Question about Onkyo TX-NR905 Receiver
Wrong valtage 220v was put through the receiver
  • petersa Apr 20, 2008
    Hi Graeme,
    Yes - 110 volt
    I can not get a signel from the DVD on HD
    Yes I have a transformer
    I can listen to CD's
  • 1,512 Answers
Hi there. Is it a 110 volt unit that we are dealing with. What are the symptoms now?
regards
Graeme
Posted on Apr 20, 2008
  • Graeme Ross
    Graeme Ross Apr 20, 2008
    I guess first, how are you connecting it to the mains at the moment. do you have a transformer connected?
    Does it still turn on and operate normally in other modes, say on tuner or CD?
  • Graeme Ross
    ok, sounds like you have escaped damage from the 220 volts. Thats good news:)
    They have a volatile memory, particularly for settings to do with video switching and input sourcing.
    If
    your unit has been disconnected, you may have to go through the menus
    and reselect the correct input sources for video switching.
    Q. Have you had the unit disconnected from the power for any length of time?
How we can vary o/p valtage in shark 650 model
sadly there are no adjustments to the voltage you receive from the power company .
Aug 23, 2016 | Dryers
Wrong elec. out let 220v
You mean the device is for 110VAC only ? Have a look at the rating plate on it. Unless that says input 110V - 220V it is most likely fried.
May 14, 2015 | DeLonghi EC270 15-Bar Pump Driven...
If I would buy a Onkyo TX-NR616 in the US (110V) and take it Europe (220V), wouldn't it be a solution to simply exchange the power transformer for a 220v one?
An stepdown transformer is needed should you buy in US and use it Europe
However, if your on a technical side , trace the primary windings , and check
There are European versions which are already 220V, no need to convert.
Source : page EN 99 of the Onkyo TX NR616
manual
Sep 24, 2012 | Onkyo Tx-nr616 7.2 Thx Certified Network...
What will happen if I plug my 110V tv into a 220V receptacle?
If you want to fry your electronics or appliances that's it's a sure way to accomplish that.
While appliance working ONLY at 220v will just not work or under perform (like a hair drier) when plugging electronic equipment that runds ONLY at 110v then that item will be "fried" as all its electric components will be burnt as it will receive twice the power that it was build to receive. Should that happen the safety switch on the 220v circuit where the item was MISTAKENLY plugged will be triggered (hopefully or there will be risk of fire and serious injuries, even death) and the power will be shut off. That's a major but possible mistake.
If traveling abroad those who come to US will unlikely damage their appliances (like electric razors) as they will receive less power (110v vs 220v) and usually these items are protected against these mistakes by the specifications of their own design. The opposite is not true of course as just mentioned above.
So do not play around with dangerous items please! ;) On a positive note though: Nowadays most appliances have dual power and should work whether plugged in a 110v, 60Hz (most common in US) or 220v 50Hz (most common in Europe). So nothing really happens... it just works as long as you have the proper adapters to plug the appliance to the different receptacles.
Note: One of the differences is that (without going into the math of it all), an appliance working at 110v will draw x2 times the power than it draws when working on 220v so if an appliance was drawing 3A at 110v it will only draw 1.5A when working at 220v.
Best.
Jul 05, 2010 | Televison & Video
All i need to know is what valtage should my
running chRGING SYSTEM VOLTAGE SHOULD BE 13.7 TO 14,5
Mar 21, 2010 | 1985 Suzuki Tempter GR 650
Wrong valtage
I am not sure what your question is but if you purchased the U.S. version and it is 110V and you are somewhere where there are 220V, you will need to purchase a stepdown transformer for it to work properly.
Apr 20, 2008 | Onkyo TX-NR905 Receiver
Plugging in with multiple voltage requirements.
no... it will put out 220volts, same as the wll socket voltage. you will need a 220v to 110v stepdown transformer to run the sub.
Dec 15, 2007 | Onkyo HTR500 Receiver
Please Tell Me That I Did Not Damage The Router
that linksys router u purchesed in out side america right might be u r using this in asia pasific so the power adapter u got with the box its comparatable only in USA the in put and out put voltage is different
out put voltage is -->12V, 1.0A Max
in put voltage is -->100V - 240V>so u need to get a power convertor u can get it in local market rate me solved if its helps thx
Nov 25, 2007 | Linksys Wireless-G WRT54G Router
Plugged in 220v by mistake
Did you check trafo? Do you get any power on secondary coil?
Oct 09, 2007 | Aiwa AV-X200
Onkyo TX-NR905 Receiver Logo
21 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
