Question about Refrigerators
After trip lg refrigerator model lrfc2750tt was completely defrosted. Power is on and compressor seems to be running bur has strange noise and nothing is getting cold. Help!!!!!
aborcass
  • 2651 Answers
SOURCE: Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
Posted on Apr 02, 2008
22yooper
  • 828 Answers
SOURCE: Freezer and refrigerator run but is not cold
Remove the back panel at the bottom. The refrigeration system is a sealed system and the smell would not come from it internally. Check and make sure the fan motor is running. If the fan motor (was) shorted out it would account for the reseting of the breaker. After resetting the breaker a number of times would cause the circuit in the fan motor to open allowing the compressor to run. Is the small line coming out of the compressor hot? If so replacing the defective fan motor may correct your problem.
Posted on May 03, 2008
  • 210 Answers
SOURCE: the refrigerator is not cold inside.
Do you have an error code? More than likely you have a ER FF or 6,7. The problem is you have a build up of ice that is blocking your fan. The noise was the fan hitting the ice and the ice has no blocked it completely. Defrost your unit and remove the back panel on the freezer wall. Cut off a bit of the insulation as in the picture and you should be ok. The problem will not happen again if you do this.
Sgt 48
Posted on Jun 19, 2008
  • 306 Answers
SOURCE: Appears to be stuck in auto defrost mode
Your relay that is attached to the compressor is going bad. It is called a PTC relay. The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Jan 24, 2009
  • 306 Answers
SOURCE: Refrigerator not cooling: Maytag Plus: Model MSD2756GEQ
Your PTC relay is bad and needs to be replaced. It is on the side of the compressor that connects the wires to it. Cost is about 50 maytag price or you could go with a 3 in 1 cost about 15. If you need any help get back with me and can walk you though it. Ken
Posted on Aug 16, 2009
LG GR-349SQF the freezer trips the power circuit. it started working after a few days was turned off and now its tripping power again, any ideas.Is it the defrost element.
it is a dead short so could be the element, compressor motor , start/run capacitor or bare wires
call a technician for the diagnosis
Jul 11, 2018 | LG Refrigerators
Crosley Refrigerator Nent196H BM7A81A
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
  • Jul 21, 2008 | Crosley Refrigerators
    Refrigerator does not cool
    Model number? Describe the noise and if there is any cool air at all. Need to see if the compressor is running even if you think it is by feeling the compressor APPLIANCE 911
    Jan 10, 2016 | LG Refrigerators
    When we got up this morning no power light and no sound. Outlet is good , where do we start?
    Hello Phil
    No Signs of Power
    If you did not find any signs of power before unplugging the appliance - no light, no motor, no fan sounds, the first thing to determine is whether your electrical outlet may be malfunctioning. Plug a lamp into the outlet to see if it has power. If the lamp works, then the problem lies with the refrigerator. If the lamp doesn't work, then you may have a blown fuse or circuit breaker.
    If the refrigerator is getting power but won't work, you may have a wiring, compressor, thermostat or overloaded relay issue. Unless you have specific appliance-repair skills, you may need to call in an expert.
    Insufficient Cooling
    If you've suddenly noticed that your food in the refrigerator doesn't seem as cold as it should, check a few things to figure out the problem. Check the thermostat setting to make sure that it's set properly. If the light is on but you don't hear the fan or the motor running, it's possible that the compressor isn't functioning. The problem could also lie with the thermostat, the defrost timer or the condenser fan.
    Take a look at the evaporator coils located in a panel in the freezer section of the appliance. If you find excessive frost built up over the coils, you may have a problem with the defrost timer. To fix this, you may need to turn the unit off to defrost the coils completely before the refrigerator will be able to cool properly again.
    Strange Sounds
    If you hear strange sounds, determine where they're originating. If the sounds are coming from the freezer, this could indicate an evaporator fan that's needing lubrication or replacement. If the sounds are coming from the outside back of the refrigerator, you may be dealing with the compressor, the condenser fan or the defrost timer. These parts often wear out and need replacing. If the noise is coming from the bottom of the unit, this may be a simple issue - your drain pan may be shifting. You can duct-tape the pan in place to stop the rattling.
    Best RegardsNeciforo Llanto
    Sep 21, 2013 | Refrigerators
    Refrigerator is not getting cold.
    Is the refrigerator completely dead? If so, see “It's stopped completely.” Is the thermostat knob turned to the proper setting? If not, reset it.
    Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
    The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor
    Mar 30, 2010 | LG LBN22515 Bottom Freezer Refrigerator
    Refrigerator seems cool enough,freezer not so good ice cream turns to soup,frozen foods eventually softens. Amana BRD18V1C
    First, answer these questions: Is the refrigerator completely dead? If so, see “It's stopped completely.” Is the thermostat knob turned to the proper setting? If not, reset it.
    Mar 30, 2010 | Refrigerators
    Not cool in freezer n refrigerator but power still
    If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running. First, answer these questions:
    LG Refridge LFX23961st
    LG LFX23961ST Support Manuals Warranty More LG
    I just used the link above to get the Manuals on your LG. On page 31, they did the following CYA statements...
    The defrost timer will click when the automatic defrost cycle begins and ends. The thermostat control (or refrigerator control, depending on the model) will also click when cycling on and off. Rattling noises may come from the flow of refrigerant, the water line, or items stored on top of the refrigerator .
    Your refrigerator is designed to run more efficiently to keep your food items at the desired temperature. The high efficiency compressor may cause your new refrigerator to run longer than your old one, and
    you may hear a pulsating or high-pitched sound.
    You may hear the evaporator fan motor circulating the air through the refrigerator and freezer compartments.
    As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your refrigerator.
    Contraction and expansion of the inside walls may cause a popping noise.
    Water dripping on the defrost heater during a defrost cycle may cause a sizzling sound.
    You may hear air being forced over the condenser by the condenser fan.
    You may hear water running into the drain pan during the defrost cycle.
    I bolded the statement. Sounds like you are going to have to get used to the sound.
    Semper Fi,
    Z
    Feb 01, 2018 | LG LFX23961ST Stainless Steel Bottom...
    GE refrigerator Model TFX20D Will not cool. Tested T-Stat, Defrost Timer and thermostat on coil. Still does not cool.
    • The compressor
    • The Thermostat
    • The defrost timer
    Jul 24, 2009 | Refrigerators
    A c unit goes into defrost too soon then it will possibly go out of defrost and hiss loudly current draw rises over 20 amps trips breaker model is a L G L 12463hl 7 k w wall split
    It sounds like the head pressure is to high. This is sometimes do to overcharging. The hissing noise that you hear is the liquid refrigerant dumping into the suction side. This is what a compressor does when the Head pressure is way too high. The fact that it is tripping the breaker may be to a broken suction valve in the compressor. I think it might be time for a new unit.
    Jul 03, 2008 | LG Heating & Cooling
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Marvin
    Marvin
