Question about Boss Audio MR1500 In-Dash Marine CD Receiver
Front panel on my Boss MR-1500 radio will not work. Can't tell which station I'm on. Is there a way to fix this?
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: repair centers
Try this # 323.890.3700 ext. 2770
Posted on May 31, 2006
mikew6
SOURCE: How can i fix it
you need a part cog just replacing one at the moment but remember the position it was in or it wont work when reassembled. cog is only nilon probably threaded. take off top, one screw. take out cd plater two silver screws either side on front. carefull when disconnecting ribbon under neith push up brown clip either side then prise out ribbon. now with great care unscrew two brassy collered screws on black metal cover to right hand side also a black screw on the side. you will have to move the screen in and out when doing this use the white cog to you right on top roll it backwards and forwards.now you will see the mechanisim for the front panel you will see from there whats threaded. probbably the little clear white cog sideways on on the right.
hope this helps.
mike.
Posted on Dec 24, 2009
SOURCE: radio stations
The +12V_Memory (pin 4 on A connector) must be connected to a permanent (not shutoff by ignition key) +12V.
HTH
Posted on Jun 10, 2011
On a boss cd/radio model # CD3155R scan does not stop or set
Could be a faulty antenna connection. The radio has to detect the stations before they can be set.
Dec 12, 2017 | Boss Car Audio & Video
Can be fixed an Original Skoda Fabia 2003 radio that gets stuck changing stations?
Anything can be fixed. I would check the front panel switches first.
Jul 12, 2017 | Skoda Cars & Trucks
2011 ram 3500, ipod frozen, will not play yet selection of songs etc does. Ipod works in other cars, new USB cord no help. How to fix? Reset uconnect?
uconnect (dodge, chrysler) issue ' Android Forums
androidforums.com > Android Phones > HTC Droid Eris
Jul 5, 2012 - According to htc/ford and chrysler, the evo is not yet compatible with ford sync or ... plug it into the USB connector using the iPod cable, does it work properly?... I can play songs, but the player will not pause, stop, or even force close. .... 2500Pickup2011 (D2) 3500 Pickup2011 (DD) 3500 Cab Chassis2011 ...
2013 Ram 1500 Radio Not Working Properly: 14 Complaints
www.carcomplaints.com/Ram/1500/.../radio_not_working_properly.sht...
The 2013 Ram 1500 has 14 complaints for radio not working properly. ... The screen would not update when a new station button was selected. ... you push, all you see is the Ram Logo.... can't change radio station or play a cd either! ... Also when my ipodwas plugged in i could hear my phone music through the speakers ...
Dec 21, 2015 | Audio Players & Recorders
18c808 aa subwoofer with amp from Focus. How do I install it?
ask here
http://www.f150forum.com/f75/how-fix-your-subwoofer-amplifier-7l2t-18c808-aa-227544/
or
Diagram 7l2t 18c808 aa - Dual Ford Mustang Convertible 94-12 Boss 12" Phantom Sub Box Ce1250m 1250w Amp
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
Oct 23, 2015 | Ford Cars & Trucks
What am i doin wrong with my boss radio? when i set a station when i shut the engine off i loss my settings
Sounds like your Memory +12V wire is not connected properly. If this wire does not have a constant source of power then you will lose all of your settings on your radio.
Things that may cause you to lose power through the Memory 12V wire:
  • Not hooked up properly to the battery
  • Bad battery
  • Bad ground
  • Loose wires
Boss 637UA manual
Sep 04, 2014 | BOSS AUDIO SYSTEMS BOSS 637UA - radio / CD...
2007 chevy radio weak signal. Iknow being out of range is not the problem.
it could be a loose antenna is juest come loose from the back of the radio the antenna is for long distant stations
Dec 18, 2012 | Spyder 07-11 CHEVY SILVERADO 1500 PICKUP...
I have a Bose Wave II radio. Never a problem until today. No sound from radio, CD, aux. Display works fine. Remote works. Have tried unplugging and plugging back in. Tried turning volume up, muting and...
in your boss amplifire system hardware problem in u try to mute and volume button please check aux port also if found no output sound then go boss service station there are some hardware problem
May 16, 2012 | Bose Audio Players & Recorders
My problem is how operate radio in this system give me details of this radio station
Radio will not work, unless until you plug in the headset.
Go to Settings, Reset FM, confirm with Yes.
Then go to Radio, it will automatically set the radio stations to ch01, ch02, ch03,...ch20.
That is Twenty radio channels will be set.
You can press the record button only once, to display the station names, if you press record button continuously it will start recording the program which is broadcasted in the selected radio station.
Cheers...!
Mr.Maduraikaran.
Jan 20, 2010 | Transcend T-Sonic 840 MP3 Player
Repair centers
May 31, 2006 | Boss Audio MR1500 In-Dash Marine CD...
Boss Audio MR1500 In-Dash Marine CD Receiver Logo
42 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
