Question about JVC KD-SX650 CD Player
I installed my JVC KD-SX650 and it works but it will not keep the radio station settings and the clock setting once I turn my truck off and back on again, what could be the problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • JVC Master
  • 2,226 Answers
You need to make sure the yellow wire is going to a constant power source.. the yellow wire controls the clock and preset setting memory.
Posted on Jul 14, 2010
KD-R805 does not store clock settings
first of all you must be able to check out a few things like do you know how to set your clock for the kd-r805. if you can check to see if you set your clock and set your presets for radio station to be saved. set your clock and set all your station presets once done. Once you have done that turn off the car wait about 60 seconds then turn your car back on to power up the radio and see what happens to your clock and presets . if your clock and presets are not still saved this means that who ever did the radio install has the yellow memory wire connected to switch ignition and not constant battery wire from the factory harness. have someone fix it. If the clock and station presets are still save then it was that you don't know how to program the clock.. how to program your model radios clock .......
STEP 1 : TURN ON POWER TO RADIO
STEP 2 : PRESS AND HOLD MENU UNTIL THE MAIN MENU IS SHOW ON RADIO SCREEN PRESS AND TURN THE VOLUME KNOB TO MOVE THROUGH THE MENU ( YOU MUST CANCEL THE DEMO FIRST TO BE ABLE TO PROGRAM THE CLOCK).
STEP 3: TO SET THE CLOCK SELECT THE CLOCK IN THE MAIN MENU SETTING ROTATE THE VOLUME KNOB AND PRESS IT ONCE TO SELECT THE CLOCK SETTING.
STEP 4: ADJUST THE HOURS AND THEN PRESS THE VOLUME KNOB TO MOVE ON TO THE SECONDS .
STEP 5 : THEN SELECT 12HR OR 24HR TO BE DISPLAYED
STEP 6 : RETURN TO THE PREVIOUS MENU BY HITTING (BACK BUTTON)
STEP :7 TO EXIT SETUP OR MENU HIT THE (MENU BUTTON)
radiorepair@www.windowtintingin239.com
Oct 26, 2013 | Car Audio & Video
I installed my JVC KD-SX650 and it works but when i turn my truck off it loses the radio station and clock settings, what could be the problem?
There should be a yellow "accessories" wire that controls the memory to the radio. If it is not properly hooked up, the radio will reset every time you turn off the ignition.
NOTE: It might be a different color than yellow, but this is the most common
Jul 13, 2010 | Car Audio & Video
Need to reset the clock on my JVC KD-SX650
Does this unit have RDS on it? if so switch it on and it should set your clock for you
Feb 03, 2010 | JVC KD-SX650 CD Player
HOW DO I SET THE CLOCK
I've had two Pioneer CD players and they both were set the same way. Turn it off then press and hold the AUDIO button if it has one. Then keep pressing it until it gets to the clock. I think on mine the hour starts flashing. When your done just turn it back on. == Answer == I had this problem too. In the far right corner is the "A" (Audio) button. Turn the stereo off and hold the "A" button until the clock comes on. The hour will be blinking. Use the up and down "Select" keys to set that. Then use the right "Select" key to switch to the minutes. Use the up and down keys to set the minutes. Push the "A" button when you're done. My stereo is older than yours but this is what someone who has one like yours told me to try and it worked
Jul 15, 2009 | JVC KD-SX650 CD Player
Change Time
Setting the minutes involves the same steps as setting the hours. You press and hold the "Select" button for a few seconds until the screen reads: "Clock H", "Clock M", "SCM Link", "Level", "Area" or "Line In". To set the minutes, push the "Track Up/Track Down" button until "Clock M" is highlighted on the screen. Once "Clock M" is on the screen, you turn the volume up or down to set the minutes. Once the hours and minutes are set, hit the "Select" button again and the clock will start. Hope this helps...
Sep 03, 2008 | JVC KD-SX650 CD Player
KD sx980
http://resources.jvc.com/Resources/00/00/97/49690ien.pdf
try here
Jun 23, 2008 | JVC KD-SX650 CD Player
EXAD KD - AR5000 Programming
Do you also lose your clock and radio station presets?
Nov 08, 2007 | JVC Arsenal KD-AR5000 CD Player
My JVC KD-SX650
get a good service manual for your car that shows the wiring for the stereo plug. match up the wires to your JVC's wires (solder tie wire-to-wire behind the car's connector)
May 26, 2007 | JVC KD-SX650 CD Player
JVC KD-SX650 CD Player Logo
249 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
