Question about Samsung UN55C8000 55 in 3D HDTVReady LCD TV
Unable to connect tv to internet. 3d plasa 8000 series tv
Unable to connect tv to internet. able to get gateway ping but notice on screen advises unable to connect to external gateway
2 Suggested Answers
  • 51 Answers
SOURCE: my samsung 55" 3d led 8000 series tv dont seems to
You need a 3D source.
Posted on Nov 28, 2010
Unable to access settings of d-link modem dsl-2750u
Your Connectivity may be on Wifi or Lan, ping the gateway and verify gateway IP is up and running if not then try to manually assign the IP to the system and try ping and if there is any proxy Please also remove the proxy from the internet settting and if still problem.Then reset the modem and then also set the IP of your system 192.168.1.2 and access the by default IP 192.168.1.1 and configure the acces point
Nov 27, 2013 | D-Link Computers & Internet
I've connected my Router to switch and through switch i connected two wireless Netgear N150 router where my router is gateway. My Problem is I can ping from Laptop to Router gateway but unable to ping from...
The two wireless routers THINK they are directly connected to the Internet and they prevent the WAN side ports from being pinged so hackers can't find out you have a device on the Internet. The devices will let you to the Internet without any problems, why do you need to ping from the router to the WiFi routers anyway. all of that is your internal network....
One thing that might fix this is if you can put the WiFi routers in BRIDGE mode. Some routers will let you do that, some won't. Don't put the router that is facing the internet into bridge mode. hackers will be able to see your whole network.
Sep 12, 2013 | Linksys EtherFast Cable/DSL Router
What is Gateway Ping
Ping is used to check for a network path to a specific host. In this case the script will ping from domain.com to the host you provide. Ping should be the first TCP/IP diagnostic tool you use when tracking down a network problem. Ping uses a series of Internet Control Message Protocol (ICMP, often-pronounced eye-comp) messages, that produces an Echo message to which every host responds. When Ping uses the ICMP messages and replies, it can determine whether the other system is alive, and also compute the round-trip delay in communicating with that system. So Ping can show you how fast the connection is between two ip addresses or domains.
Oct 11, 2011 | Samsung LA40A550 40 in. HD-Ready LCD TV
Operating system: Windows XP Home Edition Model: Acer One Aspire Problem: PC sees wireless networks & connects but Internet Explorer &/or Mozilla don't get me on the internet.
please ping your router gateway,for seeing default gateway you take command prompt and type ipconfig, there you can see your default gateway then type ping gatewayip (eg: ping 192.168.0.1) if you are getting reply from that gateway your computer communicating with your router.If you are getting request timedout then there is a problen in communication.If you are getting the reply then you just ping google (ping www.google.com).getting reply the connection to the internet is fine.If not there is problen in internet connection in the router.
Jul 21, 2011 | Computers & Internet
My laptop will not connect to our wireless router at work. It says connected, but no internet access.
The laptop might be connected to your wireless router but is unable to connect to the internet
check if you can ping websites
- click on start > Run > type in "cmd" > in the command prompt type in "ping www.yahoo.com"
- if you get 4 replies the problem might be with your browser.
- if Ping fails try typing "ping 209.191.122.70" which is the IP address for www.yahoo.com
- if ping is successful then the issue is with your DNS server. contact your ISP to get alternate DNS
- if Ping fails try pinging the default gateway or modem IP (you can find the default gateway by typing IPCONFIG)
- if ping is successful then there is a problem with your internet provider
Also you should try disabling your firewall and runnning a virus/malware scan
Mar 30, 2011 | Computers & Internet
I have a samsung tv , and im setting up my INTERNET@TV , it ticks off everything but the Gateway Ping ! Please Help
If the Gateway Ping test fails, then your TV is not communicating properly with your Router or Modem.
To resolve this, follow these steps:
  1. Power off your TV, Modem, and Router.
  2. Unplug the power for your Modem and Router.
  3. Make sure the ethernet cable is securely connected to both your TV and your Router or Modem.
  4. Plug in your Modem and turn it on.
  5. Plug in your Router and turn it on.
  6. Make sure your IP Address information entered into the TV during the Network Setup matches the information from your Router or Modem.
  • If you are using an Automatic Setup (most users), skip this step.
  • If you are using a Manual Setup (advanced users), contact your network administrator to determine what the correct IP Address information is.
7. Run the Network Test again.
  • If the Gateway Ping test passes, but another test fails, click here to go back to the list of Network Tests.
  • If all tests pass, the TV is successfully connected to your network.
  • If the Gateway Ping test fails again, see below....
If the Gateway Ping test fails again, there may be a problem with your network setup. To determine if there is a problem with your network, follow these steps:
  3. Connect your ethernet cable directly to the TV and Modem.
  5. Power on the TV and run the Network Tests again.
  • If all tests pass successfully, then there is a problem with your Router setup. Contact your network administrator or router manufacturer for information on setting up your network.
  • If all tests do not pass successfully, there may be a problem with the TV. Connect another device (such as a Computer) directly to the modem.
  • If the other device connects to the internet, then the TV will require service. Click the Create online service request button below to have the TV repaired.
  • If the other device does not connect to the internet when directly connected to the modem, then there may be a problem with your modem. Contact your Internet Service Provider for help on troubleshooting your modem.
(from Samsung support)
Hope this helps. -Sa_Les_Ski
Feb 28, 2011 | Televison & Video
I purchase a netgear universal wireless internet adapter to connect on my samsung tv to get the internet , netflik etc.....i was not able to pass the test with the gateway ping which failed. the model...
I have a couple of questions
1. What gateway are you pinging?
2. From what device are you sending the ping?
If you are trying to ping the gateway on the modem/router provided by your internet service provider then you will not get a ping response, this is because it's configured not to respond.
Oct 06, 2017 | Computers & Internet
Im trying to connect to a wireless network and it says it is connected but when i open the internet it does not work
check the configuration of your laptop. use another laptop to check the wireless configuration if its working in another laptop...check all possible setting of your laptop..make it fault all if needed
Jun 24, 2010 | Acer Aspire 5050-3242 Notebook
I have the HERMO packard bell model. I can hardly access internet and the sound is not heard. Please hhelp
For internet
Resolution:
First check ipaddress
Click Start -run- type cmd hit enter for XP or Start -search-type cmd hit enter in Vista. On the DOS black screen after the blinking cursor type ipconfig hit enter check the ipaddress if are getting ipaddress other than (169........) it is proper ipaddress for e.g 147.14.48.478
Ping the default gateway e.g ping 147.11.445.478 if you are able to get packets send 4 received 4 loss zero is with Internet explorer or operating system.
If unable to ping or getting 169..... ipaddress . you are having static ip address
On the black screen at the blinking cursor type ipconfig /release hit enter
then type ipconfig /renew hit enter .check ip address
Ping default gateway then ping www.google.com if you are able to get packets send 4 received 4 loss 0. Try connect to internet using internet explorer or other browser. if still unable to connect then issue with firewall or antivirus or IE corruption .
Create new administrative account in XP and do MSconfig .Restart the system and logon to new account and try connecting to internet.
If issue persist might have to repair IE or operating system as it is software issue or virus issue.
You can connect a different computer if you have one and check internet.
If unable to get any ipaddress or still getting static ip address ,reset modem or check ethernet cable ,do a hard reset on the internet modem.Shutdown and restart computer and check ipaddress then try connecting to internet.
NO sound : Check the sound driver .Try reinstalling sound drivers
Aug 24, 2009 | Computers & Internet
Samsung UN55C8000 55 in 3D HDTVReady LCD TV Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
