Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
My Jenn Air JCD2389GTB side-by-side refrigerator suddenly stopped working.
Both the freezer and refigeration sides are not circulating cold air.
I just lost a lot a food.
Any thoughts?
Thanks Zan
  • zannbruce Jul 14, 2010
    Thank you for your help. I called Jenn-Aire and was advised that this model is on the Recall list.
    The recall relates to the Thermostat.
    I was told that the relay may catch fire and therefore
    there is a safety issue related to this item.
    Zan
  • 4,066 Answers
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Posted on Jul 13, 2010
Jenn air refrigerator jcd2389ges freezes fridge
Bea, try this. UNPLUG the refrigerator for 12 hours and keep the fridge and freezer doors open. You might lose some food. NOW you will find some water under the fridge. clean that and now power up the fridge. Make sure you hear the motor working. Your fridge will start cooling. Keep at recommended temp.
Mar 07, 2014 | Jenn-Air JCD2389G Side by Side...
Jenn-air refrigerator not freezing or making ice
Before you go crazy just defrost the unit over night and then turn it back on. Possible e that the evaporator froze up due to the open door..Let it stabilize for at least a day and then check to see if all is copacetic.
Sep 14, 2017 | Jenn-Air Refrigerators
Refrigerators Problem
Make sure coils on back of unit are clean and not touching wall. Are doors closing and sealing with magnetic strip fully? Has some one changed settings without you knowing?
Dec 04, 2011 | Jenn-Air Refrigerators
First refrigerator stopped cooling, next freezer. Seemed like it was trying to defrost but their was lots of ice built up on coils. Jen-Air side by side, counter depth model number JCB2388ARB.
Causes of ice build up on coils:
Not enough freon (leak). Coil defrost heater not working (Coils on all freezers freeze up, but you should not notice). Coil defrost timer not working. Compressor thermostat not working (or end fell out of proper location).
:o).
Jun 04, 2011 | Jenn-Air JCB2388G Side by Side...
My refrigerator is MyTag, Freeze side ok, but cod side not working, why?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Jenn-Air JCD2389G Side by Side...
Hi, I have a jenn Air side by side fridge, and it keeps freezing everything. How can it be fixed?
your cooling temp is too low i take it you have decreased the thermis in this case the thermis is not working and will need replacing
best of luck
please remember to rank my reply
Dec 01, 2010 | Jenn-Air JCD2389G Side by Side...
JCD2290HES Side by Side Refrigerator: my jenn air side by side is freezing everything an...
i have the same problem i clean the coils and work for two weeks and now is freezing need solution thanks
May 16, 2010 | Jenn-Air JCD2290HES Side by Side...
Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
Jun 07, 2009 | Jenn-Air JSD2789GES Side by Side...
JENN-AIR Freezer and refrigerator not cooling
good day,
hope this link below will solve your problem.
ref
Jan 10, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389GEB side by side
the clicking noise is the motor overload. have a service tech check for a freon leak.
Sep 24, 2007 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
1,021 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
