Question about LG 60PK550 TV
I have a LG plasma tv model 60pk550. It won't
I have a LG plasma tv model 60pk550. It won't turn on. The red light comes on and there is a click when it is plugged in. The fuses are all good.
    President:
  • 1,099 Answers
Hello, you can fix this by opening the back cover of the television to check for dry soldering, if found resolder, check for bulged capacitors, these are likely fault that do occur, but if otherwise ,
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope you find this helpful....
Posted on Jul 13, 2010
  • mbdygert Jul 13, 2010
    I replaced the power supply with a new one. No change.
  • 4,889 Answers
This is a protection fault on the power supply. Possible reason is an overloaded line, happens all the time. We are gonna have to test the circuits to find the exact location of the problem so that we can perform a component level repair or you can just replace the power board. Let me know which of these paths you wanna take so that we can proceed accordingly.
PS: The tv holds potentially lethal voltages for several days after its turned off. I would advice that you get professional assistance to get it fixed if you do not have prior experience handling electronic circuits.
  • 8 more comments
    I have replaced the power board. Same issue. The TV is 3 months old, we had a small storm come through and the tv is the only thing that did not work. LG said it was a surge and not covered. I ordered a new power board and put it in today. Same red light, nothing else.
  • eagle338
    eagle338 Jul 13, 2010
    Ok.. How many times does it blink in between each pause? Do you still hear the click?
    it does not blink. When i plug it in it clicks.
  • eagle338
    See there is no self diagnostic error code. That means its definitely a power supply related issue. I hate to say this but it is possible that you either got a faulty replacement or you have left something unplugged. I have seen this a million times and I am damn sure that it is the power supply.
    how do we test the power supply to see if its bad
  • eagle338
    You are gonna need a service manual that has a schematic of the component along with the voltages. Considering the fact that this is a relatively new model, I do not have one. You can get it from LG itself. They will probably give you a PDF version free of cost if you can send them a mail
    http://www.lg.com/us/support/contact/sup...
    Is there any other things we can check on this tv?
  • eagle338
    The service manual should have an explanation of what different LED states mean. For example solid red- IC xx blown, Blinks once 5V line overload etc., So once you get it we can first check the code(which is most likely to be power supply related) and proceed accordingly. Let me know as soon as you get it and I will see you through this.
    Sai.
  • eagle338
    If this is what I get for helping you out then I can only wish you good luck!
  • Ken Heffernan Aug 01, 2013
    Hello I have 60" LG Plasma no picture only clicks,red light blinks
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. These kinds of issues in plasmas usually occur after 3-4years. A plasma TV is a very hard working device. From what you have described it seems to be an issue with the power supply board which is the board where all the power cords plugs into. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems in plasma TV's are caused by overheating problems. You’ll need to check the power supply board first for any swollen/bulged capacitors. As power supply board is the hardest working board in a plasma TV, it develops voltage to supply all components, high current + high voltage. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
    The TV Is 3 Months old. We had a storm and all my other devices worked, but not the tv. I replaced the power board with a new one, but it does the same thing.
LG 60PK550 suddenly shutdown,when i turn it ON the relay work and then shutdown without any signal or any thing on screen
Sounds like main board fault. Anyway visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
It has details about how to troubleshoot a Plasma TV. Do nt bther about the brand of the TV. Almost all plasma TVs will show similar faults.
Jun 11, 2015 | LG 60PK550 TV
60pk550 tv has sound and no picture ?
Contact the authorized service center for LG. Your TV need a through checkup. Gopakumar Gopalan Google
Aug 08, 2014 | LG 60pk550 60 1080p Plasma Tv 60pk550
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
No display issue
Red means it is going into shutdown because something is wrong.
It will not come on again until problem is found and corrected.
What is model number and do you have a warranty?
Mar 12, 2012 | LG 50PS60 50 in. Plasma HDTV
I have the LG 60PK550 model tv and i have a lot of buzzing noise coming from the set and wondered if this is common in plasma tv's of this size due to the amount of power they consume ?
No,the power supply board have problems.Those power supply transformers on the power supply board,causing this,high voltage flow going through those transformers.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 18, 2010 | LG 60PK550 TV
I have an LG plasma TV, model: 50PC1DRA. We had a
Defective power board. Maybe best to call local service man.
Sep 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Dec 17, 2007 | LG 42PX4DR 42 in. Plasma TV
LG 60PK550 TV Logo
1,658 people viewed this question
Computer Repairing
Computer Repairing
