Question about Quicksilver , Mac ATI RADEON 7000 64MB DVI/VGA Video Card (PCI) (p/n 1024-9C02-00-SA)-Limited Supply Graphic Card
I have a quicksilver throttle control side mount and when the water hit the side of the boat an alarm whent off it happened 2-3 times,than i know keeps beeping it will not stop,how can i stop this and whatis it,thanks.its an older unit,nor sure of age.looks like the model 2226x700 7kjpg part number 881170a4
From what i have learned... (i have the same problem), is that it will beep for 2 reasons that i know of, water or oil. check your waterflow out of the motor, it should be ripping right out with good force. If not, your looking at a cooling problem. Check the impeller, its located in the lower unit of the motor, have you run the engine out of water? or even tuned the engine over quite a bit out of water? if so replace the impeller asap! If its not the cooling its an oil problem. In a lot of cases its an oil sensor, if so replace it fairly cheaply, or it could be that the injection system isnt working properly... this is an expensive fix the engine has to be completely broken down, what i did was just syphon the oil out of the reservoir, and mixed the oil into the fuel! If it comes down to it just mix it 50:1. that way you dont ruin your engine, as far as the beeping, it wont stop it unless its that stupid sensor, i guess just unplug it?
Posted on Jun 20, 2011
How do I remove the engine throttle controller from the panel on a 240 Sea Ray Boat?
Side mounted shift/throttles have a set screw holding the handle on. Coming from the bottom, close to the wall, there is usually a hole/notch. Insert the proper allen wrench and loosen or remove to be sure. The handle is on a spline shaft and should now come off. Wiggle, rock, argue. Once out of the way you can see the mounting screws and go from there. If a different style post picture.
Oct 08, 2014 | Boating
How to take quicksilver 3000 siries throttle apart . Its a Murcury throttle handle.
from the picture I would remove all the screwI can find or see.first a mechanic's mirrow on a stick might shed some light on the problem also.there could be a clip on it also .
May 13, 2014 | Boating
Replacing shift cable, disassemble of control unit, Quicksilver 3000 control
Un Bolt controler From Side Of Boat
Remove Lower Panel 2 Screws
Undo 8 mm Nut Securing Front Of Cable Remove Cable .
Fit New Cable Re Attach Front Of Cable Slide Cable Back Into Controller Re Fit Lower Cover Re Attach To Boat
Good Luck
Mar 17, 2013 | Cars & Trucks
I hanve a warning buzz in my quicksilver motor control in my boat
Many of those gave a short buzz to tell you they were working. It's when your running and they buzz you need to shut down immediatly and find out what is wrong (engine heat, no oil ??_)
Nov 17, 2012 | Quicksilver Boating
Just bought boat & prop will not in gage all the time
put your motor on the garden hose after you remove the propeller (you don't want to step into a spinning blade). remove the cover and start the motor.
Have some one shift the motor (without engaging the throttle).. This will show you which cable is the shift cable.Disconnect the shifter, and while it's running, shift it full forward and full reverse to fin the halfway point. Next return the control box to neutral and adjust the connector. Start it up and see if the control box will shift the gear box as far as you did by hand. If not you need to take the control box apart and move the cable anchor so you get more movement. Get a repair book and take pictures as the guts of a control box can be VERY confusing.
Sep 06, 2012 | Quicksilver Mercury/Quicksilver Parts...
Boat shakes when i give it more throttle
Sounds like you hit a rock and ruined the prop or the shaft is bent. Have had 2 cylinder motors shake when one cylinder drops out, you might want to check the motor to see if all cylinders and motor mounts are still good.
Aug 19, 2012 | Boating
Quicksilver throttle
I recently aquired a 1982 Merc Bigfoot 60hp with a quicksilver throttle control. I am trying to find a manual as to the throttle operation. Any suggestions?
Chuck flochu1@yahoo.com
Jul 27, 2010 | Boating
Moving the steering from aft to forward on a runabout
There are a couple of options. If you forgo the steering wheel I know that Johnson and others make a Tiller extender. I have been able to move up a seat in a 12 foot boat using this. On my motor the speed control was on the Tiller handle. Still had to jump back to use gear shift.
The oldstyle controls used 2 cables and pulleys to steer wheel. You will have a time to find short enough cables to do motor RPM and shifter. Then you will need to mount steering wheel to something to turn it.
There are Salvage yards for Boats just like there are for cars. Do an internet search for your area. Then pull your boat there and explain what you want to do. Look under Marine Salvage, Marine Salvage yards.
Mar 07, 2010 | Boating
Need to find rebuild kit for quicksilver throttle unit
here is a link to a mercury dealer with parts diagrams and part numbers. click here
Sep 23, 2009 | Bass Pro Boating
I have a 1982 Evinrude 35 hp motor. After running it at tops for about 5 minutes, I go to trolling mode and in about 5-10 minutes in overheats. Steam coming from the water outlet holes. This happened 3...
My smaller johnson had a pickup tube in the housing. With your alarm you only know when it is too hot. You do not know how close you are to setting the alarm at full throttle; it can be running hotter than it should then too. I would drop the lower unit, pull the sending unit and try to force water through the sending unit hole. This should backflush the head. Backflush the impeller housing too.
Jun 06, 2009 | Boating
Open Questions:
Get your wife husband back lost love spells caster in city of New York +27832762854 Have you ever been in a failed relationship? Did you often feel like your partner didn't 'get' you? Are you having many obstacles in your life? Is your love life falling apart? Is your life facing financial ruin? Do you need protection from your enemies? If you seek a lost lover, or want a new lover, we can help. We reunite lost lover`s If you are really in love with someone then this is the spell for you. divorce affairs all kind of witchcrafts bring back lost love spells in NHL Eastern Conference bring back lost love spells in Boston Bruins bring back lost love spells in Buffalo Sabres bring back lost love spells in Carolina Hurricanes bring back lost love spells in Columbus Blue Jackets bring back lost love spells in Detroit Red Wings bring back lost love spells in Florida Panthers bring back lost love spells in Montreal Canadiens bring back lost love spells in New Jersey Devils bring back lost love spells in New York Islanders bring back lost love spells in New York Rangers bring back lost love spells in Ottawa Senators bring back lost love spells in Philadelphia Flyers bring back lost love spells in Pittsburgh Penguins bring back lost love spells in Tampa Bay Lightning bring back lost love spells in Toronto Maple Leafs bring back lost love spells in Washington Capitals bring back lost love spells in Western Conference bring back lost love spells in Anaheim Ducks bring back lost love spells in Arizona Coyotes bring back lost love spells in Calgary Flames bring back lost love spells in Colorado Avalanche bring back lost love spells in Chicago Blackhawks bring back lost love spells in Dallas Stars bring back lost love spells in Edmonton Oilers bring back lost love spells in Los Angeles Kings bring back lost love spells in Minnesota Wild bring back lost love spells in Nashville Predators bring back lost love spells in San Jose Sharks bring back lost love spells in St. Louis Blues bring back lost love spells in Vancouver Canucks bring back lost love spells in Vegas Golden Knights bring back lost love spells in Winnipeg Jets bring back lost love spells in NBA Eastern Conference bring back lost love spells in Atlanta Hawks bring back lost love spells in Boston Celtics bring back lost love spells in Brooklyn Nets bring back lost love spells in Charlotte Hornets bring back lost love spells in Chicago Bulls bring back lost love spells in Cleveland Cavaliers bring back lost love spells in Detroit Pistons bring back lost love spells in Indiana Pacers bring back lost love spells in Miami Heat bring back lost love spells in Milwaukee Bucks bring back lost love spells in New York Knicks bring back lost love spells in Orlando Magic bring back lost love spells in Philadelphia 76ers bring back lost love spells in Toronto Raptors bring back lost love spells in Washington Wizards bring back lost love spells in Western Conference bring back lost love spells in Dallas Mavericks bring back lost love spells in Denver Nuggets bring back lost love spells in Golden State Warriors bring back lost love spells in Houston Rockets bring back lost love spells in Los Angeles Clippers bring back lost love spells in Los Angeles Lakers bring back lost love spells in Memphis Grizzlies bring back lost love spells in Minnesota Timberwolves bring back lost love spells in New Orleans Pelicans bring back lost love spells in Oklahoma City Thunder bring back lost love spells in Phoenix Suns bring back lost love spells in Portland Trail Blazers bring back lost love spells in Sacramento Kings bring back lost love spells in San Antonio Spurs bring back lost love spells in Utah Jazz bring back lost love spells in NCCA bring back lost love spells in Air Force Falcons bring back lost love spells in Alabama Crimson Tide bring back lost love spells in Arizona State Sun Devils bring back lost love spells in Arizona Wildcats bring back lost love spells in Arkansas Razorbacks bring back lost love spells in Army West Point Black Knights bring back lost love spells in Auburn Tigers bring back lost love spells in Baylor Bears bring back lost love spells in Boston College Eagles bring back lost love spells in BYU Cougars bring back lost love spells in California Golden Bears bring back lost love spells in Clemson Tigers bring back lost love spells in Colorado Buffaloes bring back lost love spells in Florida Gators bring back lost love spells in Florida State Seminoles bring back lost love spells in Fresno State Bulldogs bring back lost love spells in Georgia Bulldogs bring back lost love spells in Georgia Tech Yellow Jackets bring back lost love spells in Houston Cougars bring back lost love spells in Illinois Fighting Illini bring back lost love spells in Indiana Hoosiers bring back lost love spells in Iowa Hawkeyes bring back lost love spells in Iowa State Cyclones bring back lost love spells in Kansas Jayhawks bring back lost love spells in Kansas State Wildcats bring back lost love spells in Kentucky Wildcats bring back lost love spells in Louisville Cardinals bring back lost love spells in LSU Tigers bring back lost love spells in Maryland Terrapins bring back lost love spells in Miami Hurricanes bring back lost love spells in Michigan State Spartans bring back lost love spells in Michigan Wolverines bring back lost love spells in Minnesota Golden Gophers bring back lost love spells in Mississippi Rebels bring back lost love spells in Mississippi State Bulldogs bring back lost love spells in Missouri Tigers bring back lost love spells in Navy Midshipmen bring back lost love spells in Nebraska Cornhuskers bring back lost love spells in North Carolina State Wolfpack bring back lost love spells in North Carolina Tar Heels bring back lost love spells in Northwestern Wildcats bring back lost love spells in Notre Dame Fighting Irish bring back lost love spells in Ohio State Buckeyes bring back lost love spells in Oklahoma Sooners bring back lost love spells in Oklahoma State Cowboys bring back lost love spells in Oregon Ducks bring back lost love spells in Oregon State Beavers bring back lost love spells in Penn State Nittany Lions bring back lost love spells in Pittsburgh Panthers bring back lost love spells in Rutgers Scarlet Knights bring back lost love spells in South Carolina Gamecocks bring back lost love spells in South Florida Bulls bring back lost love spells in Southern Methodist SMU Mustangs bring back lost love spells in Stanford Cardinal bring back lost love spells in TCU Horned Frogs bring back lost love spells in Tennessee Volunteers bring back lost love spells in Texas A&M Aggies bring back lost love spells in Texas Longhorns bring back lost love spells in Texas Tech Red Raiders bring back lost love spells in UCLA Bruins bring back lost love spells in USC Trojans bring back lost love spells in Utah Utes bring back lost love spells in Vanderbilt Commodores bring back lost love spells in Virginia Tech Hokies bring back lost love spells in Washington Huskies bring back lost love spells in Washington State Cougars bring back lost love spells in West Virginia bring back lost love spells in NFL AFC bring back lost love spells in Baltimore Ravens bring back lost love spells in Buffalo Bills bring back lost love spells in Cincinnati Bengals bring back lost love spells in Cleveland Browns bring back lost love spells in Denver Broncos bring back lost love spells in Houston Texans bring back lost love spells in Indianapolis Colts bring back lost love spells in Jacksonville Jaguars bring back lost love spells in Kansas City Chiefs bring back lost love spells in Los Angeles Chargers bring back lost love spells in Miami Dolphins bring back lost love spells in New England Patriots bring back lost love spells in New York Jets bring back lost love spells in Oakland Raiders bring back lost love spells in Pittsburgh Steelers bring back lost love spells in Tennessee Titans bring back lost love spells in Super Bowl LII bring back lost love spells in NFC bring back lost love spells in Arizona Cardinals bring back lost love spells in Atlanta Falcons bring back lost love spells in Carolina Panthers bring back lost love spells in Chicago Bears bring back lost love spells in Dallas Cowboys bring back lost love spells in Detroit Lions bring back lost love spells in Green Bay Packers bring back lost love spells in Los Angeles Rams bring back lost love spells in Minnesota Vikings bring back lost love spells in New Orleans Saints bring back lost love spells in New York Giants bring back lost love spells in Philadelphia Eagles bring back lost love spells in San Francisco 49ers bring back lost love spells in Seattle Seahawks bring back lost love spells in Tampa Bay Buccaneers bring back lost love spells in Washington Redskins bring back lost love spells in MLB bring back lost love spells in AMERICAN LEAGUE EAST bring back lost love spells in Baltimore Orioles bring back lost love spells in Boston Red Sox bring back lost love spells in New York Yankees bring back lost love spells in Tampa Bay Rays bring back lost love spells in Toronto Blue Jays bring back lost love spells in AMERICAN LEAGUE CENTRAL bring back lost love spells in Chicago White Sox bring back lost love spells in Cleveland Indians bring back lost love spells in Detroit Tigers bring back lost love spells in Minnesota Twins bring back lost love spells in Kansas City Royals bring back lost love spells in AMERICAN LEAGUE WEST bring back lost love spells in Houston Astros bring back lost love spells in Los Angeles Angels bring back lost love spells in Oakland Athletics bring back lost love spells in Seattle Mariners bring back lost love spells in Texas Rangers bring back lost love spells in NATIONAL LEAGUE EAST bring back lost love spells in Atlanta Braves bring back lost love spells in Miami Marlins bring back lost love spells in New York Mets bring back lost love spells in Philadelphia Phillies bring back lost love spells in Washington Nationals bring back lost love spells in NATIONAL LEAGUE CENTRAL bring back lost love spells in Chicago Cubs bring back lost love spells in Cincinnati Reds bring back lost love spells in Milwaukee Brewers bring back lost love spells in Pittsburgh Pirates bring back lost love spells in St. Louis Cardinals bring back lost love spells in NATIONAL LEAGUE WEST bring back lost love spells in Arizona Diamondbacks bring back lost love spells in Colorado Rockies bring back lost love spells in Los Angeles Dodgers bring back lost love spells in San Diego Padres bring back lost love spells in San Francisco Giants
Aug 20, 2018 | Sun Computers & Internet
See all Quicksilver , Mac ATI RADEON 7000 64MB DVI/VGA Questions
Quicksilver , Mac ATI RADEON 7000 64MB DVI/VGA Video Card (PCI) (p/n 1024-9C02-00-SA)-Limited Supply Graphic Card Logo
1,358 people viewed this question
Top Quicksilver Computers & Internet Experts
David
David
Martin Buck
Martin Buck
Are you a Quicksilver Computer and Internet Expert? Answer questions, earn points and help others
