Question about Dell Inspiron 6000 Notebook
Battery is charged but computer shuts off
Hi
my dell battery is having a problem: It charges fully, but once disconnected from the power outlet the computer stays on for some 3 mins and turns off... The battery is still charged. what is happening?
  • Gary Woodruff Jul 13, 2010
    Your battery is shot and needs replacement. You could borrow a friends if it is the same battery and make sure you are charging and get a good discharge time before replacing if you would like. Please rate this solution if it has helped you. Thanks, Gary
  • rsimmonds Jul 13, 2010
    thanks. I've had a battery that was shot before, I don't think its the case.
    The battery stays on, full energy, no indicator of energy depletion, and just shuts off
  • 61 Answers
I have seen defective batteries exhibit these same symptoms. If the battery is more then a year or more it is suspect. If you can try a known good battery that will show if the battery is defective.
Thanks, Gary
Posted on Jul 13, 2010
Testimonial: "thanks. Great work!! Keep it up. "
I have a dell 1720 that was working great. I went to plug in the power cord and the green light went out on the power box and nothing happened when I pushed the power switch on the computer. The power...
the charging port and or motherboard is grounding out
that is to say positive and negitive coming together
wont damage the charger
once you plug the charger out of thhe laptop and outlet then plug back to outlet the light will return
has to be look at by a technician
Jun 02, 2011 | Dell Inspiron 1720 PC Notebook
Tip
Should I Remove the Laptop Battery?
Question: Should I Remove the Laptop Battery?
I have a dell latitude d820 laptop at home which I use as a desktop replacement. As such, 99% of the time the laptop is being used it is plugged in. I wonder if I should remove the dell latitude d820 battery so that it is not permanently being charged, or does the laptop cut off the current to the battery once it is fully charged? I do unplug the laptop when I turn it off.
Answer: When using a laptop as a desktop replacement the battery should not be left in for long periods of time. The laptop will over time discharge the battery. Remove the battery – making sure that it is charged to 40% and store it in a dry, warm place. Ensure that it is wrapped protectively and nothing will be dropped on it.
The battery should be re-installed every 3-4 weeks and allowed to fully discharge. Leaving a battery in storage for longer than this without using could cause the battery to fully discharge as the circuitry of the battery itself consumes power.
Leaving a battery in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Remember that when you have removed the dell vostro 1500 battery from a laptop while using with an electrical outlet – the automatic battery backup is no longer functional. Make sure to plug your laptop into an uninterrupted power source (UPS) not directly into an outlet or surge protector.
on Apr 20, 2010 | Computers & Internet
I have connected my nanomax ipod to the computer and it is not charging.how should i charge it?
Good morning, afternoon, evening or night; whatever time you are viewing this solution post. Thank you for choosing FixYa to solve your problem. So you have connected your Nanomax iPod to the computer and it's not charging like it's supposed to, and you want to know how you should charge it properly? There are two ways you can charge the battery - charging via your Dock Connector to USB Cable, or the Apple USB Power Adapter (which is sold separately). Here are the step by step instructions to charging your and Nanomax.
Using the Dock Connector to USB Cable
  1. Using your Dock Connector to USB Cable, plug the dock connector end to your iPod and plug the USB end to your computer. Make sure the computer you are using has a USB 2.0 port (check your computer's technical specifications to see if it's USB 2.0 certified). Most USB ports on the keyboards of laptops do not provide enough power to perform charging activities. If you have a Docking Station, plug the docking connector into the station and placed the iPod in the station as well.
  2. Make sure your computer is fully awake and not asleep (meaning in sleep mode).
  3. A fully charged battery takes 3 hours to complete. An 80% charged battery takes an hour and 30 minutes. The battery is charging when it shows the charging icon (a battery not fully shaded in green, with a lightning bolt).The battery is done charging when the "fully charged" icon shows (a green-shaded battery with a 2-prong plug showing).
  4. When you are done, disconnect the cable from your computer.
Using the Apple USB Power Adapter
  1. Connect the Alternating Current (AC) Plug Adapter with the power adapter (if connected already, skip this step).
  2. Using your Dock Connector to USB Cable, connect the dock connector end to your iPod and the USB end to the power adapter.
  3. Plug the power adapter into a polarized wall outlet or surge protector outlet.
I think you connected everything correctly, but the USB port on your computer did not have enough power to charge your battery. If that's the case, you will have to find a computer that has a USB 2.0 port on it (like a desktop PC or MAC, or a car adapter charging device) and connect to it, or use the USB Power Adapter (sold seperately). I think this pretty much answers your question. I hope this benefits you the best way possible. Once again, thank you for choosing Fixya as your one-stop solution spot for your problems. Have a good day, evening or night; whatever time you are viewing this, and visit us again the next you need assistance troubleshooting.
Apr 27, 2011 | Audio Players & Recorders
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
Purchased a new Dell Inspiron 6000 (9 cell) battery
You just want to refresh battery from the BIOS. There problem will be solve
Mar 15, 2010 | Dell Inspiron 6000 Notebook
I have a Dell XPS M1210 laptop for which I have just purchased a new 9-cell compatible battery. It worked great for a couple of hours, but now shuts off immediately when unplugged from the AC power supply....
You might want to try what I did when I had a completely discharged battery for my Dell Laptop. I attached the battery to the computer, make sure the computer is off and plug in the charger for a full twenty four hours (undisturbed). And this really worked. I had no problems with the battery. Good luck.
Feb 26, 2010 | Dell XPS M1210 Notebook
Battery indicator flashing red when running on battery or on main supply and battery is 75% charged
When your battery indicator is flashing Red, it usually means that the charger is defective.
Dell also had a recall on some of its batteries. To see if you qualify for a free replacement click here: http://www.dellbatteryprogram.com/
If you want to reset your battery utility follow these steps:
1. Let the battery run completely dead. (Make sure all your work is saved)
2. Fully charge battery (You may still have flashing lights but if you turn your computer on and enter BIOS you can see the charge level)
3. Once again run battery dead.
4. Remove battery and wait 5-10 minutes.
5. Replace battery and use in normal operation.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Dell Latitude D600 Notebook
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Dell DJ Ditty fully charged but shutting off due to "low battery"
charge your player and reset and try again if not works
then replace battery of your device that is damaged
Dec 25, 2009 | Dell DJ Ditty MP3 Player
Dell Inspiron 6000 Notebook Logo
128 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
