Question about Intermatic E1220W ELECTRONIC AUTO-OFF TIMER
Can Intermatic on off clips work with ALR model # TC101R201 Timer? This is a dial timer that is used to turn on/off a swimming pool pump.
  • 12 Answers
SOURCE: Intermatic timer will not turn pool pump off
If your timer is not turning off the pump its probably wired incorrectly. Check the wires on the back of timer as it should work the same as a regular light switch. They may be reversed.
Posted on Jan 26, 2009
rockitman187
  • 2559 Answers
SOURCE: How To Program An Intermatic PE15300 Pool Timer ?
1. Press PROG Key to cycle through menu options.
2. Press UP and DOWN arrow keys to change program settings.
3. Press ENTER key to save changes and exit programming mode.
4. Press ON/OFF keys to manually turn devices ON or OFF.
Please post back if additional info is needed
Please take time to rate this fixya
Posted on May 13, 2009
  • 30 Answers
SOURCE: Changing Pool Timer
As long as you get a new timer that is 220/240v and is the same amperage or larger, you should be fine. Wiring would be the same.
Posted on Jul 09, 2009
  • 351 Answers
SOURCE: Intermatic Pool timer will not turn off... I have
If the pool pump timer is not working, first look and see if the clock dial is moving, if not then you need to check the 120volt breaker that feeds it ,, then you would check the connections on the timer to be certain that they are correct.
Posted on May 04, 2010
MOTORWIZJ
  • 1343 Answers
SOURCE: clock for pool pump intermatic timer Model T104P3 stopped ticking
TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ.. JAY ..LOOK EBAY FOR .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX
Posted on Jun 02, 2010
Is timer the problem
I would think whatever is hooked up to the timer is bad. Not the timer itself. Disconnect/unplug the pool pump from the timer and see if the timer trips the breaker.
Dec 04, 2013 | Intermatic 220v T104p Swimming Pool Pump...
Pool pump clock
T104M used WG1573 clock motor:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
The timer mechanism has metal gears, while the clock motor has plastic gears. If the metal gears get dirty and bind, it will strip the plastic gears.
Turn off power, pull timer out of box, Clean out timer with compressed air, and spray WD40, add a bit of white grease to lever where trippers make contact, then replace clock motor ... and buy another set of trippers to have on-hand since they are designed to wear down so timer will last longer.
If timer body is broken so dial does not rotate, then buy new T104 and snap new mechanism into old box. Buying whole T104 with enclosure is cheaper than buying T104M mechanism only.
May 15, 2013 | Pool & Spa
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
I need to know how to set this timer for a large swimming pool, and how long I need it to run, to keep it clean. I believe it is about 35,000 gals., in-ground pool.
You have Intermatic mechanical timer connected to swimming pool pump/filter.
Open following link to read about setting timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Lift and rotate dial until current time is lined up with stationary pointer.
Put on-off trippers on outer edge of dial.
Timer comes with 2 sets of trippers, and you can order replaceable trippers. Up to 12 sets of trippers can be added to dial for a total of 12 ON and 12 OFF events each 24-hour period.
For 35000 gallon, pump should run at least 6 hours each 24-hour period. During freezing weather, if pipes are above ground, you can remove trippers from dial, set override lever to ON position, and run pump 24-hours to prevent frozen pipes.
Jul 12, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Purchased new intermatice pool timer and it will not turn pool on but will turn pool off.
Timer is not known.
Timer is probably not wired correctly, or on-off trippers are not on the dial.
Add a comment with model number that appears on inside of timer door.
Jun 18, 2011 | Intermatic Hardware & Accessories
Intermatic pool timer E10694 does not turn on. It shuts off okay.
Open following link for troubleshooting checklist:
If dial is rotating, then tripper might need to be replaced.
The problem here is I cannot identify E106 timer
Intermatic product Index, and pool and spa catalog do not show that specific model among digital or mechanical timers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
Maybe you have T106 2-speed pump motor?
Add a comment with in-focus photo of timer you posted on Flickr for possible identification.
Upvote the help.
May 17, 2011 | Intermatic T104 24h 208-277v Mechanical...
Intrametric T-101R timer used to turn a swimming pool pump on and off. The dial not longer turns so I need to manually turn the timer on and off. Manually it works fine, but the timer feature doesn't...
Check wires from timer motor to terminals. If you buy the same brand of timer, you can "pop" timer mechanism out and replace it with the new one you take out if it's enclosure. Be sure the tripper hands are on the dial.
Jun 15, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic Pool timer will not turn off... I have to shut off the pool pump at the breaker... Any suggestions on what the problem might be?
Jan 18, 2010 | Intermatic Timer T12404R Pool & Spa...
Need Trippers for Pool Timer
Maybe a bit late, but try Paragon. They have red features and were commonly installed during that period.
Jul 12, 2009 | Intermatic Digital Time Clock In Metal...
Intermatic  E1220W ELECTRONIC AUTO-OFF TIMER Logo
81 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
