Question about Kitchen Ranges
Have a Leisure roma 100 cooker model number RM10FRS main fan oven not heating need a service manual to find out how to get at heating element to see if needs replacing.
Most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
Posted on Jul 24, 2010
  • Tommy Vickers
    Tommy Vickers Jan 26, 2015
    where on the back is it cant find mine
I had the same problem with my Roma 100 and I nearly started to take it apart to replace the thermal fuse which seems to be a common problem. However I noticed that several people mentioned the clock and the fan oven were linked (probably so the automatic cooking can work). The 'A' had been flashing on the cooker for a little while and I hadn't adjusted the clock since the clocks changed I turned off the cooker at the mains then set the clock to the correct time. The 'A' was no longer flashing and the fan oven now works!!
Posted on Dec 29, 2011
I have a leisure range cooker. model number CMTF99R.The oven RHSis not Heating up. the fan is working and the thermostat light is coming on.
Check for voltage at the element, could be a hi-limit thermostat or a failure at the control board.... You may find you are missing one leg (half) of the 240VAC required to power the elements
Jul 31, 2016 | Leisure Range 90 CMTF95C Cream 900 mm Dual...
Main oven not no heat.thought maybe heating element. tried to take element out from inside oven but seem I may need to take back cover off as it seems the two screws on one side come in from there.
yes your doing fine, usually heating element are sturdy and seldom busted. try to follow the wiring inside and locate the thermal fuse that is installed inline with the wiring,have it replaced
Sep 03, 2015 | Leisure GRB6CVR Electric Cooker with...
Have a electric cooker model nut grb6cvk no heat from main oven everything else working
Oven heater element has died. Get the serial numbers etc off the plate on the back or the handbook, go online to appliance spares sites and see if they carry an element. If you don't know how, get a good DIYer or appliance tech to change it. You could get them to check the element for continuity first?
Nov 15, 2014 | Leisure GRB6CVK Electric Cooker with...
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Oven and grill not heating up, model no se 336ss-5
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Dec 04, 2011 | Smeg Ovens
Hi i have a belling oven model number XOU252 and for the past year and half the oven element keeps blowing. It will first start my tripping my mains electric switch which can go on for weeks then the...
ISOLATE THE MAINS BEFORE OPENING ANY PANEL
Remove the rear panel, there is a component with two terminals screwed to the chassis, read whats on it, take a note of the letters and numbers, get a replacement, from a local electrical store, or www.whitegoods.co.uk you will need the model and serial number, this component stops the cooker from over heating, the elements have to be controlled, the second cause is fan running too slow, if the fan does not cause enogh pressure the element will over heat.
Hope this has been helpful
John
May 19, 2011 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Having problems with fan assisted oven on leisure roma 100 cooker, it doesnt seem to work everything else seems to work fine, Can anyone help me
Often these fan assisted type ovens have a safety that keeps th fan off if it believes the door is open. Look for uneven door closing or cracks in the door to frame closure. Is this a commercial convection oven?
May 08, 2009 | Kitchen Ranges
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
1,957 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
