Question about Troy Bilt 5.5hp Self Propelled Mower
What Oil do I put in a Troy Bilt xp series mower
    President:
  • Troy Master
  • 1,545 Answers
They recommend using only SAE 30 oil or 5W-30 if you choose to use synthetic. Be careful. Most smaller mower engines only require about 20-21 oz. The Honda engine may use more. See gauge on side of oil bottle.
Posted on Jul 13, 2010
3 Suggested Answers
RonInFla
  • 86 Answers
SOURCE: where is the oil plug located on a troy bilt mower?
Tilt it over so the oil cap is on the bottom...it'll rest on the handle and hang there...put a container under the oil fill pipe...something shallow like a glad sandwich container works perfect...get a paper towel, and reach under an unscrew the cap...all the oil runs out into the container...it'll fit !!
Wipe the dipstick off clean, and put it aside...take this time to look at your blade on the other side...it "should look" similar to wood chisel at the last 5 inches of the blade on both ends followed by a wing under it...BTW: their $12 bucks new...and worth it !!
Go back and look at the container and be sure the oil is finished draining...take the lid for the container and snap it on and move it out of the way (no body likes an oil spill)...wipe off the oil fill spout, and re-fill...takes about a half a quart, so don't over fill it !!!
your done...
Posted on Apr 17, 2010
  • 152 Answers
SOURCE: troy bilt mower 6.75 hp smoking too much oil...
Check oil level, it could be just excess oil. Also check air filter, it may need cleaning/replacing. Depending on how old the nower is, it could be broken rings in the engine, in that case... time for a new mower. hope this helps!
Posted on May 25, 2010
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
Troy bilt lawn mower were spark plugs go in striped and wont tighten
you can get a spark plug thread repair kit at a auto parts store
Aug 12, 2012 | Garden
How much oil goes in my Troy Bilt Mustang RZT 50"
at least one quart up to 2 quarts
May 23, 2012 | Garden
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
What kind of oil does my Troy-Bilt 12a-264u011 5.5 HP walk behind mower use?
You can check your manual but i would use SAE 30, if in doubt call your Troy Bilt dealer
Jul 02, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Changing oil in a troy bilt squall 5521
To change oil in a lawn mower you will need to acquire a fluid evacuation pump. Remove the dipstick and with the pump evacuate the old oil into a suitable container. Check your owners manual to determine how much oil to put in DO NOT overfill or the mower will not work. Make sure the old oil gets recycled.
Oct 27, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Jun 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Changing oil
is the drain plug on a troy bilt 6.5 hp ontop of the blade in the right hand cornor
Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
641 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
