Question about Farenheit MD-1040CMX Car DVD Player
I have a model xm 1040 and the flip down mount broke what can i do
I was riding my arctic cat 580 ext efi 1995 .. When I hint a bump and the rear suspention dropped ... Flat ... How can I raze it back to where ther suspention is suppost to be at .. What happen . Why did...
It sounds like you either broke a suspension support, or the shock has collapsed. It could also be that you broke a spring. Most likely a suspension mounting point has broken. You are going to have to flip it on it's side so you can inspect the entire suspension mounting assembly. Without a full inspection it could be speculated all day and not come up with an answer.
Mar 08, 2015 | ATVs
Have a 2007 Jeep Commander. Sirius is intermittent and will flip over to FM frequently
First question is if you ever spilled a soft drink into the radio such that the AM/FM/SAT switch gets sticky?
2nd, do you have any way to pull-out the radio and borrow a magnetic-mount Sirius antenna to temporarily test and see if the antenna on the vehicle is bad?
If passing the first two tests, then it's likely the whole radio unit has to be replaced with a model from a similar year. Actually, the audio quality you get from an XM Onyx will be much better than the Sirius radio in the Chrysler vehicles, and you can just use the AUX input on the radio for playback.
Sep 11, 2014 | Sirius Satellite Radio Receiver
Will not accept dvd
you've got a bad player. the motor inside that plls in the disk and spits it back out is toast. replace the dvd player
Feb 16, 2010 | Nesa Vision NESA NSCM-1040 Overhead Flip...
The door flips down for loading. The cables
bottom interior part of the dryer has two small holes the spring attatches to
Aug 17, 2009 | Kenmore Dryers
Flip down monitor
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Feb 01, 2009 | Nesa Vision NESA NSCM-1040 Overhead Flip...
Old xm reciever not working with new car sterio
yes you will have to upgrade to a new reciever , the older sony xm receivers will not work on the newer model sonys
Aug 13, 2008 | Car Audio & Video
The movies are playing upside down
If you press and hold the mode button it will cycle through 4:3 , 16:9, after 16:9 it should flip over.
Thanks
Dec 16, 2007 | Polaroid PDM-1040 Portable DVD Player
Farenheit MD-1040CMX Car DVD Player Logo
59 people viewed this question
Top Farenheit Car Audio & Video Experts
Martin Clarke
Martin Clarke
afairman1927
Are you a Farenheit Car Audio and Video Expert? Answer questions, earn points and help others
