Question about Delta Faucet 2530CBLHP/H25 Innovations 4'' Centerset Bathroom Faucet - Chro
How do I replace the spring and rubber seal - Delta Faucet 2530CBLHP/H25 Innovations 4'' Centerset Bathroom Faucet - Chro
  • 349 Answers
First turn water off to faucet and remove the screw that hold's the handle in place. They may have a cap on the handle to remove to access the screw.
After screw is out the handle should come off you may have to wiggle it a little to get it to come loose. Next you will have access to the spring and washer for that stem.
It should be located on the bottom of the stem just remove it and replace new ones back in place.
Some have sping's and seat in the body of the faucet if not located on the bottom of the stem.
Posted on Jul 17, 2010
Zanussi fl 1084 washing machine door seal. How do I replace the rubber seal?
the seal comes in a shrunken size use a hair dryer to stretch it on to the door lip
Dec 03, 2013 | Washing Machines
Front load washer door seal is detached
The seal appears to be spring reinforced. you may need to remove the door partially and rewrap the spring around seal. or if broken or cracked try to replace or fix with a sheet rubber and rubber cement. May be an old bike tube!? hehe
Mar 02, 2013 | Washing Machines
Rubber seal inside door came off-how do I replace it and where does the retaining wire/cable go?
Reinstalling that rubber seal is a lesson in patients. There is a metal lip on the machine opening and a cooresponding groove in the rubber seal. These two need to be mated together. That's the easy part. Once together, the retaining wire and spring go around the rubber seal just on top of where the rubber seal goes over the matching lip. It will take several tries, the spring may be small but it's very strong and difficult to stretch. Good luck.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kitchen taps drip and leak.I do not want to replace with new but would like to sort these problems.
dependent on the type of faucet, you need to replace (a) the washers, (b.) the spring and seals or (c.) the gasket. They all serve the same purpose. 1. turn off the water supply to the faucet. 2. double handle? (a)remove the center cap (b) then remove the screw holding the handle down (c)next unscrew the valve stem retaining nut (normally it is the one right above the faucet body). (d) pull the valve stem out, if there is a small rubber piece held down by screw remove the screw, replace the washer. if there is a rubber gasket wrapped around the stem, remove and replace it, if nothing is on the stem look into the faucet body you should see 1 or 2 small rubber pieces these are the seals the springs are right below the seals. Remove and replace springs and seals. 3. single handle? remove the handle retaining screw, normally covered by hot/cold indicator symbol, unscrew valve stem retaining nut, pull the valve stem and replace either the gasket or springs and seals.
Aug 28, 2009 | Home
Rubber gasket
Feel around the seal, in the groove behind the seal face. You'll find a spring at the bottom. With a small screwdriver, lever the spring over the seal face. Work the steel ring off. Fold the seal inside the washer. Unplug the washer, Remove the door, and set aside. Locate your panel screws and remove the front, exposing the drum and basket. There are usually additional screws under the dispenser trays too. Disconnect the door lock wires. Locate the other spring/ring assembly on the outer drum, and remove. Orient your new seal properly and reassemble. The only difference on the reassembly is that, when you are putting the rings back on, start 180 degrees from the spring, and work the ring back on until you get to the spring. Carefully lever the spring back over the seal face, being careful not to damage your new seal.
Best regards, --W/D--
Aug 08, 2009 | GE Energy Star WCVH6260F Front Load Washer
Rubber door seal replacement on my Front Load Washer
OPEN THE DOOR
THERE IS A WIRE AND SPRING CLAMP AROUND THE SEAL, PULL BACK THE SEAL WITH YOUR FINGERS AND YOU WILL SEE IT
TAKE OFF THE CLAMP
FOLD THE SEAL BACK INTO THE DRUM
YOU WILL SEE ( OR FEEL ) A CLAMP AROUND THE SEAL ON THE DRUM
SLACKEN OFF THE SCREW HOLDING IT UNTIL YOU CAN PULL OFF THE SEAL.
FIT A NEW ONE IN REVERSE ORDER.
HINT- WIPING WITH LIQUID DETERGENT WILL MAKE IT EASIER TO FIT THE NEW SEAL.
HINT2 - YOU MAY NEED 4 PAIR OF HANDS TO FIT THE SPRING CLAMP
Jul 06, 2009 | Whirlpool Washing Machines
When I installed my delta replacement cartridges, RP1740 two handeled faucet, the water will not turn off no matter which way I turn the handle. I have a new rubber cup and spring. It looks so easy, I must...
Sounds like you might have the rubber cup seals installed upside down? The spring goes int he body first, then the cup seal goes over and on top of the spring.
Jun 25, 2009 | Delta Plumbing
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
Replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Sep 28, 2007 | Washing Machines
Delta Faucet 2530CBLHP/H25 Innovations 4'' Centerset Bathroom Faucet - Chro Logo
194 people viewed this question
Top Delta Faucet Plumbing Experts
Steve Wood Plumbing...
Level 1 Expert
joeiaaz
Level 1 Expert
doconnell13
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
