Question about Cooktops
My stove is making strange clicking noises. please help.
My stove is a gas range and it has an electric ignition system. when i was cleaning it, it started to make these clicking noises that sounded an awful lot like the ignition sound you hear when the stove is being lit. when i unplugged the stove, they stoped, but when the stove was plugged in again they started right back up again. then i fiddled with the ignition- knob-thing and it sopped for a minute or two and then continued with this noise. is it dangerous? whats going on and how do i fix it?
    Novelist:
  • 112 Answers
It sounds like the ignition knob is stuck in the "ignitor" position. Try taking it off, clean it and adjust it. If that doesn't work, it will have to be replaced with a new one. If yu leave it alone, it will probably wear itself out. Just make sure that the gas valves on the stove are in the off position so that they don't accidentally light on their own. Good luck
Posted on Jul 16, 2010
My Jenn Air Electric stove is making a clicking noise. When I put my hand on one of the cook top knobs I can actually feel a vibration when the click occurs. What is this?
Gas stove? LP? It is probably the electric spark ignitor. Many times when you clean the stove top water from the sponge gets below. The water droplets (align mysteriously) make the connection between the wires, and the stove thinks it's supposed to be igniting. When the water evaporates, the switch will work fine again & the clicking should only occur when igniting & then backed off.
This happened to me once before.
Nov 21, 2010 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
Have trouble starting gas burners on nobel fse90-1. Is there a trick to starting the burners. I need serious help before I go mad!
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | Cooktops
Ignitors clicking
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
May 10, 2010 | Thermador SGS36GS Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
Spark ignitors went on stove top
Jan 09, 2010 | Whirlpool SCS3014LS Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Jen-Air Gas range Igniter keeps clicking but not starting fire
01/26/09 My wife decided to give our Jenn-Air a good cleaning. With lot's of soapy warm water she pulled the knobs off and washed under each of them not realizing excess water was now running down the inside of each control knob shaft. The igniter immediately began clicking away as it was being shorted by the conductance of the water now inside of the switch. I had to remove the cover (2-screws) to access the control switches but that is all I needed to do do in order to have clear access. Using her hair dryer it took about 5 minutes of warm air blowing down each of the shafts until the water evaporated and the clicking stopped. Wahla. The old Jenn-Air is back to working order again.
Sep 22, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Cooktops Logo
1,143 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
