Question about Panasonic DMR-EX85EB-S DVD Recorder/HDD Recorder
Panasonic DMREX85EBS recorder upscaling problems
I have a Panasonic DMREX85EBS that says it can upscale to 10801 720p , I have a hdmi cable connected but every DVD or recording I play it only ever says it is at 576p. Can anybody tell me what I am doing wrong?
  • paul_hickey1 Aug 18, 2010
    Thanks for that Cindy I have done that and it seems to be working, but can anyone tell me what is the difference between 10801 720p and what is the best to use?
  • Panasonic Master
  • 5,679 Answers
Check the HDMI settings and your TV specifications. Press Functions on your remote and go to Display (up/down arrows). Press Enter. Go to Connections and again Enter. Then HDMI settings and Enter. Look for HDMI video settings. If the setting is automatic, the unit sends the output it believes is best for the TV. You will notice that the compatible video outputs are the only ones available for selection. (A new cable may be worth testing.)
I hope this helps.
Posted on Jul 13, 2010
    Thank you Cindy that worked, but could anyone tell me what is the difference between 10801 720p and what is best to use.
  • Cindy Wells Aug 18, 2010
    720 means that 720 lines (horizontal) of pixels have data provided. On a TV with 720 resolution, the tv can have between 720 and 1050 lines of pixels built into the array. Upconverting attempts to add interpolation of the signal and fill in the other 360 lines of data to give 1080 pixels. The p or i means progressive or interlaced (which is how the screen refreshes).
    A TV with 1080 resolution has at least 1080 lines of pixels.
    I hope this helps.
I have a 50" Emerson and I want to hook up the Wii system. The problem is that our local cable company is using all the a/v cables available.
You can always get a switcher and select what device goes to the tv without ever changing any cables again.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jan 04, 2015 | Nintendo Wii Video Game Consoles & Games
I have a pioneer vsx-30 with hdcp error on the face i see it when a scientific atlantic cable box is connected through a componet connection
Component cables don't have the ability to carry decrypted HD info.
HDCP is "High Definition Copy Protection"...In theory, it prevents you from running the HDMI cable out of your receiver, and into a recording device, thereby recording HD content without a license for it.
HDCP handshaking is done between devices that run HDMI, or DVI.
If you're running component from your Cable box, and then HDMI out to your TV, then the content you're carrying from the Cable box may not be getting decrypted properly when it gets upscaled onto the HDMI port from Component.
IT could also simply be that you're using an HDMI 1.1 or HDMI 1.2 cable, which may not be able to carry the high bandwidth stream of your Receiver and TV.
Please be sure that all HDMI devices can support the same HDMI version, and also be sure your HDMI cable is labled "HDMI 1.x compliant". . .e.g. if your TV and Amp support HDMI 1.2, make sure you're also using an HDMI 1.2 Cable.
Apr 21, 2011 | Pioneer VSX-305 Receiver
Have a yamaha reciever with 2 hdmi inputs and 1 output aong with upscaling of composite inputs. when i connect my blu ray player through the reciever it will not appear on the tv. if i connect the blu ray...
Depending on the model of your Yamaha, you will have to go into setup of it. In there go to the input settings and select what should be done. Example: for DVD select HDMI as input. I take it you are using the HDMI out as well? This is what I had to do on my RX-V3800n
Hope this helps.
Oct 08, 2009 | Audio Players & Recorders
My player seems not able to upscale the signal from my antennea and DVDs
Upscaling will only occur when playing DVDs. You have to use an HDMI connection from the DVD player to the tv. For upscaling of DVD's you will also have to setup the upscaling resolution in the DVD player's setup menu. Be sure to set the resolution to one that your tv will support.
If your tv does not have a HDMI input, then you will not be able to use the upscaling feature.
Upscaling will not occur on antenna signals. This is not possible because the hardware (inside DVD player) is only meant to upscale DVD video.
Again, to upscale DVDs ONLY, you will have to have an HDMI cable going from DVD player to TV, set up your upscaling options on your DVD setup menu and have a TV that has a HDMI input and is capable of recieving the upscaled resolution you have set your DVD player to.
If you have any further question regarding this, let me know!
Oct 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Upscale from 480p Signal via HDMI
ok the problem might not be with your receiver it is with your direct tv settings. Double check to make sure you go to the format and set it up to be fixed or 1080i whichever will give you the highest resolution. Check your manual for the direct tv receiver. If this is all correct for the DTV then you must go into the setup on the receiver and at hardware icon toward bottom check on that box, now goto the hdmi settings and make sure it is set to through. this will allow the best picture with no upscaling which will degregade picture for blu ray. so your direct tv will be only 1080i but very impressive. if you still want to upscale you can then you have to change the hdmi settings from before to upscale 1080p . I just hope that your dtv can output 1080i it will give a better picture than 480p even if both are upscaled to 1080p
Oh i forgot to ask if you are connected through hdmi to the tv. Hdmi is the only option for upscaling
Feb 21, 2009 | Onkyo TX-SR606 Receiver
PANASONIC HDMI PROBLEM....
tengo un panasonic tc-32lx70L y no coje los canales digitales a que se debe
Jun 29, 2008 | Audio Players & Recorders
We have a wharfedale dvdr24hdmi player recorder but the hddvd we have purchased will not play.A note inside the dvd disc suggests we consult yourselves for a firmware or software update.
The wharfedale dvdr24 is an upscaling dvd player and not a hd dvd player which is why it wont recognise the disc you are trying to play.
HDMI just means that it connects to your tv via an hdmi cable, so unfortunatley you'll need to buy a hd dvd player to play your disc.
Apr 19, 2008 | Wharfedale Televison & Video
Display resolution through dvi input HELP!
For the record I have a playstation 3 running to tx100 through hdmi to dvi adapter. It does all resolution no probs, including 720p,1080i and 1080p (which tx100 does do smoothly through dvi). My denon upscaling dvd player works fine too. In fact the tx100 looks totally awsome with PS3 games and Blu-ray.
Maybe your dvi lead is the wrong type (i think there are 2 types) or perhaps you could test with a differrent piece of DVI kit in case it's your pioneer causing probs? Hope this helps.
Jan 14, 2008 | Hitachi PJTX100 Multimedia Projector
No video
I am not sure if you have gone into the Receivers Menu or not? If you have NOT! Then please try this: Go into the Receivers Menu (If you do not see the MENU on the TV you can hook up a Composite (Yellow) Cable from the Receivers Monitor Out (Yellow) and select the Input on the TV that you plug into) Look in the Menu for Inputs or In/Out Config. or Video Setup. Look for the Input that you are using for that Device. Change the Video setting to HDMI. I also recommend doing this for you Audio as well. Find the Audio Inputs and MATCH each Input to there DEVICE and CABLE (Connection) Being used. Also check in the Receiver Menu for UPSCALE or UPSCALER. Turn this on or off to see if your TV is Compatible! Hope This Helps! P.S. Check the Manual for Upscaling Capabilities NOT all Receivers upscale and route the SAME!
Jan 12, 2008 | Yamaha RX-V861 Receiver
Does not play multichannel audio (5.1) input through optical digital audio
Hi try this.
in the dvd player make sure you just leave it default (bitstream) but in the home theater receiver don't select 5.1 b/c that will only give you a virtual 5.1 not a true 5.1. In fact don't select any sound field at all just select dolby digital or dts depending on the source of the movie then you should be ok.
The only other problem i can see is that hdmi sends both the sound and picture to the tv. You will need to see if there's a function on the dvd player to only send the picture via hdmi and the sound via the optical out of the dvd player.
good luck
smeags.
Jan 06, 2008 | Panasonic SC-HT920 System
Panasonic DMR-EX85EB-S DVD Recorder/HDD Recorder Logo
122 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
