, or if they are not clean ( green or brown corrosion on them ) you'll need to clean and re-grease the contact points before considering replacement. You can use either electrical parts spray ( recommended ) or a warm water and baking soda mix ( a coffee cup filled 3/4 up with warm water to a tablespoon of baking soda. Dissolve baking soda in water, make sure key is OFF and socket is away from other wiring. Pour a small amount into the socket and scrape contact points and side wall with a fine point pick or mini flat bladed screwdriver until contact points are clean ).
Dab a small amount of Dielectric grease onto the bulb base, covering the contact points and tags sticking out of the side, and re-install bulb, then test, If it still doesn't work, you'll need to replace the socket assembly - available from your local auto parts store.. Make sure you get a socket with the same number of wires and mount configuration.
Hope this helps!!
Mar 04, 2014 | 1998 Chevrolet Cavalier
Tail light not working
only the rear 3
but front 2 work, and side park lamps?
Mar 02, 2014 | 1999 Honda Accord
1998 buick century high mount brake light doesn't work, bulbs have been replaced
there is a seprate ground that mounts to the frame of your car near the light usualy in trunk in between the rear speakers locate and make shure the conection is good.if that dos not solve it on the pasengers side rear light check bulbs for detereated ends if thay are then replace.this shuold solve you problem
Jan 19, 2013 | 1998 Buick Century
Brake light passenger side is out. After changing the bulb, will not light. Wires look in good shape, not corrosion or breaks. While putting the fixture back into place, quickly came on then went off...
The problem is suspected to be the 'contacts' at the base of the bulb socket/holder/fixture - poor contact. If the contact point overheated and it melted (then 'sank' into its holder/fixture, then replace the bulb socket.
Nov 10, 2010 | 2004 Hyundai Santa Fe
1999 GMC Envoy: replaced both GE 3057 lamps in left rear light assembly. Lamps both light. However depressing brake pedal does not initiate brake light. The righ rear brake light does work. The high mount...
The high mount brake light has its own fuse, so check that first. The high mount bulb is generally a stabdard type (there may be more than one bulb) or you can replace with an LED. As for the left rear bulbs not working when depressing brake pedal, check the bulbs again for any spring that may be broken. If the bulbs are still good, make sure there is sufficient contact with the socket. If still not working, have someone check it out further.
Feb 15, 2010 | 1999 GMC Jimmy
Replaceing brake lights on the trunk assembly part, how do i get to the lights?
High-Mount Brake Light NOTE: Depending upon the vehicle, the center high-mount brake light may be accessed from outside the vehicle, through the trunk, or through the passenger compartment.
  1. Remove the center high-mount bracket light lens retaining screws.
Fig. 17: Use a screwdriver to unfasten the center high-mount lens retaining screws . . .
Remove the lens in order to get to the bulbs.
Fig. 18: . . . then remove the lens for access to the bulbs
Carefully pull the bulb away from its retaining clip contacts.
Fig. 19: Pull the light bulb from the retaining clips
Installation is the reverse of the removal procedure. Before installing the lens, make sure the brake light operates properly by having an assistant depress the brake pedal.
Jul 26, 2009 | 1999 Pontiac Bonneville
How do I replace the center brake light bulb on my 97 Oldsmobile 88?
  2. Remove the lens in order to get to the bulbs.
  3. Carefully pull the bulb away from its retaining clip contacts.
  4. Installation is the reverse of the removal procedure. Before installing the lens, make sure the brake light operates properly by having an assistant depress the brake pedal.
I'll post the pics here in a sec.
Please don't forget to rate!!!!
May 07, 2009 | Oldsmobile 88 Cars & Trucks
Swift M7000D-MA11003 Binocular Microscope Logo
116 people viewed this question
Top Swift Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Swift Science and Laboratory Expert? Answer questions, earn points and help others
