Question about Garden
How do i level the mowing deck on a 38 inch deck
    President:
  • 1,545 Answers
I can provide with a link to instructions for leveling a Craftsman Lawn Tractor 42" deck:
www.searspartsdirect.com
Type in Model # for your tractor (if it is a Craftsman)...if not use the model # for a certain Sears 42" tractor which is: 917.272672
There will be an option on the right side of the page to download (for free) an operators MANUAL and inside that are detailed directions for leveling a riding mower's deck.
Posted on Jul 13, 2010
How do you level the mowing deck?
There should be an adjustment on both sides of the deck. Move the nut up or down to raise of lower it.
Jul 03, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
if you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
May 14, 2014 | Yard Machines 13AC762F000 38-Inch 344cc...
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I was mowing in thick grass and my ride on mower stopped. If I try to restart I can hear and feel the motor trying but it just wont get going.
You probably hit something unseen. First check under you deck to be sure a stick or something isnt wedged in there. Check your belt and pulleys on top of the deck.
Im tempted to say check the flywheel key or adjust the valve lash.
Oct 25, 2012 | John Deere Garden
Mower dies if you put in reverse while blades are engaged
These mowers are designed to do that, so that you don't accidentally back over a pet or kid while the blades are turning. My Bolens 38" has a key setting for reverse mowing, you have to trun the key to that position in order to bypass the safety swith for reverse.
May 30, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Mower mows graet for 30 mins then starts to load
Yes you need to replace the needle and set in the carb.
Aug 23, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Mowes unevenly. Blades don't match up.
make sure when you replaced the spindles that you used all the washers and spacer bushings back identical to the ones you took off.
Make sure your deck isnt bent for some reason where the spindles mount and or the deck itself
level the deck when its on the mower on a level suface,side to side(level) back to front the back just a little higher than the front 3/8 inch or less
proper air pressure in all 4 tires
Also you could add a washer or take away a waher to allow the blades to become level at mid point meeting?
be sure to torque the blade bolts to 35 ft.lbs also
May 31, 2009 | Husqvarna Garden
Garden Logo
245 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
