Question about Dell XPS 420 PC Desktop
When i try boot my dell xps 420 it states that there is no boot device available. Why does it say this?
    Problem Solver:
  • 9 Answers
A boot device stores your operating system (i.e. Windows), and is usually your hard drive, but can be any storage medium such as a floppy, usb flash drive, or even a cd rom. When you turn your computer on, your motherboard looks for your OS on any of the storage devices specified in your bios, in the order specified to look first (Ex. Boot order: 1. CD-Rom, 2. Floppy, 3. Hard Drive, 4. Network). Your Dell is telling you that it can't find Windows on any of these devices. Most likely cause is that your hard drive stopped working, your Windows boot.ini file became corrupted, or you have a USB device plugged into your computer, and it needs to be unplugged before turning on your computer.
Posted on Oct 02, 2010
I have a web cam in my monitor. It won't work, the computer (XPS 420) won't even recognize it. How do I get it?
Kindly check if it's still detected on Device Manager. If the driver has been removed, there should be a question mark right beside the name of the device. Try reinstalling the driver, support.dell.com. To simplify your search, type in te service tag number of your computer. (It's a 7 alpha numeric identifier code which can be found on the dell sticker)
Sep 01, 2013 | Dell XPS 420 PC Desktop
I have a dell xps that came with a wireless/bluetooth keyboard with mouse pad and i have another dell xps 420 that i'd like to use the wireless keyboard on...they are both dell xps's and both
Wireless/Bluetooth keyboards and mice can only be used with one device at a time it is like a bluetooth headset once it is paired with a phone it will 99.99% of the time only work with that phone and that phone only, Wireless keyboards and mice are setup on the same principal once they are paired up with 1 PC to use on another PC you have to remove the pairing. The worst case scenario is that the second PC's Wireless/Bluetooth has failed. I hope this helps.
Sep 03, 2012 | Dell XPS 420 PC Desktop
How do i fix a XPS 420 hard drive that stopped working?
You shoudl first go into your BIOS settings and ensure that the HD is registered there, compltely.
Then with the power off, open the CPU Case and look for the HD. Ensure that the jumpers are set to MAster, and that all cables are plugged in proberly and firmly. and I mean at both ends of the HD, the HD itself, and the cable to the motherboard/disk controller.
Then you should be sure that your HD didn't somehow get clobbered, such thta the disk is wiped clean, or that the critical Windows boot files are missing. If so, if you had created a boot disk for such an occurrance, then restart and hit F5 or F8 immediately after the power comes on, until you get a menu for boot. Find the option to allowyou to use boot repair and system repair on your computer.
If nothing works, then it may be necessary to start fresh and recreate your sytem from scratch.
I wish I could bring better news.
-a.
Jul 16, 2012 | Dell XPS 420 PC Desktop
Dell xps 420 noisy fan black screen
more than likely bios isn't letting it boot, i'd make sure the fan bearing hasn't gone out, if it has you can order a new one
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 03, 2012 | Dell XPS 420 PC Desktop
Connect midi to dell xps 420
You can use Midi to USB adapters.
Here: .MIDI Interfaces
Feb 06, 2012 | Dell XPS 420 PC Desktop
I have Dell XPS 420 , with windows home server running for some time. I tried to insall/upgrade RAM from 3 gb to 6 gb. So, i found the right RAM (2x2GB) and removed the two old 512 mb from the slot and...
According the the dell specification you can only install up to 4gb, so I don't understand you saying that you were upgrading from 3gb to 6gb. Make sure that all the ram that is installed is of the same brand and speed (667 / 800 MHz Dual Channel Dual DDR2 SDRAM). The fact that it is saying no boot device also would suggest that it is possibly something wrong with your harddrive, whether it was corrupted or damaged while you were changing the RAM, if you have a spare harddrive try installing and booting from it. If that doesn't work it could be a motherboard issue, which the BIOS should be update, all the jumpers on the board should be checked etc. Its rather hard to diagnose a problem such as this, and the fact that after you installed the new RAM, even the old RAM would not work, suggests that you may have damaged something while messing around in the computer.
May 19, 2011 | Dell XPS 410 PC Desktop
Dell XPS 420 won't boot at all not even a BIOS screen
the bios is not starting ...
check the memory ram if its inserted correcly or
chek the beeps wen cpu starts and
http://kb.iu.edu/data/afzy.html
se if tha link is help full
Apr 29, 2010 | Dell XPS 420 PC Desktop
Dell xps 420, won't finish loading bios boot screen, freezes and gives steady fast beep,cant get into safe mode, no clue what to try
see if this info helps narrow down the failure
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Apr 03, 2010 | Dell XPS 420 PC Desktop
Dell XPS 420 sound software problem
Try to download a different software , Like VLC player
Jan 23, 2010 | Dell XPS 420 PC Desktop
Dell XPS 420  PC Desktop Logo
416 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
