Question about Garmin nuvi 260W GPS Receiver
Battery my car adapter is broken....does my garmin charge if i plug it into my computer
  • 63 Answers
The unit will take a very slow charge via your computer. I tell most people no it doesnt charge VIA your PC just because it takes soooo long. I recommend getting a new power cable from GPSCity. Just call them up or follow the like to the cable you need.
** This cable is for the Nuvi 200 series GPS units
http://www.gpscity.ca/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi-in-web-packaging.html
Cheers
Posted on Jul 13, 2010
I will be travelling in Europe without a car and no access to a computer. Is there a plug in adaptor for charging the battery? Can the battery be replaced, as needed?
You can purchase AC international adapters for all nuvi units, here is a link to one http://www.gpscity.ca/garmin-nuvi-zumo-international-ac-adapter.html.. For your battery it will not be able to be replaced by you the user, I only recommend replacing it through an authorized Garmin repair center.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 1370T Car GPS Receiver
I just bought a Garmin 265T how do I charge it for the first time with my pc.
Connect the vehicle power adapter to the Garmin 265T GPS to charge it. The battery indicator is in the upper-right part of the screen. You can also buy other accessories, such as an AC adapter, to plug the GPS unit through a wall outlet or a USB charger to charge it through a computer.
If it came with software install it then plug it in to your computer with a usb cable that is compatible with it.
Jun 12, 2010 | Computers & Internet
Nuvi 760 will not take charge
I don't know which of the three ways you're trying to charge - car cradle, via USB cable to a computer or via accessory AC adapter. An 18 month old 760 should still have a good battery.
If you are using your car cradle to charge consistently, use one of the other methods and allow the 760 to charge for 8 hours. Use of the car cradle can cause the 760 to stop taking a charge after a while, and switching to one of the other methods should "refresh" the internal battery. Since the AC adapter wasn't included in the box, the USB cable method is likely your only other choice. While connected to your computer, you should download & update the 760's firmware. It's fast and free - and could solve other potential issues. Get the WebUpdater software direct from Garmin.
It is also possible that the fuse in the cigar lighter plug has opened. Disassemble the the plug to check for and replace a blown fuse.
If unable to get the 760 to accept a charge, you might need to replace the battery. There are several sources for batteries - but a free call to Garmin Support should be your first move.
Please rate this reply and good luck!
Jun 10, 2010 | Garmin Nuvi 760 Car GPS Receiver
StreetPilot C330 (010-00401-10) GPS Receiver: I just recently purchased a Garmin GPS system for ...
If there are no power points in your vehicle, you might have to purchase a battery-operated powerpack and plug the GPS into that via a USB/AC adapter.
May 18, 2010 | Garmin StreetPilot C330 GPS Receiver
Not turning on
My unit was totally dead. I just kept it plugged into my computer for about 12 hours. I downloaded the newest software from Garmin. When I unplugged it from my computer, the battery seemed to drain quick, but once I plugged it into the card adapter in the car... everything seems to be running great now.
Oct 09, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin nuvi is no longer charging via car adapter. I plug it into the car lighter as usual, but it never charges and continues to operate off of battery life.
Your car adapter may be broken. try unscrewing the top of it to check the fuse inside the cable. that can easily be replaced. other than that it could be the cradle (if your cable plugs into your cradle) or the back port of the unit in a worst case scenario
Aug 13, 2009 | Garmin Nuvi 760 Car GPS Receiver
Not charging
Give this a try let it charge for 24 hr and see what happen
Mar 20, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin 1412, wont run on battery power, DC only. Need info on maybe a full reset whether to return as defective
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
Dec 22, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Garmin c340 does not charge
I came here looking for solution and tried the "press eraser in bottom right corner and turn on" but didn't work for mine BUT if you look at the face plate (the part on the front that says "Garmin",) just under the word "Garmin" you see a small indent in the plastic, useing your finger nail, gently pull upwards and the face plate will come up. Also, be gentle while pulling the face plate being careful not to break it. ( I advise that you use your nail and not anythng that might scratch the plastic if you are intending on returning the unit, cause they may suggest that you tampered with it and that "voids the warrenty") Anyway, look at the USB plug (above the ON button on the side) and you see a tab, press it and the unit will reset.
Seems to me that with all the problems Garmin has had with their units freezing up that I should have found this solution on the garmin site! To think that there are people who will throw there unit away because of this problem OR who will pay 150.00 bucks to get it fixed through Garmin.
Jan 15, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
195 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
