Question about Maytag MER5775Q Electric Kitchen Range
Oven does not heat up past 255 degrees - Maytag MER5775Q Electric Kitchen Range
    President:
  • 1,561 Answers
It sounds like your thermostat. Is there a sensor or probe visible at the top of your oven on the inside? Check to see it is clean and not covered with gunk.
Try cleaning that probe/sensor with some fine sand paper and make sure that it is secure in place.
Take care.
Posted on Jul 14, 2010
  • wheaton_d Jul 14, 2010
    I have replaced the thermostat, but have the same results.
  • Sulaimon Jimoh Olayemi Jul 14, 2010
    remove the knob and loosen the retaining screws on the back, using a
    Phillips screwdriver. Turn the center disk toward "Hotter" or "Raise" to
    increase the temperature, or toward "Cooler" or "Lower" to decrease the
    temperature. Tighten the screws, reinstall the knob and test the oven.
    Readjust the knob if necessary.
    If the problem still persist, you will need to replace the igniter, it most likely bad that is why the oven is not heating properly.
    Take care.
Oven will not heat past 195 degrees
Check and see if you have blown a fuse which is usually in the top of the stove in the area of the clock if you have one. You usually can get in from the back of the stove at the top.
Jan 03, 2015 | Maytag Gemini 30" Self-Cleaning...
Used self cleaning and now wont heat past 180 degrees
Sounds like you burned out the oven ignitor. A simple fix with a few tools and common sense.
Dec 13, 2013 | Whirlpool GGG388LXS Stainless Steel Double...
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
My oven wont heat up past 200 degrees. Suggestions
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Mar 04, 2011 | GE Monogram® ZMC1095BFBB /...
My oven won't heat above 255 degrees. just curious what the problem might be.
You do not state if this is in centigrade or fahrenheit.
If it is centigrade, then it will not reach more than this if it is a domestic oven, if fahrenheit, then it should get hotter, so I would suspect a faulty oven thermostat as being the cause of the problem
Jan 05, 2011 | Ovens
Our oven is not heating up past 150 degrees. The
The element will have to be replaced if there is no power going to it.
Jul 20, 2009 | GE Spectra JBP84 Electric Kitchen Range
Why won't my Maytag electric oven heat past 210 degrees?
Hello could be oven thermostat,when you are sure of the part you need check out www.appliancepartssolutions.com cheep parts!
good luck
Apr 08, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
Maytag MER5775Q Electric Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
