Question about Kenwood KDC-C467FM 6-Disc CD Changer
Interference noises I installed it, when just the battery is on the sound quality is excellent, but when I start the engine there's terrible interference like noise and when I accelerate the noise increases even more.
    Problem Solver:
  • 10 Answers
You have an unclean power supply when you accelerate the whining sound gets louder this innerferance is coming from the alternator, to fix you need to purchase and install a p1 ground loop isolator but before you try this check to make sure your unit has a good ground, move it to a diff. location.
Posted on Jul 16, 2010
CB base Station picking up interfence with inverter
Inverters are full of diodes and diodes are extremly noisy devices. Also the filtering in CB radios is not the best as manufactures try to keep costs down to compete. Try unplugging the antenna from the radio and see if the noise stops. If it does not stop, then buy an inline filter to go in the supply to the radio and place it as close to the radio as possible. If the noise DOES STOP when the antenna is unplugged then it is coming in through the antenna and there is not much you can do but maybe buy a much higher quality radio with better filtering. You might try moving the antenna. Magnet mounts are not as good at blocking noise as high quality permanent mounts. Work to get your SWR as low as possible. Use high grade low loss coax from the antenna into the radio and use high quality connectors like the Amphenol brand. It takes time and effort to solve this type problem and some times nothing works.
Jul 17, 2012 | Cobra 29 LTD CB Radio
Microsoft lifechat lx-3000 headset crackle noises
Go to Control Panel>Large Icon View>Sound>Playback Tab>Right Click The Headset Icon>Properties>Advanced Tab>Change the Default format from CD quality to DVD quality and voila. :D
Feb 01, 2012 | Microsoft LifeChat™ LX-3000 Headset
Order of the cables of chevy venture 99
SET OF 6 -- Meets or exceeds OE/OES specifications for fit, function, performance, and quality; Features OE conductor construction and OE/OES specified insulators, nipples, and terminals; Offers superior fiberglass, silicone, and Kevlar construction for excellent conductivity, high temperature, EMI/RFI noise suppression, durability, and more; Meets SAE J2031 Class E specifications rated to withstand temperatures from -40 to 428 degrees Fahrenheit; Designed with click-in-place end caps that match to OE end caps for quick installation and a tight fit without adjustment; Pre-cut for a perfect fit; Features specially designed ignition cable and wiring systems to meet customer-established performance, reliability, and cost; Passed strict quality control and testing procedures to ensure consistent product performance; Designed to protect electronic systems from electrical or magnetic interference; Allows for all weather starting; Offers resistance to heat, cold, and chemical attack; Carries a maximum voltage; Won't crack or shrink.
Jun 04, 2010 | 1999 Chevrolet Venture
Just installed a Bose Wave system, but the radio emits a constant hiss-s-s-s when we tune it to CBC radio at 96.1, FM. How can I cure this problem? Bill
There is probably a source of interference near the radio. Move the radio into another room and tune 96.1 again. If the interference is still present, try again - further away still. You should be able to find a place in your home that the interference is not present. If you are unable to find such a location, try another radio tuned to the same frequency and repeat the steps above. If the interference is present on the new radio - there is an electrical device nearby (not the radio) that is causing the noise.
You could try a battery operated radio (not plugged into the outlet) to determine if the noise is coming into the radio via antenna - or by the power cord. If the noise is gone, the problem is on the wiring in your home. It could be caused by any appliance in your home - or from the utility itself. You'll have to go around unplugging everything (or shutting circuit breakers off) one by one until you find the source. Don't forget to plug the radio into a different circuit after you've gone thru every circuit - just in case it was plugged into the circuit that was the source of the noise.
IF the noise was present while on battery power, the above test will help determine if the noise source in your house, too. You may have to contact the utility about the noise problem - or it may be a problem within a neighbor's home too. Walk around with a battery operated radio on 96.1 and listen for a stronger sounding noise from the speaker. The closer you get to the source will provide a louder sound.
I hope this helps! Good luck!
Oct 06, 2009 | Bose Wave Radio
BlackBerry 8310 making RF interfernce noise...
I am having the same problem with my phone. When you hook the charger up to the phone the static should go away. I have purchased a new battery and after it charges for the 12 hours i am going to test it out. I will let you know.
Aug 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
Engine noise on am stations
this was common in the old days, if you realy want to listen to the am radio and you cant stand the static reving sound of your engin you may need resiter spark plugs and wires.
Aug 01, 2009 | 1998 Ford Mustang
Interference engine
all of the engines used in the hyundai's are interference engine's, that does not mean for sure u have bent valves but the chances are u did. source of info Gates timing belt Catalog.
Mar 20, 2009 | 1990 Hyundai Excel
Crooked Excel Spreadsheet
I also had this problem, through trial and error I found that if you go into File, Page setup in excel then the Page tab, make sure the print quality is set to 600 dpi. Once I did that it printed correctly.
Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Audio noise on cold start
hi pick up the volume just a bit and so for the speakers and see if it continues to happen if soo try by putting all settings as normal( not your normal the tv's normal...speakers and volume without the reciver) if soothen the problem is in the tv's AMP which was mute all those years hope it works good luck
Mar 19, 2006 | JVC AV-32750 32" TV
Kenwood KDC-C467FM 6-Disc CD Changer Logo
71 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
