Question about Frigidaire FAS155K1 Air Conditioner
A/C condenser fan running slow and humming when themostat is off
I have a 1997 Bryant 561c A/C outdoor condenser unit which had the dual capacitor (40/5 370) replaced a few years ago and was running fine. A week ago the condenser fan stopped again so I replaced the cap with the proper replacement but this time without success. The unit is currently turned off at the outside disconnect.
Problems:
1) When powered up and thermostat at cool, the fan runs at 1/2 speed (~500-600 rpm) but I was getting cool air inside. After 5 mins or so it over heats and shuts down.
2) When the thermostat is off, the fan hums like it is getting some power but does not turn. I need to pull the disconnect to stop it.
3) When I turn the thermostat to "heat", the fan actually turns very slowly in the opposite direction.
I noticed a small spot almost like a gray colored burn on the top of the cap after rechecking the system so I think the new one fried.
It looks like the contactor is operating correctly but I do see some black on the contacts. I tried manually pushing the contacts closed (with an insulated screw driver) and there was no difference.
Any ideas what I should target?
-Greg
4 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: my outside condenser fan motor hums and slowly
hi there,
check the capacitor of your condenser fan,if busted replace,although thats the common causes of hummimg motor,it can't start,consider also after replacing capacitor still hum,check the motor start winding,and the supply from the source of relay in control panel.have a nice day
Posted on May 08, 2009
roniecon
  • 6927 Answers
SOURCE: My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Posted on Jul 08, 2010
  • 1033 Answers
SOURCE: CONTACTOR IS NOT MAKING CONTACT
Hello. Make sure you are getting 24 volts to the contactor coil, you can check by using a multimeter and put the probes of the multimeter to each side of the coil ( not the contacts) if you are not getting 24 volts than u must check the low voltage wiring to make sure there is no loose connection. also check the thermostat to make sure it is wired properly.
Posted on Feb 01, 2011
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
Model 393 Bryant furnace fan or motor makes noise when first starting. Then it's quiet.
https://www.repairclinic.com/PartDetail/Bryant-Furnace-Dual-Run-Capacitor/P2914553RS/2386586?ss=a36b380&mr=0
That part is probably going bad. The motor uses it to get moving and when it fails then the motor wont start, makes buzzing or humming noise due to phase loss.
Jan 28, 2017 | Bryant Heating & Cooling
My Bryant 561c airconditioner I need to know what wires to attach to my outside A/C is it blue on blue and yellow on brown
Brown is always active, blue is always neutral. But yellow or yellow/green is usually an earth. Sometimes on appliances yellow is used as a signal wire so if that is your only option then I would just run with that. If you trip your circuit breaker after turning it on then it was a earth and your back to square one
May 17, 2014 | Bryant 561CE060-A 561C Package Air...
Condenser motor hums but will not turn on
The hum you hear is the compressor running. The fan motor capacitor is most likely problem. The top of the capacitor should be flat. Bad ones will likely be puffed up. Other cause, bad motor.
Sep 27, 2013 | Bryant Heating & Cooling
My condenser fan runs and blows cool air but isnt cooling down the house. Any help.
Check the outdoor unit (condensing unit). Keep in mind, because the condenser fan is running it's not an indication that the compressor is working. On a split system,there's a dual capacitor that serves the fan and the compressor. The capacitor has three terminals.
1. common
2. fan = fan
3. Herm = compressor
This is a common problem; The outdoor fan (condenser fan) runs, but not the compressor (you have to know the sound of a running compressor or you'll mistake it for the sound of the fan) doesn't, because the compressor side of the capacitor is too weak to give it that needed phase angle that it requires to start. If you're referring to the outdoor fan spinning, but no cooling, I can bet the compressor isn't working and needs a new capacitor. Very common problem, I see it all the time. Before you change the capacitor, make sure that you cut the power to the unit, and then use an insulated tool such as a screwdriver and short the terminals together first. A capacitor holds a charge even after being de -energized.Buy the new one with the same exact rating written on it as the old one. Do not mix up the wires when replacing. Write it down or take a picture with your phone
Aug 20, 2013 | Heating & Cooling
My fan is nto blowing on my outside unit. i hear a light hum coming from the unit.
Sounds like the contactor is pulled in, but no power to the condenser fan motor. Check power to motor (through the contactor & check the capacitor.
Jul 11, 2011 | Bryant 463AAC008BA Air Conditioner
Bryant model 594DNO24-E Air out of vents not cool, fan is not moving on AC unit.
I think you are talking about the outdoor unit so see if you can hear the compressor running. If it isn't running then set the thermostat so that the unit is not running and give the pressure time to come down.(15mins-30mins) Discharge pressure will build up if the fan isn't running and cause the compressor to shut down that's the reason for doing this. After this set the thermostat to call for a/c then see if the compressor is running. If it isn't first check your circuit breaker or disconnect or fuses. One of these should be located close to the outdoor unit. If you have power and it's not running then look at the contactor to see if it is pulled in. The contactor supplies both the fan and compressor. After that then check you capacitor. Some use a double capacitor that works the fan and the compressor. Let me know what you find
Jul 04, 2010 | Bryant Heating & Cooling
Ac unit fan does not turn unless i force it to turn. also not producing cold air
If the fan just hums and if you spin the fan and it runs, check out the capacitor, it is bad. Most condensing units have a split capacitor, for the hermedic unit and the fan. If the compressor runs the dual capacitor is bad on the fan side. Your choice buy the dual capacitor, or just buy a single capacitor for the fan part of it. Make sure the voltage rating and microfarad ratings are the same. They will be marked on the old capacitor, as will fan (for fan), and herm for compressor). THATS 220 VOLTAGE YOUR WORKING WITH, BE SURE THE POWER IS OFF!!
Jun 22, 2009 | Goodman Heating & Cooling
Fan Not Working
either bad condenser fan motor or fan capacitor
Apr 24, 2009 | Samsung AW0503B Air Conditioner
Frigidaire FAS155K1 Air Conditioner Logo
634 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
