Question about KitchenAid KEBC278 Electric Double Oven
We started the oven clean cycle for the top oven which takes about (3) hours, after about (2) hours the power when off completely only on the oven. The door is still locked , I when and tried the breaker once on & off and still nothing .
    President:
  • 1,891 Answers
The oven needs to reheat to self clean. / try to run a new clean cycle and it should re open and end . mm
Posted on Jul 15, 2010
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    How does the self-clean feature work on a Frigidaire CFEF366EMB model?
    Hi Beverly,
    I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
    -To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
    -Next you will press the "Clean" button, and the display will show "---".
    -Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
    -The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
    -"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
    When the self-clean cycle has completed:
    -The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
    -Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
    -If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
    -When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
    -Best Regards-
    Jan 23, 2014 | Frigidaire Ovens
    How do i operate the self cleaning function
    Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
    Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
    When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
    If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
    Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
    I have the self cleaning feature and put it on medium clean which takes 3 hours. This was 4 hours ago and the oven is still hot and the door won't open
    This is normal, don't panic! You have to let it cool off. Cool down can take up to 2 hours (after the clean cycle is done). The companies do not factor in cool down time into the length of the clean cycle. The oven reaches about 750 to 800 degrees during self clean so give it some time.
    Jun 12, 2010 | Maytag MEW5527B Electric Single Oven
    I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
    you might try the following, although it is the instructions for an old model, it may be relevant;
    "The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
    A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
    I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
    Nov 18, 2009 | Ovens
    My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
    You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
    Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
    How do I use the self cleaning option for my oven?
    First remove the rack, because the extreme heat will tarnish the racks and the shinny coating will will no longer be there, press the cleaning button, and leave it this cycle will take approx.. 3-1/2 to 4- hours to clean and cool down will take another hour, it will tell you that it is cooling and also the the cleaning is complete. so let the cycle complete and all you will need to do is wipe off some residue once it is complete.
    Nov 14, 2009 | GE Ovens
    I started my oven on ''clean'' -- how long should this take?
    Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
    http://www.frigidaire.com/support/manuals.asp
    Mar 20, 2009 | Frigidaire 30 in. Electric Gallery Series...
    Self-cleaning feature of GE Built-In Oven does not work
    Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
    Jun 26, 2008 | Ovens
    KitchenAid KEBC278 Electric Double Oven Logo
    101 people viewed this question
    Top KitchenAid Ovens Experts
    Marvin
    Marvin
    Craig Butler
    Craig Butler
    Jim Goldsmith
    Jim Goldsmith
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
