Question about Lexmark E260dn Laser Printer
The printer reports states low pc kit. I have changed the kit and toner and it still is binking.
    Genius:
  • 1,087 Answers
After replacing the kit and toner, you will need to reset the printer's page count. Simply press and hold the CANCEL button while the printer is on and the front cover open until all lights are flashing. Hope this helps.
Posted on Jul 13, 2010
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
I refilled toner of my Lexmark E120 (since it said it was out of toner) and it worked fine untill few days ago when I got status report: Missing or defective catridge. Could this mean it's out of...
Replace the chip, is a chip cartridge problem.
if not work try this:
31 Defective toner cartridge or missing cartridge
1. Verify that the toner cartridge and PC kit are correctly installed.
2.Wait 10-20 seconds for the printer to verify the units.
3. Replace the toner cartridge or PC kit if necessary.
Aug 01, 2011 | Lexmark E120 Laser Printer
When i refill toner it still show toner low.how sovle the problem
Good day.
First try to print a print status report. Here are the steps:
1.Push setup menu button, that would be the wrench icon. 2.Push the right button to navigate until you get to the Tools Menu 3.Tools Menu>Push button for Printer Status Report
This will give you the accurate ink levels on your printer. If it still shows low ink based on the printer status report, you have to reseat the ink cartridge and make sure the orange tape near the HP Logo on the ink cartridge has been peeled off.
If the report shows ink levels are fine, then that status report on the front panel is just a false report. Try powering off your printer and powering it back on again. As long as you don't have print quality issues, you should be fine.
Jun 20, 2011 | HP LaserJet CP1515n Printer
My Canon Laser Class 710 fax machine is flashing a red error and the message states ''received in memory'' .. How do I clear it?
You could be out of toner = new toner cartridge.
You could be out of paper = reload paper
You could have a printer problem, paper jam, door open, etc
get the printer part working.
does it print a report if you press the 'report' key?
Nov 13, 2009 | Canon Office Equipment & Supplies
States the ink is low & it is not low - I took out toner cartidage & shook it - it then stated I had to clean cartidage by moving a green tab - I did - that it stated drum problem. I repeated the...
Firstly, I would like to say that this is a "scam" of brother. They make the toner life so short when there is still so much toner left in the cartridge! This is a problem for me because we print a lot. I have been searching tediously for an answer to this problem, but have been unable to find one for this particular printer. The best thing to do for now is to return the printer for a new one-not just a new printer, but from a different company. If you dont want to buy a new printer, go onto Ebay, and search for the toner cartridges for this printer. You can buy them for 25 dollars, and this is the simplest solution but you will have to do this for a long time. So you should get a new printer because it will be much more money to get new toners rather than buy a printer that lets you print more pages per toner without the "Toner End Scam."
Oct 23, 2009 | Brother MFC-7440N Laser Printer
Toner Exhausted
mail me at printerrepair@in.com for complete solution .
Jun 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
Flashing error and toner on Dell 1700 and will not print even after replacing drum and toner this happened before and I found on line sequence of pushing the buttons on printer to clear...but i can no
After replacing fysicalythe photoconductor/imagaging drum, leave the door open. Press and hold Cancel untl all lights flash in sequence to reset the printer. Close front cover.
May 28, 2009 | Dell 1700 Laser Printer
Copier makes faded copies, even though it has toner
the heater unit is the problem.
yo can get a repair kit by search on the Internet or go to Toshiba web site.
the repair kit come with instruction, if you can handle the mechanic part of things. then you are all set.
May 19, 2009 | Toshiba DP5570 Laser Printer
Lexmark E260dn Laser Printer Logo
1,658 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
