Operating oki cx3641, staple feature will not work. stopped in the middle of a job. checked staple cartridge for jams, shut down and restarted to no avail.
Srid
  • 10 Answers
SOURCE: paper jams
The Pickup roller of the printer is not properly aligned, send the printer to repair and see the jam
Posted on Sep 29, 2007
altaf702
  • 28 Answers
SOURCE: HP OfficeJet 6110 All-In-One
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
812
Posted on Feb 28, 2009
SOURCE: OKI c3200 Laser Printer...
There are 3 little black and white rollers under the cover on the back of the printer. They are pushed under the upper rollers. They should be on the outside of the upper rollers. Somehow they got wedged under the upper rollers. This should fix the accordian paper jam.
Posted on Apr 04, 2009
SOURCE: dell 924 printer shows error as "unsupported cartridge"
You can't have a Dell cartridge refilled. It's Dell's way of making big bucks selling overpriced cartidges. Their practise is almost illegal and eventually they will get sued.
Buy an HP or a Kodak printer. Both sell better printers and their cartidges can be refilled.
Posted on Aug 26, 2009
  • 40 Answers
SOURCE: HP deskjet 5550 will not print. Flashing orange
Make sure the covers are closed completly. It will not print unless its closed. If its not that, then check to make sure you didn't knock one of the cables loose inside the printer, and make sure the belt that moves the cartridges is still intact and is not jammed.
Posted on Mar 08, 2011
After ejecting five staples, my staple gun stopped pulling staples into the feed and ejecting them. It makes the shooting sound, but nothing comes out. I examined it for staple jam, but found nothing.
staple guns are feed from the rear by a spring. check and see that the spring is still douing its job. if this isa air feed,inpact gunn, clean ejector ports and staple slide.
Apr 26, 2017 | Staples Tools & Hardware - Others
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
Xerox docucolor 240-250 not stapling/folding, error codes 012-243, 012-229, 012-225
Koday Hero 7.1 carriage jam. Stuck to the left side. No paper jam can be found but can't get the carriage to move.
Nov 15, 2013 | Office Equipment & Supplies
Is there a way to reset the printer if you want to stop a job midway when i print a report? OKI Pacemark 3410 Matrix
yes, clear all print jobs in the print queue on the PC.
The press "Stop" on the printer.
2. Turn the printer off for 1 minute the restart
3. Shut the PC down and restart.
This will clear the memory for both devices.
Apr 16, 2010 | OKI Pacemark 3410 Matrix Printer
Oki 5250 380 paper jam
Sometimes you will find debris has fallen into the printer. Take off back to clean it out. Something as small as a staple can create this problem.
Apr 09, 2009 | OKI C5250n Printer
My Swingline model 520e jams every other time I staple.
There were a few staples left in the cartridge when the stapler stopped working. I went thru all the steps on bottom for stapler after changing the cartridge with two different cartridges. It makes the noise and puts marks in the paper, but no staples come out of it.
Mar 18, 2009 | Staples Swingline® 36115 Staple Guns Tools...
OKi C5800ldn 231: fatal error 03
I have the Oki 5650 which had been great for about 18 months. Then found that the C cartridge was showing error as 'not installed'. After much fiddling about with it and checking on the internet I can now rectify this by either pushing down on the top of the printer while it boots up, or removing the small chip on the left top of the toner (make sure you have 'earthed' yourself to prevent any static damaging the chip when you handle it!) and taping securly onto the top of the cartridge above the chips proper slot. This now has been working OK for 6 months. Strange how this only affects the C cartridge (which has also been replaced and had the same problem). I suspect that the printers RFID chip reader for the C cartridge is having problems reading the chip and moving the chip closer to the reader by either taping to the cartridge top of puching on the top cover while printer boots up resolves the problem (for now anyway!) This can also trigger the 'service call 231 fatal error 03' message which also disappears if you follow the above procedure.
Hope this helps you.
Feb 13, 2009 | OKI C5800Ldn Led Printer
Stanley-bostitch B8E E66760 jammed and can not un jam it
i pushed down on the on the cartridge itself and then on the release button. it freed the cartridge and i was able to access the staples themselves. (the tray was full of new staples).
i replaced the cartridge empty, activated the stapler a few times...reopened the tray, reloaded it with the same staples i had removed, and it worked fine.
i found this useless information at the bostitch website:
http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-7781364541754123555/view_question!PAGETYPE?sq=b8e&sc=1&sf=101113&st=526105&documentid=56717&action=view
Aug 05, 2008 | Office Equipment & Supplies
Oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
57 people viewed this question
jasbo
jasbo
