Question about Dell 926 All-In-One InkJet Printer
Cartridge carrier does not move when I open the top to replace ink cartridge this is the new problem. Old problem: had to press print then turn off the computer & printer & turn them back on to get the printer to print.
  • 524 Answers
Hi...
when you open the tops cover the catridge wil not move. this fuction is provided for safety reasons. so its normal.
Posted on Jul 13, 2010
When fax comes through paper is blank. I've tried 2 different cartridges
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink
cartridge appears in the display, replace the print cartridge. The part number for
replacement cartridges is HP 701.
1. Take out a cartridge from its packaging and carefully remove the tape covering the
printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper
area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
1 Access Cartridge
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
Care and maintenance 45
3. Open the control panel and cartridge compartment cover (it will click and remain
open).
4. Push the cartridge down and remove it.
5. To load the cartridge insert the cartridge as shown below. When the cartridge is
pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks
into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this
step.
1 Control panel
2 Cartridge compartment
cover
46 Care and maintenance
Clear jammed documents and paper
6. Close the cartridge compartment cover and control panel.
7. Press Start/Enter.
8. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the
correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount
of remaining ink. Once you have put in a new cartridge, use it until it is completely
exhausted.
Nov 11, 2011 | HP 640 Inkjet Fax Machine
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    How to change printing cartridges
    Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
    3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
    4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
    Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
    1. Unplug the printer from the power source.
    2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
    3. Remove the used cartridges.
    4. Load the new cartridges. Close the cover.
    5. Plug the printer back to the power source.
    You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
    Apr 04, 2011 | Lexmark X3650 Printer
    HOW DO I CHNGE THE CARTIDGE.?
    When you notice that the print becomes light or ink low or when install new ink cartridge appears in the display, replace the print cartridge. The part number for replacement cartridges is HP 20.
    1. Take out a cartridge from its packaging and carefully remove the tape covering the printhead.
    Hold the cartridge by the colored top or black areas only. Do not touch the copper area.
    3. Open the control panel and cartridge compartment cover (it will click and remain open).
    4. Pull the cartridge toward you and remove it.
    3 To load the cartridge insert the cartridge as shown below. When the cartridge is pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks into place.
    If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
    5. Close the cartridge compartment cover and control panel.
    6. Press Start/Enter.
    7. Press 1 for new cartridge, or 2 for the old one.
    • When you put in a used cartridge, choose 2:Used. This helps you to check the correct amount of ink you have left.
    TIP: If you mix up several used cartridges, it is not possible to check the correct amount of remaining ink. Once you have put in a new cartridge, use it until it is completely exhausted.
    Dec 22, 2010 | HP 1040 Plain Paper Inkjet Fax
    How do I install the printer cartrige? I do not have the booklet...
    1. Turn on your printer.
    2. Open the front cover.
    1. Press the tabs on the cartridge lids, then lift the lids.
    1. Remove the old ink cartridges.
    1. Store the cartridges in an air-tight container or dispose of them properly.
    2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
    1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
    1. Snap each lid closed.
    1. Close the front cover. The front cover must be closed to start a print job.
    1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
    2. Click the Maintenance tab.
    3. Click Install a new print cartridge.
    4. Click Next.
    5. Select the type of cartridge you installed.
    NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
    1. Click Next.
    Dec 17, 2010 | Dell Inkjet 720 Printer
    Hello, just today my printer (HP Officejet 6310 All-In-One InkJet Printer) showed an error saying , "Cartridge Error: Cartridge in the left must be replaced. I put ink on both , just in case that was...
    You need to decide upon a suitable replacement. HP recommends using their ink cartridges, but you can also choose to use a cartridge from a different brand. If you have a higher volume of prints, you may even consider refilling old cartridges to cut down on costs.
    Remove the old cartridge by removing the main cover. The cartridge carriers will automatically move to the center. Press the top of the carriers to open the plastic lids covering the cartridges. Gently press down on the old cartridge and slide it out.
    Install your new HP printer ink cartridge. Remove the blue protective strip from the contacts and place the cartridge in the carriers. Press down gently until the cartridge sits in its position. Replace the carrier lid and main printer cover. Restart the printer and take some test prints.
    Nov 17, 2010 | HP Officejet 6310 All-In-One InkJet...
    How do you open for ink replacement?
    Removing an empty print cartridges Follow the steps below to remove an empty print cartridge:
    1. Press the Access Cartridge button on the control panel. The cartridge carrier moves to the remove/install position. Figure 1: HP Fax 1040/1050 control panelc00253378.gif 1 - Access Cartridge button
    2. Open the control panel and cartridge compartment cover (it will click and remain open). Figure 2: Opening the control panel and the compartment coverc00253379.gif 1 - Control panel 2 - Cartridge compartment cover
    3. Pull the cartridge toward you until it releases from the print cartridge cradle and then remove it. Figure 3: Removing an empty print cartridgec00253380.gif 1 - Pull cartridge towards you 2 - Remove cartridge from print cartridge cradle
    Installing a new print cartridge Follow the steps below to install a print cartridge.
    1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape using the pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Figure 4: HP 20 print cartridgec00259017.gif
    2. With the cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place. Figure 5: Inserting a new print cartridgec00253382.gif 1 - Insert the print cartridge into the print cartridge cradle 2 - Push the top of the cartridge until it clicks into place NOTE: If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
    3. Close the cartridge compartment cover and control panel.
    4. Press the Start/Enter button.
    5. On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old. NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
    for more information follow the link:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00253364&tmp_task=useCategory&lc=en&dlc=en&cc=ca&lang=en&product=425911
    Jun 18, 2010 | HP 1040 Plain Paper Inkjet Fax
    "Print carrier stall"?
    Error 0502-Carrier Stall indicates a physically blocked carrier. This condition can occur for many possible reasons. Most often, the carrier is blocked because the ink cartridge lids are open while the printer is on (Figure 1).
    Figure 1: Open Ink Cartridge Lids
    Reseat the Ink Cartridges and Make Sure the Lids Are in Place
    1. Make sure the printer is turned on.
    2. Lift the printer's front cover.
      new_note.jpg Note: The ink cartridge should be in the up/loading position unless the printer is busy.
    1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
    2. Remove the cartridges.
    3. Make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
    4. Replace the cartridges.
    5. Snap the lids closed.
    6. Close the printer's front cover.
    7. When prompted on the printer's LCD to choose New or Old, choose Old.
    8. Press Select.
    new_note.jpg Note: For more information about reseating ink cartridges, refer to the Maintenance or Ink Cartridge Maintenance section in the Online User's Guide.
    Back to Top
    » Reposition the Encoder Strip
    1. Remove the power cord from the printer.
    2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
    3. Gently slide the ink cartridge carrier to the middle of the printer.
    4. Gently move the top part of the printer belt to the right.
    5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
      Figure 1: Inkjet Printer Encoder Strip
    6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
    7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
    8. Once the encoder strip has been re-seated, close the scanner lid.
    9. Re-connect the power cord to the printer.
    Jul 18, 2009 | Dell 922 All-In-One InkJet Printer
    Where do i insert the ink cartridge in Brother DCP-130C printer?
    Turn the printer on and open the top cover. The cartridge carrier should move to the opening. Get the new cartridge ready to install, remove the old one and install the new one. When that is finished, close the top and the cartridge carrier will return to its normal spot, probably do a head cleaning cycle and be reaady to print.
    May 28, 2009 | Brother Office Equipment & Supplies
    How do I change the ink cartridge in my Lexmark x2470
    How to Install or Replace the Ink Cartridges in the Lexmark i3 ID: 810 This document does not apply directly to your Lexmark X2470
    1. Make sure that plain paper is loaded in the paper tray.
    2. Ensure that the power light is on.
    3. Open the cartridge door.
      The cartridge carrier may move slightly, and then return to the loading position.
    4. Push up on the cartridge lever.The cartridge holder springs open.
    5. Remove the old print cartridge and dispose of it.
    6. Remove the sticker and transparent tape from the new print cartridge.
      Warning! Do not touch the gold contact area on the print cartridge.
    7. Install the new print cartridge as illustrated below. Insert the cartridge into the carrier slot. Push the cartridge lever back to secure it under the cartridge hook. Press the cartridge lever down until it snaps into place.
      Insert the color cartridge in the front carrier slot.
      Insert the black cartridge in the back carrier slot.
    8. Close the cartridge door.
    9. On the PC, open the Lexmark i3 Solution Center and click Print Cartridges.
    10. Then click Print Cartridge Installation and follow the on-screen instructions to install the cartridges.
    Please Rate the solution.
    All the Best
    Sammy
    Sep 26, 2008 | Lexmark Office Equipment & Supplies
    Dell 926 All-In-One InkJet Printer Logo
    76 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
