Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Where is the usb port to plug in the printer Brother MFC -240C
    President:
  • 405 Answers
It is located under the scanner cover, under the glass, if you look at the right side of the machine there is a groove to place your figer to completely open the cover, the USB cable would be located on the right side.
Posted on Jul 15, 2010
  • smithfsj Jan 25, 2011
    Thank you! I was going crazy turning it upside down over and over!!!!
Where is the plug in for the usb cable mfc 240c printer
The USB connection is inside the top cover.
Refer to this Setup Guide:
MFC-240 Setup
Go to page 17, Steps 11 and 12. It shows where it is and how to route iy out of the printer.
Thanks for using Fixya.
May 19, 2011 | Brother MFC 240C All-In-One InkJet Printer
How do i connect my printer mfc-240c to my computer
Open the cover.Inside you'll see the usb connector.Plug the usb cable into this connector and then plug other side in to computer.
Oct 16, 2009 | Brother Multi-Function Center MFC-240C...
Lost the disc that came with my MFC-240C now can't connect it to my PC.....how will I connect it...Thank you
Install like any other printer and download the driver for this printer from this site.. http://www.liutilities.com/device-driver/brother-mfc-240c-usb-printer/
Hope this helps
Thanks
Ranjit Ranjit@supportminds.com
Aug 11, 2009 | Brother Multi-Function Center MFC-240C...
How to connect MFC-240C fax/printer to my computer
http://www.nodevice.com/driver/MFC-240C/get41297.html
from this link you have to download th edriver for this device ...
after that if it has a usb cable or a regu;ar printer cable ...conect it to the pc
when its plugged well you will hear a bel sound from the new device found wizard...
ya may also run the driver first ...so in the moment that you plug the printer you already have it into your pc..and the wizard will just complet the installation
Jun 07, 2009 | Brother Multi-Function Center MFC-240C...
I have a bother printer model mfc-240c and a dell dimension 2350 computor. i need instruction on how to and where to connect the printer to the computor
The USB port on the printer is somewhat hidden on this model,
Lift both lids so you can see the inside of the printer(where you installed the ink) to the right of it there is an indented area in the grey plastic. Both the USB port and the telephone/fax port are located on a vertical section of the indented area. Once you plug the cables in there is a track to run the cables in that will drop them out the back of the printer.
Of Note: this model usually doesn't come with the USB cable included, if there isn't one in the box you may have to go back to the store and buy one for $10-$20 dollars.
Once you have the cables installed on the printer, run the disk that came with the printer, DO NOT plug the USB cable into the computer until the program on that disk tells you to.
Once you get through the foray of nexts and ok buttons it will eventually ask you to plug the printer into the computer and turn it on. Windows and the installer program will then complete the installation and you're on your way.
Hope This helps FixYa
Chris
Armor-IT
Apr 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have windows vista and mybrother MFC-240C won't print, Says can't find printer?
first unplug ur usb cable from ur mfc-240c than deinstall all drivers of your printer
than reboot your system
than go here:
http://welcome.solutions.brother.com/bsc/public/midlink3.aspx?prod=mfc240c_all&lang=all&src=DOWNLOAD
click on your country flag and download the latest drivers for ur mfc-240c
install it
than when asked for ut plug in your usb cable from ur mfc-240c
the computer wil find your mfc-240c now whend asked for reboot than reboot
Dec 27, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-240C
lift the scanner cover until locks into the open position.
you will see the usb socket. plug it
route the cables through the trench out the back of the printer
Dec 19, 2008 | Brother MFC 240C All-In-One InkJet Printer
Instructions
first you will have to install the cd that came with the printer. i will assume that you bought the printer new, some where while you are installing the cd it will ask you to plug the usb cable in to the printer. one end into the printer marked usb and the other end into a usb port on the back of your computer. if everything installed correctly, you will be ready to print to the printer. good luck brother tech
Sep 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc-240c
The printer opens up like and a clamshell and their is two sockets, you want the one on the left, with a USB cable running from a usb port on computer
Dec 28, 2007 | Office Equipment & Supplies
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
497 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
