Question about Toshiba 62HMX84 62" Rear Projection HDTV
Red & green light is on
When I turn on my tvthe red& green light on the front of the tv is on but the tv is noton what can be wrong?
  • Anonymous May 25, 2008
    The TV has a blank screen, but the audio is fine. The TV will try to shut off and turn back on with the same result and the red and green lights trun on.
  • parothdwcltd Jun 02, 2008
    Both the red and green lights indicate that the lamp is not on. Check the lamp behind the door behind the left side door.
  • 3 Answers
I have a 62HM84 and had the same problem with no picture and the blinking red and green lights on the front, then the tv turns off. read the above and bought a lamp and ballast from conn's appliance online. the lamp is easy to replace, 2 screws and slide out then slide the new one in from the side panel. But the ballast was the problem, not the lamp.
keep track of your screws and how things went together. i did not still not sure about one piece. you do not have to cut anything to get to the ballast, but it is a pain. you have to take off the entire back panel on the lower part of the tv. unscrew the metal support bar (flat). unscrew the other screws on the bottom. they are connect to a rolling metal tray that all of the exposed parts are sitting on. before pulling tray out, there is a black plastic piece on the left side that is in the way. unloop the wires around the hooks and unscrew the one screw. there is still one fat wire that is connected on the left side that i could not figure out how to disconnect so the tray did not come all the way out. double check for other wires that may prevent the tray from moving. i think there is another on the right side.
to get to the ballast, it is on the right side, as far back as you can reach. to get it out, unscrew the brown electrical connector from the side door opening. pull the out from around the metal shield as best you can. unplug the other two wires from the ballast. there are 4 plastic hinges on the corner of the ballast, push back to pull the ballast out. just do the reverse to get the new ballast back in and the tv back together. had a very hard time trying to get the new brown electrical plug back in. everything worked fine once i put it all back together.
Posted on Jun 09, 2008
How to fix a light switch on a whispaire notone hood ,it has one red wire and two black wires
Polarity is not important if it only turns on the hood light, Red to one side of the switch and both black to the other side.
Nov 18, 2016 | Electrical Supplies
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My t v will turn on, the light will be Red, then Green ,then
your tv in protection mode some thing wrong inside tv.mostly power card defective.
Jun 28, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
When turning on the TV the green light on the front does not come on. You hear a click and then about ten seconds later you hear another click but the tv never comes on.
What light do you get, green blinking, red blinking, yellow steady light or yellow blinking light. The led lights will tell what is wrong with your tv.
Jun 12, 2009 | Mitsubishi WD-52327 52" Rear Projection...
My picture is green the it shuts off with light blinking in front
that's very hard to fix, you need to monitor every test voltage pin if is in normal. try also replace crystal capacitor thats one monitor with the jungle IC.
Apr 30, 2009 | Sony KP-57WV600 57" Rear Projection...
TV won't come on- green and red lights flashing
It may be your bulb.  We just had to replace ours after 4yrs.
Dec 31, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
Wont' turn on
The unit shutsdown for a reason ,is sensing trouble somewhere,it could be mechanical problem or an electronic problem,either way it needs service.An estimate will tell you whats wrong and if it is worth to you to repair.Good day
Sep 05, 2006 | Panasonic PV-DF2035 20 in. TV/VCR/DVD...
Toshiba 62HMX84 62" Rear Projection HDTV Logo
144 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
