Question about Samsung CLX-2160N All-In-One Printer
When printing in color, the color runs - Samsung CLX-2160N All-In-One Printer
    Guru:
  • 366 Answers
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb), OHP transparencies, postcards*, letterheads,
colored paper, envelopes, label sheets, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray
Posted on Jul 14, 2010
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
I have new photo (58) and color (57) carts and when I print wallet size (9 pics per 8.5x11 photo paper) the first 3 print true color and the last 6 are blue. I have cleaned the rollers and still do not...
hello, you are using the photo color ink cart, have you tried running a cleaning cycle or test print, the reason why i ask, is that maybe 1 of the colors is not printing, the test pages would prove what color is missing, if black not printing, it would print possible blue, or no black at all. i know you have put in new inks, but since the volume of ink in these cartridges run out according to usage, one color might run out before the others, and since black and yellow are the most used colors, without them your prints will show color faults.
Oct 07, 2010 | HP PSC 1350v All-In-One InkJet Printer
When I print something out there is nothing on the papper
Did you run a test print? And then check and clean the print nozzles:
Make sure there is paper.
Press the "Maintenance" button once to display an A.
Press Black or Color
Let it run its cycles.
If there is still no print:
Press "Maintenance" button twice to display an H
Print "nozzle check"
Let it run it's cycles.
Still nothing:
Press "Maintenance" button until an M
Still nothing:
Replace BOTH cartridges and repeat the first nozzle check.
If this doesn't work, contact Canon
Jan 27, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I have run out of color ink want to print with black only
all you want to do is to remove the color cartridge then that's it you can now print in color balck
Jan 07, 2010 | Canon PIXMA MX310 All-In-One Printer
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
The color cartridge runs out very quickly even though I rarely use it. I make sure to print in black and white, and I manually choose the option "Use Black Cartridge only" but the color cartridge runs out...
Printer manufacturers design their printers to print some color mixed in with the black when you are only printing black. That is why your color cartridge is running out when you only print black and why it prints "weird colors" when the color cartridge is empty. Printer manufacturers sell the printers at a loss and make up the profit on the cartridges.
Feb 20, 2009 | HP D4360 DeskJet Printer InkJet
HP2820
Try to run maintenance software. Print test pages and see if the color ink does have prints. If print test is working and you can see soe color printing, go to printing properties and check mode of printing, grayscale mode might be activated.
May 20, 2008 | HP LaserJet 2820 Printer
Samsung CLX-2160N All-In-One Printer Logo
450 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
