Question about GE JGRP17 Gas Single Oven
Gas in oven wont come on,burners and broiler ok, oven light comes on but oven won't come on,electrical connections ok, checked
    President:
  • 1,891 Answers
This is a 2 burner oven with 2 ignitors . the bake ignitor is too weak to light the burner . replace it and the bake should work properly .. mm
Posted on Jul 16, 2010
Oven won't light
ck thermal coupling see if its to far from pilot light or burnt out
Feb 18, 2012 | General Ovens
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Oven wont light
Check the amp draw on the ignitor. If 2.9 amps or less, replace the ignitor. If 2.9 amps or more, replace the gas safety valve.
Aug 02, 2009 | GE Ovens
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
GE JGRP17 Gas Single Oven Logo
402 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
