Question about Samsung RS2534 Side by Side Refrigerator
I have a Vintage brand refrigerator, which I understand is made/the parts are by Samsung. It is 2 years old and there seems to be a water leak from the refrigerator side only - it's a side by side - there is not water under the refrigerator and there is no water leaking from the freezer side - water either appears on the top shelf of the refirgerator and that sometimes turns to ice or it fills up underneath the storage drawers which are located at the bottom of the refrigerator and then the water starts to leak out from there onto the floor - I now have drips of water coming from the light fixture that is on the top of the inside of the refrigerator - have checked the ice maker line and the line to the water filter - no leaks from there - it sounds like maybe a condensation issue or is there a auto defrost, but from where? Is there a simple tracking method to locate the source of where the water is coming from - Also I live in southern california - does anyone know of a repair company that works on this type of refrigerator??
  • 17,970 Answers
One of the most common problems I see with frost-free refrigerators (and often with upright frost-free freezers) is drain freeze up. This is usually caused by the defrost drain clogging, then freezing. On older units, it can also happen when the insulation around the drain gets 'ice-logged', as it often does over the years, causing ice to build up inside the drain.
The first symptom, at least in top-freezers, is usually water under the crisper drawers, on the floor of the refrigerator section. (In side-by-sides and upright freezers it'll appear as a nifty slab of ice on the freezer floor, eventually running water out onto the kitchen floor)
Before I found this little trick, this was a frustrating problem that was hard to keep from recurring.
Now I keep a handful of copper 'drain heat exchangers' in the truck, and use a dozen or two most summers, when humidity is highest and these drains have to handle the most water.
These are quick and easy to make. Just cut a piece of #12 copper wire (strip from regular 12-2WG 'Romex' household wiring ) about 6 inches long and bend it around a 1/4 inch round rod. A screwdriver shaft works well for this, but any 1/4 inch dia. piece of metal will do.
Now when your refrig or freezer drain clogs and you find the trough under the evaporator full of ice, here's what you do. Clear the ice, open the drain (use hot water in your one gallon pressure sprayer and the wet-vac - you DO read the DRSNews back issues, Don't You? Hmmm?), and hang this little piece of copper on the defrost heater, so it extends down the drain. On most units, this is a black rod under the evaporator coil. Some use a radiant heater inside a glass tube, with which you can use this method, but you must carefully bend the hook on your copper wire to the diameter of the glass, being sure it puts no pressure on the glass.
This heater is responsible for melting all that frost that we don't have to deal with since the advent of Frost-free units, and it glows a dull red during the defrost cycle, so there's plenty of excess heat for our purpose.
Anyway, since copper's such a good conductor of heat, some of the defrost heater's energy will transfer down the copper wire, into the drain, and keep it open. What I like to call 'stupidly simple', this uses no extra electricity and works very well!
One precaution: hang this piece of copper *loosely* over the defrost heater. Don't squeeze or crimp it on, or you risk damaging the heater.
For appliances service can search here or in yelp.com
Hope helps.
Posted on Jul 13, 2010
Is a sewing machine vintage at 20 years or at 40 years old
That is probably a personal definition. To me, a vintage machine would be one that is more mechanical than computerized. .Some (below) seem to think it would be a heavy metal mechanical machine. But, to throw a monkey wrench into the discussion, what differentiates vintage from antique?
8 Great Reasons to Own Vintage Sewing Machine
Tips for Buying Vintage Sewing Machine
Best 25 Vintage sewing machines ideas on Pinterest Vintage sewing Antique...
Mar 03, 2018 | Sewing Machines
No water when water filter is replaced for RFG298HDRS/XAA
You are not screwing the new filter in right/ it is not seating. I experienced the same problem; you need to "break the seal" on the new filter.
Apr 03, 2014 | Samsung RFG298HDRS 29 cu. ft. French Door...
My 1 year old ge profile refrigerator has a serious leak problem from the refrigerator water filer. What should I do?
Check where the leak came from in the water filler, probably a pin hole will cause that. If you already located the leak then apply a small amount solvent or epoxy into it. You can buy solvent or epoxy from
hardware store. Look for a brand that is not harmful to human and especially use for water leaks.
You can do it so good luck.
Jul 03, 2011 | GE Profile PSW26P Stainless Steel Side by...
A 2 to 21/2 year old Samsung bottom mount freezer RB217ABPN purchased from Costco. Water is starting to collect under the crisper drawers in the fridge section. This is the third time in a couple of months...
You have a leaking water tank behind the crisper drawer. You will need to get back there to determine if the tank is leaking or the water connection is leaking. This will only leak if you close the door and dispense water from the dispenser.
Jun 22, 2011 | Refrigerators
Water leaks into cabinet fron filter
You need a new filter housing to stop this from happening. You can repair this yourself and save a ton of money!!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST with your brand and model number and we will get the correct part out to you asap. We also provide part removal/installation instructions for you when you get your parts through us.
We hope to hear from you soon and we hope you have a terrific New Year! Thanks, Ella
Jan 08, 2010 | Refrigerators
Our side by side is leaking water in a puddle on the left front corner (water dispener side) off and on. 9 year old refrigerator. Refrig/Freezer and ice/water working well.
I'm going to give you a lot of information on one page please choose thye part that most defines your situation and I will be here to assist you, Please rate me, Thanks, Sea Breeze
Click Link Below
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker is leaking into ice bin.
it sounds like the water valve is leaking
May 07, 2009 | Kenmore Refrigerators
Gas leak
you should call service
Apr 07, 2009 | Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung american fridgefreezer
2 years is much too short for starting problems with a refridgerator contact your dealer for a condition because of warranty on the repair you eventual will spend on it. Hidden defects are factory falts are there some holes for melting water are clogged inside the fridge somewhere
An ordinary refrigerator is made for a 17-year life span. like brands as Bosch Siemens Kuppersbusch easely have that lifetime but your dealer is the right point to get your service .
Aug 18, 2017 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
32 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
