Question about Dishwashers
We have a 12 year old kitchen aid diswasher model kudpo1ilbs2. It is not cleaning the dishes. Everything is loaded correctly and the proper cycle and soap is being used. We have had no problems until the last 2 - 3 months when a greasy food film is now appearing on the dishes. Some food is left on but not a great deal. The question is what could be wrong and what kind of cost are we talking? We are trying to make an informed decision as to whether fix or buy new. Thank you in advance
SOURCE: Kitchen Aid diswasher controls don't work
The Button is part of a switch control (all the buttons are individual switches) - take the switch block out of the door and test the button (switch)for circuit continuity, if it is OK, then the timer control may be the problem. My machine had progressive failures through the various cycles until most do not work and it wa the timer that was failing bit by bit.
Posted on Oct 03, 2007
micromaster
  • 3614 Answers
SOURCE: No clean dishes
Internal filtersEvery dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve
Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms
There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Detergent cups
Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Posted on Sep 13, 2008
  • 71 Answers
SOURCE: DISHWASHER NOT CLEANSING PROPERLY
there is a food shreder located in the pump at the impeller intake, it looks like a round screen with a rotating blade on it, if the blade breaks off then the screen gets cloged and will restrict water flow.
Posted on Jan 01, 2009
  • 677 Answers
SOURCE: Cutlery is cloudy and dirty,
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
Posted on May 10, 2009
  • 677 Answers
SOURCE: The dishes don't get clean
www.dishwasherfilter.com sells a filter that will solve this no problem. it removes hardness from your water before it enters your dishwasher. you will have crystal clear dishes after the first load. it is guaranteed to work or your money back. this will solve your problem.
Posted on Jul 26, 2009
Maytag diswasher not releasing rinse aid
I am guessing you have tried cleaning the door with very hot water and dish washer soap. If so, then the front portion of the main door will need to be removed to check the bi-metal strip during the wash / rinse cycle to verify the timer is sending current to the dispenser properly.
Jan 28, 2013 | Dishwashers
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
Frigidaire diswasher not drying dishes properly
Make sure you have the heated dry setting selected, use rinse aid at all times, and make sure the unit is getting hot. If it is not, or there is no steam generated when you open the unit after cycle - have a professional diagnose the heating element.
Aug 01, 2012 | Frigidaire Dishwashers
We have a Kitchen Aid dishwasher model number KUDK03CTSS3. It's only about 3 years old, but the dishes on the top rack do not get clean. We thought maybe it was water not coming out the top, or food stuck...
had a simular problem, used product called dishwasher magic to clean it well and that took care of it. I got it @ walmart in the diswasher detergent area. Also be sure you are loading according to the manual. I now use lemi shine in every load for spot free clean dishes and put the dishwasher magic in it about every few months to keep it from getting build up. If you have a manual they have directions to take them apart for cleaning and I have had to that before to. Just remember how to get it back together. That's all I have but I'm not a repair person I'm a nurse.
Sep 15, 2010 | Dishwashers
Dishes not clean?
Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
If cleans well, mostly the upper rack dishes not arranged properly.
I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
Apr 01, 2010 | Dishwashers
Does not clean the dishes
Hello, I can help you. With the dishwasher empty, toss in two cups of white vinegar and run the machine on its longest and hottest cycle. This will thoroughly clean the machine.
Now put in a load of dishes, be sure to run the kitchen faucet til the water is as hot as it will get and then start your machine.
Aug 11, 2009 | Dishwashers
Dishes not cleaned properly....
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Mar 31, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Dishes still dirty after wash cycle
It would be real helpful to have you provide the manufacterer and model number to get more specific with solution.
-Have you changes dishwasher soap powder recently? Buy a box of Electrosol or Cascade and see what happens. The ultracheep versions actually have caused cleaning problems, especilly in water-conserving dishwashers.
-Under the lower rack is the sump area with a filter that can be removed, usaully by removing several screws. Pull that filter, rinse is as best you can. Inspect under where the filter was and remove all debris. Watch out for broken glass that is found in most well used diswashers, it is hard to see and sharp! Reasemble the filter.
-If problems continue and if this diswasher is several years old, plan on getting the wash pump motor replaced (or replace the diswasher with a name brand, Energy Star model.) Good Luck!
Please update me with what you found. OK?
Mar 30, 2009 | Dishwashers
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
Owen Barnes
