Question about OKI B6500 Led Printer
OKI B6500 has ID mismatch error....need to know how to fix. Thank you
  • OKI Master
  • 825 Answers
Basically the machine does not recognise the image drum. You maybe using the Xerox equivalent which of course wont work. Replace the drum with an OKI one and it should work even though its really a Xerox printer.
Posted on Dec 07, 2017
markzbylut
  • 64 Answers
SOURCE: I have a Oki b6500. Replaced the fuser. How to
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
Posted on May 20, 2010
  • 20 Answers
SOURCE: Error 950.10 NVRAM mismatch. how do I fix or
The way that I have found to fix this problem is to replace the logic board but when you do that, this is where the NVRAM mismatch comes in. Once you change the logic you also have to change the display op panel. That is what is giving you this error. You must change logic and op panel at same time and it will not give that error.
Posted on Apr 13, 2010
Testimonial: "Thank you very much for all your help"
  • 3 Answers
SOURCE: service error 02
SE 02
: Software Exception
Posted on Sep 22, 2010
SOURCE: OKI B6500 service error 03
hola buenos días tengo una impresora oki B6500 se le cambio el tonner despues del cambio manda el mensaje de tonner bajo que debo de hacer para quiatar el error que marca
Posted on Jan 11, 2011
ZJLimited
  • 17970 Answers
SOURCE: we have a service error
try to check in this link, or send one email : okic=errorcodes
Posted on Mar 29, 2011
How fix oki B6500 loading display error
gravity reset. seriously, hold it about 9" off the floor and drop it evenly. repeat if not fixed. this was in an oki tech bulletin. there is a ribbon cable deep inside that comes unseated. unless you want to take the ENTIRE printer apart perform the steps above. :)
Aug 19, 2014 | OKI Office Equipment & Supplies
Oki b6500 is stuck on initializing
the main board needs to be replaced
Apr 21, 2014 | OKI B6500 Led Printer
Impresora oki b6500
oki b6500 code flash error firmware upgrade que puedo hacer
Jan 15, 2014 | OKI B6500 Led Printer
NVRAM Failure oki
OKI provides live customer support 24/7 at 1-800-OKI-DATA (1-800-654-3282) in addition to a live chat feature during "normal" business hours. Visit www.okidata.com and look for the red "chat" button on the right. The skilled technical support staff should be able to fix your problem promptly.
Jan 25, 2013 | OKI B6500 Led Printer
Oki b6500 new printer has error code 03
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Jun 15, 2011 | OKI B6500 Led Printer
Sep 29, 2010 | OKI B6500 Led Printer
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
Service error 02
SE 02
Jan 12, 2010 | OKI B6500 Led Printer
OKI B6500 Led Printer Logo
2,642 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
