Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
My saniflow dosnt allways come on when you flush
My saniflow dosnt allways come on when you flush toilet water comes up to top of pan if u leave it a while it kicks in or if u run sink tap it will somtimes start
  • v_stannard Jul 24, 2010
    sanitop with just toilet and hand basin as i say somtimes you can flush toilet and run hand basin works ok other times just fills toilet up and dosnt cut in.
    Scholar:
  • Saniflo Expert
  • 115 Answers
That can be a problem with the pressure chamber, the membrane might be warped or the micro switch may be defective. Open the lid and remove the motor and presure chamber. Inspect the unit for damages or any broken pieces. Check that the membrane is not warped. This can be tested manually by placing the motor on a work bench and putting pressure on the membrane to manually start the pump on and off. If parts are needed you can buy them through Saniflo directly. Their website is www.saniflo.com
Posted on Jul 30, 2010
Saniflo ball valve replacement
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will definately help.
Dec 29, 2012 | Saniflo SaniPlus-Round SaniPlus Macerator...
Pump randomly runs
This problem maybe caused by a slight weep of water from the cistern the saniflow has a sensitive float system , once level is reached the unit will turn on until required level is acheaved again . So check toilet bowl to see if the is a trickle of water if so you need to take a look at the flush system in your cistern.
Nov 17, 2012 | Saniflo & Saniplus& Macerator Pump
I have a saniflow for toilet and when flushed it makes a whirring noise and gradually goes to a loud crunching noise at this point i turn power supply off when turned back on its ok till next flush !p
find water pressure regulator. it will have a bolt coming out of the top with a nut at the base of it.loosen nut. while toilet is being flushed, adjust bolt till noise stops. turn bolt clockwise to adjust.
Dec 17, 2011 | Taylor Home
Opal 2000 toilet suite, water leaking from around bedding cement. Have marked water level in cistern and bowl with marker and there is no change, water would appear to be coming when toilet is flushed like...
check the donut seal which seals the cistern to the pan, they perish and leak when the toilet is flushed, water runs down back of pan to floor you can check this by drying/wiping with tissue back of pan and flushing you will see if any moisture is running down there by wiping again with tissue and seeing if it is damp.
Sep 04, 2011 | Caroma toilet - water saving Sydney Low...
Saniflow pump keeps comming on without flushing toilet
Water pressure makes the unit kick on and off. If it's turning on by itself then most likely somehow water is draining back into the pump. It could be leaking water from the toilet tank, to the bowl and from the bowl to the pump. Or the check valve inside the discharge elbow may not be closing all the way down and is allowing waste water to drain back into the pump creating enough water pressure that makes the pump kick on and off. Inspect the flapper on the flush valve and the check valve on the discharge elbow on top of the macerating pump.
Aug 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
How can you tell if the waste pipe is blocked on a saniflow toile
Yes the bowl will be slow to empty. Try squeezing the white discharge hose as the unit operates, if there is a blockage then this hose will be hard to squeeze. If hose is soft then blockage could be in the toilet pan U-bend in which case fill bowl with very hot water and leave to soften the toilet paper.
Jan 11, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Water leaking out of breather
I have a question, I have a saniplus no problems hooking it up filled the tank and then flushed it..On the discharge end I had a small about of water puddling up at the pressed in rubber fitting. Every clamp was tight not sure what the reason is any ideas. I thought about silcone around the rubbber seal between the lid.
Sep 08, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
554 people viewed this question
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
