Question about Maytag Neptune MCE8000AY Electric Dryer
Maytag dryer MCE80000AYW top dryer will not shut off and lower dryer will not turn on. Cannot put in Diagnosistic mode because top dryer remains in pause mode. When it gets close to shutting off the damp dry signal on the lower dryer goes haywire beeping constantly until dryer is unplugged. Which does not reset the dryer when turned on. We have tested the temistors and found them operational, the bottom dryer motor and blower will come on when tested with meter. The damp dry signal is testing bad. Cleaned all the lint that was clogging the exhaust out, put machine back together but it still responds in the same way with the top dryer running and the bottom dryer not. our question is do we need to change the whole console panel with membrane pad. Or is there another option we don't know about. HELP would be greatly appreciated as no one here or in my surrounding area works on this machine including all the maytag dealers kathi hamilton
  • 6,784 Answers
Hi. Your control panel/membrane assembly is not the issue here. That part is ok. The areas of concern will be the moisture sensor and logic board. The initial area or part will be the moisture sensor bar. Usually, this sensor will cause the exact same symptoms that you are experiencing at this time when the sensor fails. The main logic board cannot communicate with the sensor in this state, thus causing the logic sector to malfunction. i recommend to replace the moisture sensor, asap. This should correct the issue. The part number will be 33001809
Posted on Jul 13, 2010
  • Michael Masters
    Michael Masters Jul 13, 2010
    Additionally; This particular issue is very tricky, due to the fact that, the moisture sensor cannot be tested. This will present a slight unorthodox approach to the repair. I would advise to start with replacing the moisture sensor. It is not very expensive, and it is the most possible culprit in your case. If in fact the the new moisture sensor dose not correct this fault; Replace the logic board. These are the only two parts to focus on. Every other part in this unit will not be affected or damaged, as of now.
    Logic board part number will be 31001562.
Maytag Dryer MDE6400AYW. Dries clothing but does not shut off in Auto Mode. Tried Timer mode but the knob does not advance on its own and dryer does not shut off in that mode either. Replace Timer?
Some of them timer can be oiled, (just a little zoom oil no wd-40) if it is real hard to turn, the knob can become cracked and the timer motor itself it may not have enough ump to move the gears and sometimes oiling the timer and moving it around many times loosens em up.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 11, 2017 | Maytag Dryers
Dryer won't shut off.
Will the timer advance in the NO HEAT mode? If it does advance you would know it has something to do with the temp alright but if it don't advance in No Heat then the timer motor is bad in my opinion. And it can fail by more than one way. Open winding OR stripped motor gear.
Aug 30, 2012 | Maytag Dryers
We have a model MCE80000AYW, the big dryer. the
it is a rahter easy fix
four long 1/4 bolts hold the control in place
inside the upper dryer on the back of the control
sears part number
31001658 298.30
Oct 09, 2009 | Maytag Dryers
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
Maytag Performa Electric Dryer Won't Start
check the blower wheel, sounds to me like it is loose on the blower motor, common on these dryers. One sure sign would be a warped filter and a rusted top. The blower aint putting out enough and the dryer is over heating .
/uploadswith image
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number 200258764242.
Premmy
Oct 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MCE8000AY Electric Dryer Logo
89 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
