Question about Mountain Shimano Alivio Front Bike Derailleur Bicycle Part 129
I have a huffy 26 in mountain bike with gear shifts by the hand grips is it possible to tighten the cable to make the gears work better?
  • 4,102 Answers
Hi, if you follow the cable to the derailleur at the back and look where the cable goes into that part you should see that its held on with a bolt, now just before this bolt their should be an adjuster that you can turn to tighten the cable a little bit, you know where the black outer cable goes into the derailleur at the back their should be a little screw in adjuster you can screw this out and this will tighten the cable.
how ever if you dont have this then change the gear so its on the lowest gear (the smallest cog at the back wheel) then if you undo the bolt on the back derailleur that is holding the cable if you undo it slightly you should then be able to push the derailleur up slightly and pull some of the cable through when you have pulled some of it through tighten the bolt back up and then give it a try, before you tighten it up make sure the little adjusted is screwed in all the way then when you have tightened the cable up you can then adjust it further using this adjuster on the end of the cable.
now the only other problem you may have with the gears is that over time the gear cable becomes weak and therefore goes stretchy this can cause the gears to be loose and not change correctly so if the gears dont work after adjusting then this would suggest you need to get new cables for the gear system.
CLICK HERE
this link will show you how to replace a cable so it will tell you and show you what i have just told you.
let me know how you get on or if you need further assistance ok
Posted on Jul 13, 2010
How to install the handlebars?
Stick it in, tighten it down, add brake and gear levers. Take it to local bike shop, if you are having problems.
Aug 23, 2014 | Huffy Granite 26 Women's Mountain Bike
Brand new bike gears won't engage. The gear shift is on 6 and the chain is on the smallest cranks.
the derailleur cable is too loose. Shift the shifter into the smallest cog, make sure the chain is on the smallest cog. The derailleur cable will most likely be very slack now. At the rear derailleur, there will be a nut or a allen bolt pinching the cable to the derailleur. loosen this, pull the cable finger tight, tighten the nut or bolt again and then try shifting again. You can dial it in using the barrel adjuster on the derailleur or the shifter.
Oct 15, 2011 | Pacific International Pacific Evolution...
How do I fix the grip shift ? The piece that you turn to shift gears will not click into place. It slides back to first gear.
on the top of your grip shift there will be a slot for your shifter cable to connect. there should be a bolt there as a tensioner as well as on shifter itself. these may have to be tightened because it sounds as if they are loose.
Aug 24, 2010 | Schwinn High Timber Girls' Mountain Bike...
Trying to reassemble rear wheel gear assembly for huffy mountain bike. i didn't take it apart and don't have a manual. someone else took it apart
This should help you:http://sheldonbrown.com/gearing/index.html. Also try here:http://www.parktool.com/repair/byregion.asp?catid=4 Hope these sites help. Good explanations and pictures.
Aug 29, 2009 | Huffy Blackwater Men's 26-Inch Mountain...
How do I fix the handle of my huffy blackwater women's bike so that it synchronizes with the wheel?
Try this website and look under repair help:http://www.parktool.com/index.asp I think you are try to adjust your derailleurs. Also check this website under gear shifting:http://sheldonbrown.com/gearing/index.html I hope this will help.
Aug 10, 2009 | Huffy Blackwater Men's 26-Inch Mountain...
Changing gears
spray some wd40 into the cable untill you see it dripping out the other end then attatch a pair of vice grips to the tail end and losen the cable nut on the derailer then pull tight with vice grips and tighten cable nut.
Aug 02, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Operator manual for huffy crosswind bike grip shift
Look for the manufacturers name and model number on the gripshift and check at www.parktool.com. Look under derailleurs for repair tips which will give you an idea how they work. A twelve speed has six gears on the rear sprocket and two on the crank giving you a combination of twelve speeds. sheldonbrown.com is another good site with good articles and pictures.
Jul 15, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
Mountain Shimano Alivio Front Bike Derailleur Bicycle Part 129 Logo
23 people viewed this question
Top Mountain Cycling Experts
Michial Gueffroy
Lawrence Oravetz
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
