Question about HP Officejet 5610 All-In-One InkJet Printer
I have the following message: Cartridge error...Remove and re-insert cartridge on left" I have replaced the cartridge with two new HP cartridges. Still not printing. Any ideas?
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Your black cartridge must be replaced with a new one or an older refilled cartridge that you can easy refill it by this way
http://www.youtube.com/watch?v=II9gpIXs_lE
Posted on Oct 30, 2010
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
Apr 03, 2011 | HP Office Equipment & Supplies
10.1000 supply memory error
hi,
10.00X is the error code displayed when
  • Cartridge is not installed correctly
  • Use of refilled cartridges
in your case x is 0 which means that black color cartridge had a problem
problem may persist in slot holding black cartridge and /or in the cartridge
just do steps below
solution 1: check all cartridges are in right slot it is better to remove and fix it again
solution 2:
clean the surface of metal contacts with lint-free cloth
the image below will show metal contacts
solution 3: Insert the problem print cartridge into a different slot
Follow these steps to determine if the print cartridge or the slot it sits in is causing the error.
  1. Open the print cartridge door completely.
  2. Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
  3. Remove one of the non problem print cartridges from its slot.
  4. Install the problem print cartridge into the empty slot.
  5. Install the other print cartridge into the slot of the problem print cartridge.
  6. Close the print cartridge drawer completely.
  7. Close the front access door completely.
  • If the error message persists , replace the problem cartridge with new one(problem is in cartridge)
  • If the error message is gone , contact HP to troubleshoot a faulty slot.
regards,
cseian
Dec 16, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
10.00.00 supply memory error
The 10.00.00 SUPPLIES MEMORY ERROR is based on the e-label. To clear the error, do the following:
NOTE: If the error occurs, it should appear at beginning of life, causing the error message after first installing the cartridge.
Turn the printer off and on to clear the message.
Put in the old catridge and see what happens.
If OK put in the new one again.
Verify that the print cartridge is a genuine HP cartridge.
Check that the E-label reader is functioning correctly.
Check that there is contact between the E-label chip on the print cartridge and the E-label reader on the printer.
To verify this contact, insert a new print cartridge.
Remove it again.
Check for scratches on the e-label chip and on the cartridge.
If contact is being made, replace the print cartridge (part number: Q2610A).
If contact is not being made, check the toner guides to see if they are in the proper position, or that the cartridge is not damaged.
If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
Turn the printer on again.
If the error does not clear, turn the printer off and remove tray 3.
Turn the printer on and verify if the error clears.
HP has recently discovered that a 10.00.00 Supplies Memory Error can occur when Tray 3 is faulty.
May 06, 2010 | HP LaserJet 2420 Printer
Cartridge Errror
How to Reset an HP Inkjet Cartridge
Hi there
Instructions
Things You'll Need:
Adhesive tape
HP inkjet cartridge can be refilled easily, getting it to work again in the printer is another matter.
The contacts on the back of the cartridge are programmed to read the ink level, but they don't reset for the printer just because you add more ink.
You must get the printer to recognize the cartridge as new.
You can do this easily if you have two other old cartridges, or you can manipulate the contacts on the refilled cartridge.
Step 1
Insert the cartridge you refilled into the HP Printer.
Have the printer print an alignment page, thus recognizing the cartridge. The printer will still read the ink level as where it was before you refilled it.
Step 2
Remove the cartridge from the printer and replace it with another old cartridge.
Have the printer print an alignment page with this cartridge so it recognizes it as a different cartridge from the first one.
Step 3
Replace the second cartridge with a third one and run the same alignment page.
Because the printer only retains the memory of two Print Cartridges, it will erase the memory of the first (refilled) cartridge.
Step 4
Insert the refilled cartridge into the printer.
The printer will now recognize the cartridge as being full.
Next Steps
Step 1
Tape over the contact squares on the top left corner of the cartridge's contacts. Insert the cartridge into the printer and run an alignment page. Ignore any messages that might appear saying there is a problem with the cartridge.
Step 2
Take the cartridge out of the printer. Remove the tape from the left corner and tape over the contact squares on the top right corner. Place the cartridge backs in and run another alignment page.
Step 3
Remove and reinsert the cartridge, this time with no tape on any of the contacts. Check to see if the printer recognizes the cartridge as being full.
Step 4
Repeat the above steps if the cartridge is still shown as being empty.
This time, use the bottom corner contact squares instead of the top ones. If you are still unable to reset the cartridges, using multiple cartridges is likely the only way to do it.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); All I ask is to call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | HP PSC 2355 All-In-One InkJet Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
    OR
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Error code 1203
    To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
    Aug 20, 2007 | Lexmark P315 InkJet Photo Printer
    HP Officejet 5610 All-In-One InkJet Printer Logo
    109 people viewed this question
    Seeker5211
    Seeker5211
