Question about Refrigerators
MY REFRIG STOP WORKING, THERE IS POWER TO THE REFRIG BUT THE CONDENCER AND FAN ARE NOT KICKING ON. AFTER PULLING OUT THE REFRIG FROM THE WALL THERE IS NO LEAK THAT I CAN SEE ON THE FLOOR. ANY IDEAS?
  • 6,784 Answers
HI. You unit is showing strong signs of main board failure. If the evaporator and condenser fan are not working, this will confirm the failure i suspect. I will you to observe the compressor unit. If it is hot to the touch and it is not cycling on and off, this will , again, confirm that your main board has failed.
Additionally; Check to be sure of air movement inside the freezer and refrigerator sections. If there is no air flow inside the unit when plugged up, this will again confirm the failure to the main board. The condesor fan should be spinning at a high rate when the compressor is activated. If this fan is not spinning at that time, the fan motor may be the culprit. inspect all these areas for their operational value and let me know what you observed.
Posted on Jul 13, 2010
I have an Amana Refrigerator. It is a double door on top and a pull out freezer on the bottom. The freezer is working fine. The refrigerator light comes on but it is not cold and my fresh food is fading...
either the evaporator fan in the damper vent door isnt running to push cold air from the freezer up into the refrige compartment or the damper vent door between the freezer and refrige section is frozen shut and cannot open to allow cold air flow,you need to access the evaporartor coil in the freezer rear wall and check both the fan and door movement
Mar 22, 2011 | Amana Refrigerators
Water dispenser not working,
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours so the heat will thaw the " hook " , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
May 15, 2010 | GE GSS20IEP Side by Side Refrigerator
Model gsl251grb water dispenser stopped working. r&r filter no help. turned temp down in case froze, no help. can hear motor run. ice maker works. help
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Nov 13, 2009 | GE GSL25IFR Side by Side Refrigerator
Water stopped coming out of the front
There is also a dispensor heater , you may want to install , pt # WR49X10173 . This should keep the water line from freezing again , if it turns out to be that problem .
Nov 07, 2009 | GE GSL25JFR Brushed Steel Side by Side...
Kitchen aid kscs251 gets hot on front strip between the doors
Remove the bottom kick panel , and check that the coils are clean of dust , lint , pet hair , etc . Next , pull the refrig out from the wall , and remove the back panel . Check to see if the fan , cooling the compressor is working . If not , it should be replaced .
Sep 19, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker works slow
Usually , slow ice production , is caused by dirty condensor coils ( the coils under the front of the refrig , behind the kick plate ) . Only vacuum what you can see , no need to pull refrig out and all that . It does need to be 3 " from the wall though .
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sub-zero 511 Refrigerator again!
The problem could be one of many. Make sure the condencer is clean and that the condencer fan is working. Make sure the light is going off when the door is closed by pushting the door light switch in. Next the compressor would need checking and then the most likely is that your low on freon which most likely means a new refrig evaporater .
Dec 21, 2008 | Sub-Zero 650 / O Bottom Freezer...
Problems with Frigidaire FRS6R4E Side by Side Refrigerator?
The refrig side does not have a fan. only the freezer. Is that fan working??? you will hear it when the unit is running (and not in defrost) The clicking you hear is the Damper (a motorized door allowing more or less air to the refrig) opening or closing. Is there frost buildup on the back wall of the freezer??
Nov 23, 2007 | Frigidaire Side by Side Refrigerator 26...
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
