Question about Hotpoint Dryers
MY DRYER HOTPOINT HD DLL2650BFLAD, RUNS FINE BUT WHEN YOU TURN KNOB TO HEAT IT BLOWS THE BREAKER, I REPLACED THE IGNITER AND BOTH COILS, STILL BLOWS BREAKER?
Amigaman
  • 248 Answers
SOURCE: Gas dryer is not heating up
Could be a bad set of burner coils. Does the glow come on for a bit then goes out. And after a bit does same?
Probably bad coils. If you were able to change ignitor, you can do the coils. Unplug first! The coils are the 2 black cylinder shaped devices on burner. They are held on with a bracket that has 2 phillips screws. You can probably take them to your parts house and they can ohm them out for you. Make sure to write down their position before removing them.
Posted on Nov 07, 2007
colin324
  • 57 Answers
SOURCE: DRYER RUNS BUT, NO HEAT
They normally have a thermal cut out on the rear, behind a small cover or rubber area. Reset this by pushing it in. You have probably let it get too hot at some point by not keeping the filter cleaned often enough, or the outlet hose getting blocked. If there is not a reset, or it doesn't resolve the problem, it may be a fault with the hetaer element. These are not normally difficult to replace, just normally difficult to get to!
Posted on Jan 22, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool gas Dryer LGR5636JQ1
theres a thermal fuse located on back panel usually white maybe 2 inches tall 1/2 wide 2 blue wires leading to it. ck for continuity, if none replace that(most common problem)... if good you can go back to the ignitor and unplug the white connector it plugs into. place your meter leads into the connector and turn on dryer, you should get 110v. if you do you have a bad ignitor, if not a thermo's gone bad (check the thermal fuse first though.
Posted on Mar 12, 2008
  • 686 Answers
SOURCE: kenmore gas dryer [changed to propane] will not heat
Does it ignite? tell more plz
Posted on Mar 01, 2009
gary1121
  • 332 Answers
SOURCE: dryer will not heat up
if the ignitor doesn't glow it could be broke it is vary fragile, and made of carbon, you might want to have a tech come out, if you can see it with a flash light it has 1 screw that holds it in place if you can get it out unplug it, take it to R.E.Michaels a supply house over the us if not look for an appliance co, that has parts and you have to get the one with the same plug and hold down. you can instal it your self but remember do not touch the carbon part, it is sensitive to the oils in your skin only handle with the hold down,, if you touch the caron as soon as it lights up it will break, no doubts in that----good luck
Posted on May 30, 2009
GE - Hotpoint Dryer Model # QUXR453EV2WW (2001)blows breaker what might it be
Shorted heating element. Fluff cycle does not use heat.
Sep 18, 2016 | GE Dryers
My Hotpoint gas dryer won't relight after it has
Your gas valve electrical coils have gone bad. They are easy to replace.
Jun 21, 2011 | Hotpoint Dryers
No heat in dryer
Hi
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | KitchenAid Dryers
The dryer runs, but there is no heat. Gas is
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Aug 20, 2009 | Kenmore 700 6972 Dryer
I have a gas dryer , dryer only runs on air. There is no heat. What is causing the problem? Please advise!
Igniter
Gas valve coils
Thermal fuse
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Aug 03, 2009 | Dryers
Maytag performa dryer will not heat up
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
Igniter
Gas valve coils
Thermal fuse
Jul 06, 2009 | Maytag Dryers
Maytag neptune (gas dryer) just stopped heating up...was working fine yesterday. The dryer is 8 years old...never a problem. Does the heating elements need replacement?
Gas dryers utilize a gas valve, ignitor assembly, and a series of coils mounted on the gas valve to provide heat and safety. The gas valve coils are the usual suspect when it comes to a "No Heat" complaint. I have provided a checklist from www.repairclinic.com, for your convenience. They also provide disassembnly diagrams and repair parts.
Firstly, ascertain that you have made an adequate "Heat" selection, then read on:
Igniter
Gas valve coils
Thermal fuse
Jul 06, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Alg331raw gas dryer. Runs but no heat. Worked
Check the following to address this issue
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 04, 2009 | Amana ALG331RAW Gas Dryer
No heat, clothes do not dry
the model number that comes up is DLL2650BPL you could have a bad igniter,gas coils or sensor but the only way to tell is by reading them out with a meter the igniter part number is WE4X444 gas coils are part 5303931775 and the sensor is part WE4X448 you can go here to see parts
https://www.repairclinic.com/Shop-For-Parts/a8b95d49280/Model-DLL2650BPL-Hotpoint-Dryer-Parts
if you have heat at the beginning and then no heat it will be the gas coils but one of the coils still could be bad and not work at all but check all parts with meter before you start ordering parts you don't want to change out good parts.
Feb 09, 2018 | Hotpoint Dryers
Nov 06, 2007 | Hotpoint NVL333GY Gas Dryer
Dryers Logo
46 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
