Question about Philips Audio Players & Recorders
PHILIPS CONDENSER MICROPHONE MODEL LIKE B432 FROM 70IES PERHAPS, LOOK A LIKE BLACK BULLITT . HOW 8-PIN DIN TO 3-PIN XLR WIRING
ice man
  • 68 Answers
SOURCE: Microphone wiring for DV camera
on both xlr connection, you can see numbers on the plug from the out side and the inside. number 1,2 and three. 1 is for the ground, 2 for the hot wire and 3 is for the return, just match numbers. if you switch them, it will not work. just make sure one to one and so forth. good luck
Posted on Apr 01, 2007
  • 1138 Answers
SOURCE: Want a wiring diagram for 1x3pin xlr plug to
Pin 1= ground/shield, Pin 2= hot(+ve), Pin 3= cold(-ve). Just remember if you make a cord like this you can expect some signal loss.
Posted on Oct 19, 2009
  • 611 Answers
SOURCE: Hi, I have a Shure Untdyne
Amphenol -> XLR
Pin 1 -> Pin 1
Pin 4 -> Pin 2
Pin 3 -> Pin 2
Posted on Oct 18, 2010
  • 87 Answers
SOURCE: i got a cable to hook my MXL 990 condenser
Professional condensor type mikes require a phantom power source to work. That will be a balanced (read XLR) connection from source to preamp and the preamp must be capable of supplying the power. These units cannot be used in an unbalanced circuit (like 1/4" or computer mini-pin). Your best bet for the setup would be to get an external power supply box that can also convert the signal from balanced to unbalanced. That would be what the mike plugs into and then that plugs into the computer. You're probably looking at about 50-100 for even a cheap one that will work well. Companies like Sweetwater and B&H should be able to steer you toward a decent basic unit. If you happen to have a mixer (which is why you bought the good mike) then it may have phantom power for some of its mike inputs.
Posted on Oct 23, 2010
cjsound
  • 26 Answers
SOURCE: Microphone came with male XLR not soldered. What
http://pinouts.ru/Home/xlr6_pinout.shtml That should do it.
Good Luck, Cody J.
Posted on Dec 17, 2010
How do you wire ecm77 to jackplug
There are literally hundreds of styles and sizes of jacks and plugs. The ECM77 is a condenser microphone and REQUIRES phantom power to bias it. Not all body packs have this bias available...MOST current mixers do have phantom power, at least on XLR inputs. Since you did not tell us what this connects to, we can't give you a definitive answer.For an XLR, the shield of the cable will tie to pin #1... be careful as the pin numbers are tricky... Typically for a TRS 1/4 or 1/8 jack, the shield of the cable ties to the sleeve part of the plug and the other two wires to the tip and ring contacts.
Mar 13, 2013 | Sennheiser freePORT Wireless Instrument...
What is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
What are the true xlr connection numbers for bottom blue and red wires
Blue wire connects to XLR pin 2.
Red wire connects to XLR pin 3.
You can find a wiring diagram on Shure's website.
Apr 19, 2011 | Shure SM58 Professional Microphone
Want a wiring diagram for 1x3pin xlr plug to 2x3pin xlr female plugs.microphone splitter.
Oct 12, 2009 | Audio Players & Recorders
Wires in the microphone at the point where you connect to the lead have come appart and i need to solder them back on, Black, red and white wires. Which in which order do i solder them onto the connecter...
There are many standards of microphone connectivity with 3 pin XLR (cannon) style plugs. It depends on where in the world you are as to the favoured standard,
Your microphone usesthe following::
Pin
1 ground (white) 2 +ve or hot (red) 3 -ve or return (black)
Another way to work out what wires connect to what, is to remove the cover of one of your XLR-XLR microphone cables exposing the connections it favours, plug the connector into the mics scoket , and use the connections to the cable guide you in resoldering the connections back on.
The same connections can be veiwed in the user manual here
Please rate this solution. Cheers
regards robotek
Jul 15, 2009 | Behringer XM1800S Professional Microphone
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Don't know the conections of blue or red
If we're talking about the microphone cable wiring on a low impedance mic remember this. Cheap mic cables with XLR's on both ends often have no standard color code to follow. True pin 1 is ALWAYS ground (shield wire) but the other two wires could be any color of the rainbow. Look for small numbers beside each pin of the XLR connector and make sure that pin two on one end of your cable, is also pin two on the other end as well....etc. Special note: The XLR connectors set screws have reversed threads and it's the same for the XLR male plug in the bottom of the microphone as well.....Glen
Dec 24, 2008 | Shure Beta 58A Professional Microphone
75 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
