Question about Brother MFC 8840D All-In-One Laser Printer
Unable to print from computer after router was replaced
When printing the document comes out with lines across that look like barcodes along with text. Have changed drum and still the same. Any ideas?
Posted on May 12, 2011
  • 1,511 Answers
Hello and Welcome to fixYa!
Please do make sure that the device is turned On, and the device drivers are properly installed and the cable is plugged in properly...Also do make sure that there is no error message at the printer end... Clear that if any....
If you got an error message or something,do tell me...
Best of luck,,
Please do Rate the solution, if found helpful,
Regards.
Posted on Jul 13, 2010
I have Dell V505w wireless printer. It has worked fineuntil I replace my router with a new one. Now I can't scan anything to my computer. The orange light on printer blinks, indicating the printer is...
Either set the new router to the old router's IP, SSID, channel, key, etc. Or set the print server to the new router's network, SSID, channel, key, etc.
Feb 05, 2010 | Dell Computers & Internet
Have a new dell pc/will not print to photosmart. old hp computer still prints. unable to find where i put router number/think this may be problem
Make sure the driver for the photosmart printer is not checked. Click start, printer faxes and look to see if your printer is set to default.
Dec 25, 2009 | 2wire 2700HG-B Router (2700HGB)
I'm unable to get wireless connection to the internet after i replaced a new modem. Directy connection from modem to laptop is fine. Both my laptop and PC are able to detect the wireless network but are...
disconnect all the connections from the router. connect only the computer to the port 1 on the router. check the lights on the router. Reset the router for 30 seconds . unplug the power to the router. plug it back in. wait for 1 minute.now check the IP address on the computer. Win XP = click start ==> run ==> type cmd in run box and click ok. you will see the command prompt. in the black window type ipconfig and hit enter. now you will get the IP address and the Default gateway. Default gateway will be the number of your router. This will open the roputer set up. not check the settings on the router. If you connect the modem to the router, it works. now reconfigure the router as per ISP. Click Here for more info about how to set up router
Nov 18, 2009 | Linksys EtherFast Cable/DSL Router
Printer not picking up wireless signal to print from laptop.
so the printer was working before.
Did you try to change any settings on the router?
Is there any other wireless computer or other device able to go online ?
You will need to check the wireless settings of the router.
Click Here for step by step solution
Oct 30, 2009 | D-Link Computers & Internet
Printing on network
Does your printer have Network sharing capabilities? Some printers will allow you to share them, but still wont be able to allow you to print to them remotely. Secondly, if you have a server on your network, you'll need to check your router and make sure it's DHCP is not enabled and assigning IP addresses to nodes on your network. This can create communication problems if both DHCP servers are assigning IP ranges that are on completely different subnets
Jun 18, 2009 | HP Office Equipment & Supplies
Printer will not print to laptop
It sounds like you are using one printer and two computers if this is the case you need to SHARE the printer in both your laptop and Desk computer
Jan 22, 2009 | HP OfficeJet Pro K5400dn Photo Printer
C6180 scan unable!! conection error reported
Get the right Driver's and will work fine than recalibrate the printer. .http://welcome.hp.com/country/us/en/support.html
Jan 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Unable to setup wireless print server with wireless router
The issue was the wireless print server not properly connecting to my home network and thus being unable to see my modem/network. This was because my linksys wireless print server generates its wep key with a different algorithm than the Motorola surfboard SBG900, this also explains why when I was using my old linksys wireless g router, things worked without any issue (same wep key algorithm). Once I figured out how to manually configure the print servers wireless settings and manually enter the wep security settings I was able to connect to my network and the configuration found the print server and I was able to finish setup.
Nov 27, 2008 | Linksys WPSM54G Print Server
HP 7410 can't print anymore
I think I have solved this, any way it worked for me.
Turned off printer and turned off wireless router made sure no computers are on.
Restarted printer make sure wireless settings are installed in printer then restart router.Once router is up and running switch on computer and you should be able to print.
Hope this works for you.
Dec 17, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Brother MFC 8840D All-In-One Laser Printer Logo
47 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
