Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My cub cadet 2130 will not start. Battery is ok. I turn the key and nothing no clicking,the lights come on and that is it. It was running and I turned it off to take a break then it would not start.
  • 246 Answers
SOURCE: cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
  • 7 Answers
SOURCE: my riding cub cadet won't start. key clicks,
jump start it from your car, the battery is dead
Posted on Jun 08, 2009
  • 202 Answers
SOURCE: Cub cadet 2130 engine starts
there is a switch under the seat that senses if you are on the mower or not. check it, make sure it's plugged up try replacing it. if it does not "see" someone on the seat it will shut down
Posted on Jul 14, 2009
  • 202 Answers
SOURCE: I have a Cub Cadet 2135 and when I turn the key
possibly a bad starter, check and see if you can turn the engine by hand after you remove the spark plugs( dont want it to accidently start). if it does try a straight cable+ side to the starter terminal. if it turns then you may have a bad solenoid.
Posted on Jul 23, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: cub cadet 2135 wont start
check for a fuse behind the ignition
it might be blown
then i would check the starter solenoid
if you put a screwdriver accross the bolts that hold the wire from the starter and ignition switch and it tries to start there's ur problem.
Posted on Jul 30, 2009
Testimonial: "So after borrowing the neighbor's tractor for a month, I finally checked the fuse and YOU WERE ABSOLUTELY RIGHT!!!! Blown fuse! You're BRILLIANT! Tnx!"
Cub Cadet won't turnover.
Try boosting it directly from the battery and see if it will turn over now. I had that problem and found my cable on the ground side had corrosion in it. I put new cables on and is ok now.
Jun 18, 2018 | Cub Cadet Garden
Cub cadet lawn tractor not starting?
There are several safety switches located on the tractor that could be giving you the problem. The starter solenoid may be bad as well.
Jul 10, 2016 | Cub Cadet Garden
Cub cadet trouble shooting
Check the "engage" switch. If it is shorted, it will drain the battery.
Jul 07, 2014 | Garden
Cub Cadet ZTR will not start
Is the blade engagement off? If that is ok, does the solenoid even click when you put the key to start position? If the solenoid doesn't even click check the battery connections and make sure they are good and clean. If the connections are good, are you sure the new battery is fully charged. If the battery sat around for a long time in the store it could need charged. If all that is good and then you don't get the starter solenoid to click when you put the key in start position, then it is either the seat switch, parking brake switch, handle switches, or mower engage switch keeping it from starting. If all that is ok maybe you have a bad starter solenoid. Please rate my answer so I am rewarded points for it.
Jan 30, 2012 | Cub Cadet Garden
PTO clutch will not engage.
first start by turning ign on,then switch on the pto switch to on. you should hear a click in the clutch. if not use a twelve volt test light,hook aligator end to a good groundand the needle end,,,touch to the pto switchharness to see if you have power to the pto switch. if you don"t, you have to go checkfurther to your power source,(battery) if you do have power there check to see if you have power at the plugin at the end of your wire harness, just at the beginning of where your cluch connects up. you can test you clutch by conneting a test wire from positive on your battery to one of the terminals on your clutch and the other terminal to ground . It willengage if it is good .using either wire is ok as all it will be doing is completing a circuit. hope this helps.
Sep 24, 2009 | Oregon Scientific Electric PTO Clutch for...
REMOVE PARKING BRAKE ENGINE STALLS
i have a cub cadet 2130 2000 seris but it quits when i rekwase the brake pedal
May 03, 2009 | Oregon Scientific Oregon Gator Mulcher...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
98 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
