Question about Apple MacBook Mac Notebook
I have a dvd that will not play in my apple laptop. I had inadvertantly put the two shiny sides of the dvd's together and wondered if I somehow disabled the dvd's.
  • Apple Expert
  • 481 Answers
If other DVDs play OK on your laptop, then the problem is not in your laptop. If no DVDs play on your laptop, then the problem is in the optical drive.
It usually takes more to scratch a DVD than placing it next to some other DVD.
Posted on Jul 14, 2010
Testimonial: "Thanks for your prompt response. I am so technically challenged that I need help understanding how to examine the optic feature "
    Scholar:
  • 183 Answers
I have seen this problem before...
It was solved by getting a super-thick permanent marker, and colouring in the entire top surface. Apparently the top surface had become scratched and was causing problems for the laser on the underside. Make sure it's a permanent marker or the ink will rub off inside the drive.
Posted on Jul 25, 2010
DVD player will not play a standard DVD after playing a Netflix movie
Could be a region setting issue. Go to DVD preferences and restore defaults. Try running your standard DVD from an outboard player and see if it works. Check your region setting- should be Region 1 for American DVDs. Any error messages?
Feb 16, 2015 | Apple MacBook Pro - Core Duo 2.16 GHz -...
Muffled Voices on Dolby DVD Playback
Most voices come out of the centre channel. Put your ear to that to see if it is working. If it is not then you might have somehow managed to switch it off. Check the cable connections to the speaker also.
Mar 12, 2017 | Sony Audio Players & Recorders
My iphone screen got biger by itself and i cant fix so is there a solution?
Put 3 fingers together on the screen and move them around, it should fix the problem. I somehow managed. The trick is NOT to put 3 fingers together whilst playing a game!!!!
Nov 08, 2010 | Apple iPhone Smartphone
Delete key on macbook pro won't work
you may have inadvertently set up a keyboard short cut on the delete key... go to your system preference app in the dock. Then select keyboard shortcuts... if you select "default" at the bottom of the window it will revert to the factory shortcuts and eliminate any you may have accidentally created...
Hope that solves your delete issue...
K
Jul 21, 2009 | Apple MacBook Pro MB991LL/A 13.3-Inch...
DVD Drive problem
Yes the drive mechanism is bad.
Please don't open up your mac if it is still under warranty, as this will void it. The warranty is 1 year after purchase, or up to 3 years if you purchased apple care.
Please take your laptop in to be repaired by an authorized apple technician either at an authorized apple reseller or directly to the apple store.
Nathan.
Apr 13, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
DVD not working
Does any other DVD play? If so, your drivers are fine and the disc may be unreadable due to dirt on the lens, scratched too badly, not in the correct format, etc. Is there any error message? When you put the disc in, does the DVD drive icon change? You can also try putting the DVD in another DVD player to see if it plays in that one.
Jan 17, 2009 | Acer Aspire 5050-3242 Notebook
DVD player won't play
Make sure you have inserted the correctly; the label faces away from the TV/DVD player.
Oct 18, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
PowerBook Aluminum G4 1.67GHZ
Kim,  I'm glad you asked this.  I have had problems with my superdrive as well.  What I found out through persistent research is this:     The new Superdrives can take CD+R and DVD+R.  (I am assuming you are asking about recording?   However, the older models of Superdrives ---usually found in Powerbook G4s, can take CD-R and DVD-R.  These are different from the first ones ini that they are slower to burn, and just a few gb short of space than the +.  this should help solve the problem with taking new cds and dvds for burning.  The superdrive tends to just spit these right back out.  If you are referring to playing them, then have you tried cleaning the dirty ones?  Check the help section at www.apple.com.  they have wonderful solutions.  Try to put in a couple new cds or dvds to play.  Open up itunes or the dvd player before you put the disks in.  If you're still having trouble, make use of that warranty and go to your nearest apple store to fix it right up! Hope this helps!
May 19, 2008 | Apple PowerBook G4 Mac Notebook
Apple MacBook Mac Notebook Logo
75 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
