Question about Avaya 5610 IP Phone
Dial tone, can be called, hear caller, but caller cann't hear me.
Our Avaya 5610 IP phone contractor sent a phone after activating the system at headquarters. They configured the remote phones and shipped them. They were supposed to work out of the box. They didn't.
An IT contractor successfully configured the remote IP phone for the Internet. He got me a dial tone and an extension number that can be called. However, when I answer my remote Avaya 5610 IP phone, I cannot be heard. I can hear the caller, but they cannot hear me.
So what is the problem? At this point, it must be really simple to fix.
The IT contractor doesn't know the phone system. The phone contractor still hasn't called me back. What can I do?
The problem is likely either a conflict in compression or a speech path problem.
In Manager, is "Allow Direct Media Path" checked?
If so uncheck and reboot eh phone system, then reboot the remote phone.
Posted on Jul 30, 2010
Our phone system rings three times (on the caller's end) before the standard greeting connects. We use Avaya and Caller ID and it seems it is standard with that program and calling feature that the...
Is this an IP Office?
This is how it works. For some reason the IP Office waits for teh first 2 rings to get caller ID, and then lets the call ring in.
Sep 07, 2011 | NorStar M7324 Telephone
Lately when i call out - the party on the receiving end hears a garbled message..it even happens when I dial an internal extention. I am working remottley in my home office using a Avaya 5610sw IP...
Your internet connection at home or the office needs to be faster.
Talk to your ISP or have the phone admin run some traces to see where the blockage is.
Aug 13, 2011 | Avaya 5610 IP Phone
Is it possible to get caller ID for an incoming call if I have that number saved as a speed dial? If so, how do I get that. My phone is the Avaya IP Office 5410. Thanks
If the number matches the CID number, you should get the name as well. But here is the hard part.
IF your system requires you to dial an access code (say 9 to get an outside line) you may have that speed dial number saved as:
913125551212
If so, the incoming caller ID would have to match exactly, meaning CID would need to show 913125551212 in order for this to work.
BUT, caller id probably only shows 13125551212, and as such, wont work.
Jul 15, 2011 | Avaya 5400 Series 5410 Phone
I got error message on 2 Avaya 5610SW IP phone: one is showing: incompatible Disc and another shows:Call Barred Disc. I have no clue to issue. is there anyone can help me out?
Incompatible means that what you dialed is not recognized by the system.
Call barred means your phons is restricted from dialing whatever you are trying to dial (900 numbers etc)
Aug 11, 2010 | Avaya 5610 IP Phone
Cannot receive calls and dial tone flashing
You have a feature active on your phone it's more than likely a call forward feature which would redirect you calls. The broken dial tone or stutter dial tone is an indicator a feature is active. Contact you system admin for the clear all feature code and the clear all call forwarding codes.
Feb 26, 2009 | Mitel 5220 IP Phone
Dial tone is active as I'm dialing, callers cannot hear me speak
Your phone is broken, the only solution is to replace it. Call Uniden Customer Service and they should be able to help you. 1-800-297-1023. ( I'm serious, there is no way you can fix this problem with out opening the base unit up and replacing a bad transistor)
Feb 24, 2009 | Uniden DECT 6.0 Cordless Telephone...
How to configure Avaya's IP Phone 5610?
What IP did you give the phone? When it says discover, its looking for the call server, which it is not finding.
Which system is this on? If IP office, you may need to build an IP route in the system for that subnet.
Feb 13, 2009 | Avaya 5610 IP Phone
Repair of Polycom conference handsets
Hi Debbie,
Try Multimessage systems based in Potters Bar for repairs.
We repair Conference phones along with a host of other manufacturers products.
If you are local we can either pick up from you or you can drop them off and we will quote on the repair before we start.
Please call me , Paul Morgan, on 07703 270679 for more details.
Multimessage Systems
Avaya Global Repair Centre
BT Repair partner
Jan 19, 2009 | Polycom SoundPoint IP 501 IP Phone
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Avaya 5610 double display on incoming caller ID
Did you get this fixed. I would double check the firmware files of the phone. And maybe reset it.
Oct 10, 2007 | Avaya 5610 IP Phone
Avaya 5610 IP Phone Logo
1,413 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
