Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Water is leaking inside the refrigerator in the middle and the back right corner.
  • Roper Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezerwater is leaking inside the refrigerator in the - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jul 13, 2010
Whirlpool side by side water leaking on frig side right front corner not leaking in back 13yrs old ed2phexnt00
-Most likely the drain tube inside the fridge is clogged with waste food.
-Check it out and clean and clear the line. You'll not see any leak for a while until it clogged again.
Good luck and enjoy
Mai
Dec 27, 2017 | Whirlpool Refrigerators
2006 Tiffin Phaeton water leak by refrigerator
If you have been in a cold climate, there may be a possibility the water pump has frozen up and cracked. Open the lower vent cover outside for the fridge (about 14"x18") with a few long horizontal air vents in the middle. Use a coin to rotate the tabs from the two upper corner and remove cover. Locate the water line coming into the pump. If you see water in the immediate area, it may be leaking but dry the area up and have someone inside help you by filing a cup with water from the dispenser on the fridge door. If it has cracked, you will see the water start running out. It will also less when the ice maker is filling the tray. These units are plastic and cannot be fixed do you need to get it replaced. Before trying to remove the pump to take it to an RV dealer, make sure you turn off the water supply to the fridge. Most units will have a valve connected by a "T" at the cold water supply going to the kitchen sink
Mar 29, 2014 | Tiffin Motorhomes RVs
Amana TZ22RW Refrig (1993) : Water is leaking down.
I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Sep 12, 2012 | Amana Refrigerators
Water leak on floor under refrigerator
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | GE Refrigerators
LEAKING FROM BOTTOM RIGHT CORNER
Either leaking water valve, or possible cracked drain pan.
Apr 28, 2010 | LG LFX25960ST Stainless Steel French Door...
Refrigerator is leaking/dripping clear water, but the ice maker lines have no leaks and it appears to be coming for the middle of bottom of the box somewhere.
You may have a leak from the water supply line that is attached to the fridge from the house hold line near the bottom right corner of the fridge.
Jan 29, 2010 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
I need to replace the adaptive Defrost Control Board on Maytag Refrigerator Model No. MZD2766GEQ. Where is this board located?
Its Located in the top right inside corner of the refrigerator section near the back wall & to the right of the water filter.Its tough to get out but only takes about 10 minutes to replace the part
Nov 18, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Leaks water periodically onto floor bottom left corner freezer side
your freezer cabinet need to get all out and open the back wall
there is a drain hole in the bottom middle of it make sure it is
clean and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday . com.
Jun 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fridge Leaking water from front right hand corner
yes, get a pipe cleaner and put in to the hole to try and clear if not from the back you will find the pipe which will be clipped to a plastic tray on the compressor. unclip and blow up the pipe this will always clear the blockage.
Oct 19, 2006 | AEG SK78800I Compact Refrigerator
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
116 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
