Question about Kenmore Dryers
I have a Kenmore 67832 model number that is drying but takes twice as long as it use to. The air vent is open & lint filter clean. Could it be one of the thermostats not working properly & needing to be replaced?
  • Kenmore Master
  • 8,220 Answers
It might be but do this first:Unplug the dryer. Remove the rear dust cover and then remove the filter chute and wash it out, check the blower, and wash out the filter.
I have a Kenmore 67832 model number that is drying - 6daed05.jpg1408cac.jpgThe thermostat is right next to the fuse. 477aa6b.jpgThe large wires carry the heater element current. The smaller wires come from the control. They power up a small heater that chI have a Kenmore 67832 model number that is drying - d7dd490.jpgate at which the control shuts off power to the heater for knit and permapress. The newer dryers have a thermister which controls the temp.I The thermister could be bad. Rate it or hate it 36dc1dd.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 13, 2010
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
Taking too long to dry
your lint trap and lint vent are most likely clogged. Easiest way to fix it is to move your dryer away and disconnect the lint vent from the dryer and then take a yard blower to the back of your dryer with a towel around the blower in the hole to ensure the max air moves through the machine. (Ensure the door is only slightly cracked or your house will get very dusty) then clean the lint trap. Then do the same to the lint vent line (make sure the opening of your vent line on the exterior of home is clear of any debris or critter screen) reconnect your vent hose and it should work as new
May 16, 2012 | Kenmore Dryers
I have a Sears/ Kenmore model 70 heavy Duty eletric dryer, this months eletric bill was almost twice what it normally is and we realized that it has been taking longer and longer to dry the clothes. Once...
Long drying times are ALWAYS cvaused by poor air-flow in a dryer.
The causes are many.
1. Go outside and check the thru the wall dryer duct flapper. Make sure it is free of lint.
2. Pull the lint filter and wash it with vinegar. The water then soap and water with a very good fresh water rinse.
3. Inspect the area where the lint filter is installed for any signs of lint build up. Use a crevice tool and a stretched out and folded in half wire coat hanger (Looped) to reach deep onto the lint build up areas so you can remove the lint with a crevice tool and Vacuum.
4. Remove the vent duct from the back of the dryer and check the air-flow. The air-flow should push a relaxed hand / wrist gently away from the dryer vent hole with the dryer on. If you do not get this kind of aor flow you will need to ensure all of the lint has been removed from the internal dryer ducting. If your sure the ducting is clear and you stil have poor air-flow then most likely the blower wheel has failed, Most of the time the center hub will crack and the blower wheel will not turn at full speed. Other times a fan blade breaks and blocks the ducting.
5. Use a flash light and look into the vent duct hole on the back of the dryer. Check for a restricted duct. Clean as necessary.
The above are the most common reasons for higher electric bills and long drying times.
Have a 2nd person look for lint after your done cleaning! The more eyes the better.
Thanks for choosing FixYa,
Kelly
Jan 25, 2011 | Kenmore Dryers
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
How do u know if the heating coil is bad?
If you are feeling any heat at all when you place your hand by the air vent in the back, your element is at least partially working. We must determine if your model has a single or double element. If you have a double, perhaps only one side is working. To determine this, I will need the model number located under the lid or on the back of the unit.
If you have NO hot or warm air, it may be your element or the thermal fuse. Need model number.
But before we do that...
The most common cause of this is just a simple build up of lint. No matter how well you clean the lint filter during use, lint does build up and may require cleaning every few years or so. If you do have some warm or hot air and it seems to take two cycles to dry your clothes, try these simple checks (unplug dryer):
1. Insure that your vent hose is not clogged with lint. Unhook it on both ends and see if you can see through it. If there is a blockage, remove lint, reconnect and you should be fine. 2. Insure that the flaps on the vent outside of your house are free of lint and can open and close freely. If they are upstructed, clean. If they do not open or are bent, you may need to replace the vent. 3. Pull out your lint screen and see what you see? Lint build up? Take a coat hanger and bend it to stick into the lint trap well. Can you pull out any lint? Pull out as much as you can. Also look into the vent on the back...is there lint inside? Use your hanger. This may involve opening the top of the unit, or pulling off the front to clean. But let's get the model number before you get that far.
Write me back with model number or let me know if cleaning the hose and/or vent help. I look forward to assisting you.
Aug 02, 2010 | Kenmore Dryers
We have a Kenmore 80 gas dryer that tumbles, has hot air, but takes 2 hrs to dry. Vent line is clear, but lint filter is getting lint on back side of filter as well as normal amount on correct side. The...
Have you cleaned out the lint build-up from inside of the dryer yet? When you disconnect the vent from the back of the dryer, look inside the dryer. It probably have years of lint build up covering everything and needs cleaned out. You also will need to clean out the filter reservoir (with the filter removed) if you can get to it with a vacuum attachment. Be sure to unplug the cord and close the gas valve while you are working on it. Also be sure your vent flap outside is not stuck and allows hot air to open it when in use. Lastly, when you push the dryer back into place, make sure you don't squish the vent tubing if it is an expandable plastic or foil vent, which will restrict air flow and cause drying clothes to take longer. Hope this helps. Douglas
Jun 03, 2010 | Kenmore Dryers
Won't dry clothing takes a long time
when did you last clean out dryer?need to vac out dryer,clean out lint duct and blow out the vent line,go outside and see if the vent is blocked,if flapper isn't opening that is a sure sign that it's loaded with lint,if this is not it,come back with model number and is it gas or electric
Nov 03, 2009 | Kenmore Dryers
I have a kenmore elite HE2 dryer and it takes 2 or 3 times before the clothes are dry
know this may seem simple, but the lint filter needs to be cleaned after every load- some times twice- 'specially if you have cats, or heavy blankets, or lint prone fabrics. might try using vacuum cleaner to clean vent tube, or check external vent louvers. blocked or repressed airflow can really slow the drying process!
good luck!
Sep 08, 2009 | Dryers
Dryer not drying cloths
HI thanks for your question. the lint filter housing is full of lint. remove the lint screen. 2 screws. remove. pry top up with a flat screw driver, from the almost the corner. lift the top up. pull dryer away from the wall remove the air duct that the lint filter goes in clean out the lint. thanks the appliance doc
Oct 16, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
120 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
