Back to:
Tags:
Onkyo TX-NR905 7.1 Channels Receiver
Wrong valtage
posted by petersa on Apr 20, 2008
220V through the receiver
Comment by petersa, posted on May 08, 2008
I ended up putting 220volt through a receiver that is set for 110 volts for about 3seconds. I then changed the fuse , connected the receiver with 110v and tryed again. ( with a transformer)
At this stage I can only receive sound through the receiver
No screen
Can you help
Regards
Peter
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
sodabug
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I am not sure what your question is but if you purchased the U.S. version and it is 110V and you are somewhere where there are 220V, you will need to purchase a stepdown transformer for it to work properly.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Wrong valtage:
I don't want to Accept this solution
Can you Help with these Receivers problems?
Receivers
can hear music but not call
Receivers
I need to find out the tuning frequency for a L7 15. the...
Receivers
Looking to replace Boston Acoustic HD7 bottom speaker with...
Receivers
zone one doesen't work everything else does?
So I recently tried hooking up my Onkyo TX-NR905. I've...
Loading problems.
Repair Service
Find Receiver Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
