Question about Haier Heating & Cooling
I need a 3m ducting for my Haier model AM092ACMAA (HM-09CA03. The outlet is about 110mm and is threaded. I tried tumble drier hose but the heat from the hose countered the cool air.
  • 1554 Answers
SOURCE: air exhaust hose gets extremely warm
replace the hose with a insulated housing hose. like the ones in your attic.
though you have to buy it in 25 ft sections.
or wrap that hose in insulation.
and putting a strong fan at the end of the hose will help it **** out the heat. then you can run the hose further away.where you won't hear the additional fan.
the best is just forget the portable and sell it .
they **** energy and provide little relief.
a window or wall unit produces much better air flow and btu power.
that portable is for folks who work in a hot garage area ,not for cooling a room at all.
Posted on Jun 13, 2008
  • 24 Answers
SOURCE: exhaust hose
i could not find that model number on the haier website you can get the manuals and parts list there. you dont need the haier hose however lowes and home depot sell what im guessing is three or four inch hose that you can use say a dryer vent flex hose or alumaflex hose to connect this unit. unless you are going for the looks.
Posted on May 31, 2009
  • 4 Answers
SOURCE: i need parts for everstar portable air conditioner
Just google "Midea parts" to order online
Posted on Jul 29, 2009
SOURCE: Leaking Haier Commercial Cool air conditioner.
there are 3 drain holes in the primary pan right underneath the evaporator that need to be clean with a pipe cleaner or a wire of somekind and there is also a secondary drain behind it that will work only if the unit is 100% level. To access the primary drain pan you have to take all the screws of the back cover 5 on each side and 3 in the center above the electric cord and behind the air filter and only then will you be able to see these very small holes. Use a flashlight to make sure. Have fun!Reply
Posted on Jul 07, 2010
  • 8197 Answers
SOURCE: My Haier HPRD12xC7 is not heating, only blowing
Check the flame sensor. Its a little rod that sticks out into the flame of the furnace. Shut off the power to the furnace and lightly scrape or sand it, then see how it works.
Posted on Dec 07, 2010
Gas dryer?
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
Best of luck...
May 18, 2015 | Dryers
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
Bosch Exxcel Drier WTA4107GB/01 not heating up. Is there a reset button
yes and here is the thread on it:
Jan 11, 2011 | Bosch Dryers
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at TEL 08455218000
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
Drier tumbles but will not heat up, checked for
check you legs on the plug it might have a bad leg (prong) or you need a new pig.
Jun 05, 2009 | Kenmore Dryers
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
hi did u check the hoses from the pump and check the pump for any obstructions.
Feb 14, 2009 | AEG Washing Machines
Tumble drier works but wont heat
Hi can you tell me what make model etc.... I then can tell you what is wrong!
Dec 28, 2008 | Hotpoint Dryers
Tumble dry is heating but takes forever to dry
check your air exhaust (including the lint filter) from the air duct connector (remove duct if necessary) on back of dryer to the exterior of the building. Somewhere, there must be air blockage.
Jun 17, 2007 | Creda IWD12 Front Load Washer / Dryer
Heating & Cooling Logo
65 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
