Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
New Control Unit not working
I started having problems in January when the Control module would not reset, even after we powered down and repowered the dishwasher. I bought another Control module in March, the dishwasher worked again for about a month, and then went on the blink. Now the Control module doesn't light up at all, like it doesn't have power, and the unit doesn't work again. Is there a problem with the motor or power unit?
    Genius:
  • 1,075 Answers
I think this machine need a test run on it,i suspect a problem in the circuit and it might have blown the board again.adrian,,
Posted on Jul 14, 2010
Resetting the power windows and convertible top on a 2004 Volkswagon Beetle
GET INSIDE THE CAR AND CLOSE ALL DOORS.SWITCH IGNITION ON.USE BOTH UR HANDS TO {AT THE SAME TIME} LIFT ALL 4 WINDOWS UPHOLD THE BUTTONS UP UNTILL ALL WINDOWS ARE UP.RELEASE AND HOLD UP AGAIN.REPEAT AT LEAST 4 TIME .THEN U PUSH ALL 4 BUTTONS DOWN!!!HOLD THERE UNTIL ALL 4 WINDOWS ARE DOWN . REPEAT STEP AT LEAST 4 TIMES!!!SWITCH IGNITION OFF AND ON.U NOW HAVE THE COMFORT BACK!!!!LET ME KNOW IF U STILL HAVE ANY PROBLEMS!!
Apr 06, 2014 | 2004 Volkswagen New Beetle Convertible
I have WGT624 v2 used for years and in a pretty good condition. Unfortunately, it suddenly doesn't work recently. No internet connection at all. The power LED light keep blinking and the color change...
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | NetGear WGT624 Wireless Router
Kitchenaid kud101tj "cancel drain" light and "Rinse Only" lights are falhing and DW won't start???
Don't know if this will help, but when I had problems with my control panel (lights blinked and nothing worked) I fixed it by disconnecting the power completly from the dishwasher at the fuse box. Leave it off 10 or 15 minutes and then repower. That reset mine and it worked again...has happened several times and each time I could fix it by cutting the power. If that doesn't work, you may need a new control panel.
Sep 11, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Unit re-powers after being turned off. Only removing the battery gets it to shut down without re-powering.
When it repowers,is it because when you hold the unit,it repowers? Then once it shuts down put the unit down.
Feb 15, 2010 | Focus Enhancement FireStore FS-4Pro HD...
I was using the FM modulator to listen to the MP3 player. I shut the unit down and kept the power cord plugged in to charge the battery. When I went to use the MP3 player again, the FM modulator wasn't...
Ok,
So s the FM modulator working or not? If everything is working then anything could have been the culprit. These units work much like computers and it's possible for glitches/freezes and even more serious things to occur being they are quite complex units. Has this problem occurred often? If so how old is the unit and the modulator and how long have you had this problem? Once I have more information I will be happy to assist you further.
Thank you,
Lee
Dec 04, 2009 | Garmin nuvi 765T GPS Receiver
My compressor will not start.
There are a few more things to try, in the control unit of the AC there is Cold Control/Freeze Switch. Take down the control unit (inside unit, remove inner shroud) and remove the cover, The freeze control is plugged into the blue plug on the board. Remove the plug and install a jumper wire in its place. Does the compressor come on? If so, you have a bad freeze control. If not, then we need to check and see if your AC power module is sending power to the Compressor. Check power across the relay in the control unit, Black to Blue. If the blue wire is hot, then you need to go upstairs to the top of the compressor and check the thermal overload. If the blue wire is not hot, the comfort control center may not be sending a signal to turn the compressor on. If it is not, do a reset of the CCC. For a five button system, turn the tstat off and hold down the Mode and Zone buttons simultaneously. While holding them down, turn the CCC on and hold the buttons until FF appears on the screen. Release the buttons and try the AC.
Four button reset -
Depress MODE switch to activate annunciator light.
Simultaneously depress the bottom two buttons
(temperature UP and DOWN) and hold.
While holding these buttons down, depress the
MODE button once and release.
Release the two buttons previously held down.
Depress the MODE button once again.
At this time the light should extinguish, and the mode
should register “OFF”. If not, repeat Steps 2 through
6.
Retest system ensuring that all functions are present
and operational.
Hope this helps,
Jeff
Rate me please!!
Jun 28, 2009 | Dometic 57915531 Air Conditioner
Display scramled, light works, timer counts down but unit doesnt
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Assuming your model number is DMT2420 (since that's the category under which your query was posted) then you likely also need a new secondary interlock (bottom door switch).
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you have a different model, please reply back or contact me directly with the correct model.
If you want to send your control panel assembly in for repair, you can note on the repair form that you need a new door switch and we'll throw one in at no charge.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 15, 2009 | Dacor DMT2420 1200 Watts Microwave Oven
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
Breadman pro stopped working
it is defenitely a power problem some of them have internal resets and you should check. also you could have a malfunction of the power supply module on the circuit main board. if there is no reset then i suggest that you take it to a aplliance repair shop and have a tech replace the circuit module.
Aug 30, 2008 | Breadman Pro Dual Bread Maker
Kenwood Audio Amp KA-5040R - remains in standby
Hi, Lost sole, i HOPE YOU FIND IT
Minwhile, when it works to know if you have a cold solder joint, hit the unit on the top or buttom to see if it stop working, mostlikly it will,
To fix this you must unplug the unit open the bottom cover, and solder joint that look broken off, moslity on the output stage or power supply.
What I think happening is when the unit heat's up the joint expand and doesn't do contact no more.
Another problem that this may be is a bad power supply, cap's, this can be check by freezing them to see if the unit starts again.
This is little trick of the trade, I hope this help
What About Bob
Feb 09, 2008 | Audio Players & Recorders
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
119 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
